Question about Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M
I cant pull the cord on my FL1500LE blower - Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M
My fl1500le blower starts in full choke but dies as soon as i move it to half choke
Check the following, and then clean or replace:
  • Fuel Filter - Located INSIDE the fuel tank
  • Spark Plug
  • Spark Arrestor - at Muffler
  • Carburetor - May need a rebuild kit
Also watch this...
and this one as well...
Dec 10, 2013 | Weedeater 2 Speed Gas Blower FL1500LE ()
Cannot remove the impeller so i can replace starter cord
Assuming you have the nut/washers removed, a small amount of WD 40 on the shaft and GENTLY pry it off with whatever 2 tools you have on hand, 180 opposite each other. The only thing holding it on is a little corrosion.
Jun 29, 2011 | Weedeater 2 Speed Gas Blower FL1500LE ()
Pull cord is hanging out and will not restring
the recoil system is worn out (have to buy and replace it).
May 15, 2011 | Weedeater 2 Speed Gas Blower FL1500LE ()
Need to know how to replace string on weedeater gas blower FL1500LE
The Weedeater FL1500LE is a 23cc 2-Stroke Gas Blower and does not use string. It only uses air.
Mar 31, 2011 | Weedeater 2 Speed Gas Blower FL1500LE ()
The pull chord is jammed on my FL 1500 LE. How do I get it loose?
Unfortunately,its not jammed,you need a new starter clutch mechanism,I have a similar problem,if you can get one from your agent/supplier its quite easy to do yourself,you should be able to download a pdf manual from the internetrgds
Sep 26, 2010 | Weedeater 2 Speed Gas Blower FL1500LE ()
I need to repair the starter mechanizum on my weedeater fl1500 gas blower. How do you get at it?
Oh, are you in for a job.
here we go,,,,pull air output tube. then remove bottom of air intake shroud...then remove impellar, then remove top half of air intake shorud... now all starting parts will be visable. They are mounted on top of the top half of the air intake shorud......careful, the fuel tank is mounted to the top half of the shroud...Good luck.
May 29, 2010 | Weedeater 2 Speed Gas Blower FL1500LE ()
Replaced starter spring on Poulan/weed eater FL1500LE leaf blowe.
you may have wound the spring backwards, try winding the othe way.
May 09, 2010 | Garden
Starter cord is stuck. Will not retract. What do I do
I spent a lot of time, but I found that most of the problems with this starter rope etc, are caused by the starter assembly being too tightly mounted to the motor assembly causing drag on the rope mechanism.
I fixed the problem by adding spacer washers between the starter and the engine mount (two small washers on each of the 5 or 6 mounting bolts adding about 1/4 inch of clearance.
Now even my wife can start this machine..
Apr 26, 2010 | Poulan FL1500LE 25cc 150 MPH Blower
The pull cord is stuck, can't be pulled to start
This solution applies to the Sears model 358.797200, which also appears to the FL1500LE marketed under the Craftsman name, and may apply to other, similar, blowers. Go to the searspartsdirect.com site and enter the Sears model number. This blower may be prone to develop binding in the pull cord rewind spring compartment. (The binding may easily be misdiagnosed as a seized up engine.) The binding can be fixed by adding washers to increase the spacing. Open the rewind starter page on the sears site for an exploded view. I found that by placing 2 washers on each of the 5 screws (no. 7 on the diagram) which attach impeller housing (12) to the motor, I increased the spacing enough so the pull cord operated and retracted normally. The washers must go between the impeller housing and the motor. To complete the repair, you need to add a washer between the spacing flywheel (14) and the impeller(15) to keep the impeller from binding against the housing. The gasoline tank screws won't line up as well with the holes, but will fit. Install all 3 screws for the at first loosely, then tighten them down.
Oct 25, 2009 | Garden
Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M Logo
205 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
