Question about ViewSonic Computers & Internet
My monitor comes on for a few seconds then goes off how can i fix that
    Scholar:
  • 82 Answers
Check to make sure that the power cable and computer cable are secure. Im not sure how many options your monitor has, but here are some troubleshooting tips:
  • Try plugging a different computer into the monitor using the same connector
  • Try plugging a different device into the monitor using a different connector (TV, Etc)
  • Try plugging the same computer into the monitor using a different kind of cable (if option is available)
If another computer works then it is the computer and not the monitor, if a different connector works (HDMI or RGB instead of VGA) then it is the connector. If another computer or another connector results in the same problem then the monitor is likely faulty and will need to be repaired by a professional or replaced.
Posted on Mar 14, 2011
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
The light comes on for A few seconds amd goes out. The back light comes on for A few seconds dimly and goes out how do you open the monitor and fix it?
Here are the free service manuals: http://elektrotanya.com/?q=showresult&megnev=ACER&megnev2=AL1917&kategoria=&kat2=schematics
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
May 10, 2010 | Acer AL1917W LCD Monitor
PL 9 19" CRT Monitor: my mag innovision lt716s 700p monitor screen keeps...
Take care.
May 06, 2010 | CTX PL 9 19" CRT Monitor
I have a AOpen Flat panel monitor, model # F70VS. It comes on for a few seconds but the screen goes black. Can this be fixed or do I need to buy a new one?
try the monitor with another pc or laptop , if the same problem happens then yes seems to be a fualt with monitor
Nov 29, 2009 | Computers & Internet
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Iimj9 sonic tft - lcd monitor goes out after 3 seconds
You should remove power for a few min then hook up and try again.electronics sometimes need to be reset after any fluctuation in power. Good Luck
Jan 26, 2009 | ViewSonic VX910 19" LCD Monitor
The LCD does goes dark after power on
you mean few second the monitor goes in black. then its come. if it happen, it is ok
Jan 21, 2009 | Sony VAIO® VGC-LS37E PC Desktop
Optiquest q9 turns off
read the solution I have wrote on th Q7
display goes blank after few second
the fix is about 5 $ the supply is almost dead
Jan 18, 2009 | ViewSonic OptiQuest Monitor
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Computers & Internet Logo
79 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
