Question about Sony PSP (Piano Black)
Memory leak - Sony PSP (Piano Black)
    Novelist:
    Champion:
  • 347 Answers
Sorry explain what your problem is
Posted on Mar 14, 2011
Apps are crashing and screen flashes due to memory leak ! Need update for OS!
If you use Win7 or newer, updates should be automatic but if they have been switched off, there is a link to update in your programme menu. If older, no updates available as pre Win7 is no longer supported. Memory cannot leak, it either works or it doesn't.
Aug 23, 2016 | Computers & Internet
Why does firefox window slowly roll down when closed?
A key feature of Firefox is the ability to create Firefox extensions -- programs that anyone can create to add features and capability to Firefox. While Firefox developers can fix memory leaks in the Firefox program, they can't control memory leaks in Firefox extensions. If you still experience a speed degradation after upgrading to the latest release of Firefox, one of your extensions might be leaking memory. Disable all extensions and re-enable them one by one to determine which extension is causing the problem. Contact the extension developer to find out if there's a fix for the program.
Jul 30, 2014 | Mozilla Firefox
Memory problems
How to prevent low memory problems Running fewer programs at one time can help prevent low memory problems and information loss. It's a good idea to observe which programs show signs of low memory conditions and try not to run them at the same time.
However, it's not always convenient or practical to run a limited number of programs. Signs of low memory can indicate that the computer needs more RAM to support the programs you use. Here are the recommended ways to solve or prevent low memory problems:
  • Increase the paging file (virtual memory) sizeWindows automatically attempts to increase the paging file size the first time your computer becomes low on memory, but you can also manually increase it up to a maximum size that is determined by the amount of RAM installed. Although increasing the paging file size can help prevent low memory problems, it can also make your programs run more slowly. Because your computer reads information from RAM much faster than from a hard disk (where the paging file is), making too much virtual memory available to programs will slow them down.
    For more information, see Change the size of virtual memory.
  • Install more RAM
    If you see signs of low memory, or if Windows warns you about a low memory problem, check the information that came with your computer or contact the computer manufacturer to determine which type of RAM is compatible with your computer, and then install more RAM. To install RAM, check the information provided by the manufacturer.
    For more information, see Find out how much RAM your computer has.
  • Determine if a program overuses memory
    If the computer becomes low on memory whenever you run certain programs, one or more of those programs might have a memory leak. To stop a memory leak, you need to close the program. To repair a memory leak, you need to check for updates for the program or contact the publisher of the software.
    To determine which program is using the most memory, follow these steps:
    1. Open Task Manager by right-clicking the taskbar, and then clicking Start Task Manager.
    2. Click the Processes tab.
    3. To sort programs by memory usage, click Memory (Private Working Set).
    You can also check for program errors and troubleshooting information using Event Viewer.
    1. Open Event Viewer by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, clicking System and Security, clickingAdministrative Tools, and then double-clicking Event Viewer. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
    2. In the left pane, click Applications and Services Logs to view error events. To see a description of the problem, double-click the event. To see if troubleshooting information is available, look for a link to online Help.
Mar 08, 2013 | Dell VOSTRO 3350
My printer is sharp and it displayed on the screen fuser temp?
memory leak in spoolsv.exe I have a Windows 2003 Std sp2 server that is my primary print server for my entire company. We have 40+ different printers configured on it.
About 2 months ago, we started having performance issues with the box... the Print Spoooler service apparently has a memory leak and eventually consumes so much memory that the service stops responding. Print jobs accumulate in the queues but never get printed. As soon as we restart the spooler service, the jobs spit right out.
I've changed all of my printer ports to Standard TCP/IP ports per a suggestion I found on google, and installed SP2 per M$ suggestion, but nothing has helped. spoolsv.exe will go from 2MB to almost 500MB of memory in less than 12 hours.
I can use perfmon to monitor the memory usage and such, but so far I haven't found any utility that will identifiy EXACTLY what is causing the spooler service to leak memory like this. There are so many different drivers that use spoolsv.exe, how can I tell which one is the culprit?
Feb 28, 2011 | Computers & Internet
Wont boot, wont display anything on monitor, cant access bios. trying to format the hard disk and install win7
remove memory boot should hear seris of beeps memory is clear,reinstall memory one at a time if it boots with one but not two have a bad memory stick
Jan 26, 2011 | Shuttle XPC SD32G2 Barebone
Bsod
Maybe a memory leak, or damaged?
is this the RAM we are talking about?
Jul 13, 2009 | Computers & Internet
Memory leak
you will have to wait till service pack 2 for Vista comes out. The SP2 for Vista fixes the memory leak problem
Mar 07, 2009 | Microsoft Windows Vista Ultimate Edition
Power on & off
I believe that Windows Mobile has some "built-in" memory leaks. But my experience with this phone is that some of the third party apps that change the appearance of the display (i.e. - SPB Mobile Shell) take up an enormous amount of memory and tends to leak severely! I suggest removing any third party apps from your phone and seeing if you still experience the issue. If so, hard reset the phone. If not, install the third party apps one at a time and let them run for a while before installing the next app to narrow down the app causing the problem.
Jun 02, 2008 | T-Mobile Wing™ Smartphone
Sony PSP (Piano Black) Logo
27 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
