Question about Sirius Satellite Radio Sirius SIR-ALP1 Satellite Radio Receiver
Having trouble with my SIR-ALP1 sirius radio tuner. Been working great for 5 years and now no signal at all. Icon is not listed on the alpine head unit but head unit works fine with all other accessories. Really think its the Sirius Tuner so I checked the fuse, wiring, etc in and out of the tuner and all looks good. I have noticed that the SIR-ALP1 tuner does not have the constant internal orange light that glows steady when it is working. Instead it is now a flashing internal light in a sequence. Any repair solutions out there yet?
2 Suggested Answers
SOURCE: Alpine CDA-9855 won't recognize SIR-ALP1
I also had this problem. I had to go through the menu into the setup and then into tuner settings. There should be an option called tuner area. If you set it to area 1 it should start working. For some reason the sirius only works on area one. Hope that solces your problem
Posted on Jan 06, 2008
I have my cd changer (alpine) plugged into the input port via ai net cable and I have the output going to the alpine radio (cda 9886) via ai net cable. When I hit the source button everything comes up but...
One thing to verify is that the Ai-Net switch at the bottom of the radio is set to Norm and not the EQ position. And also gray Ai-Net connectors are for audio input and the black Ai-Net connectors are for audio output. It sounds like you have everything connected correctly and at least the Sirius is coming up. And I assume that the CD changer works when connected directly to the reciever so you know that it is working. I would suspect that there might be a problem with the Sirius reciever not allowing the communication signal to connect to the Alpine deck and in that case you would need to get a new reciever. You could check the Alpine radio settings and see if there is something that needs to be changed in order to allow the CD changer to work. If you disconnected the battery connection to the radio then it might have reset the settings to factory default. Otherwise it sounds to me like the problem is with the Sirius reciever.
Jan 09, 2010 | Sirius Satellite Radio Sirius SIR-ALP1...
My CDA-9847 will no reconize the SIR-ALP1 tunner.
I am in the same situation.  I have had my sir-alp1 for 4 years and it simply stopped being recognized.  I called Alpine and they said they have no connection to this piece, it is made by "directed electronics" and I need to contact them.  A new one is around $120 whereas this one was 79 on sale in 2004.  I still have he installation guide/owner's manual for it and nowhere inside is there a number to call them.
Mar 08, 2009 | Sirius Satellite Radio Sirius SIR-ALP1...
Stuck on 255??WTF
you need to call sirius and activate the new unit the id number is on the bottom sir-alp1 unit or the box it came in
Jan 28, 2008 | Sirius Satellite Radio Sirius SIR-ALP1...
No sound
You most likly have the Data cable in one the other or both plugged into the wrong side, this just happened to me the other day with some Pioneer stuff and I had plugged the input outputs backwards. Everything came up as far as sources showing but now sound. That should fix you up Good luck
Oct 25, 2007 | Sirius Satellite Radio Sirius SIR-ALP1...
No talk radio
After the serial number of the unit is given to the support tech to enable service, it is your subscription that aloows to get those stations. It could be the unit as they said.
Jul 03, 2007 | Sirius Satellite Radio Sirius SIR-ALP1...
Jun 19, 2007 | Sirius Satellite Radio Sirius SIR-ALP1...
SIR-ALP1 problems
the only thing left is the head unit but that is not very likely. Go back to where you bought it from and have them give you new tuner box and anttenna. Sorry man But i put these in all day and its almost impossible for the head unit to be the prob
May 03, 2007 | Sirius Satellite Radio Sirius SIR-ALP1...
NO SIGNAL all of a sudden. Gone. Lost.
Hey adam, check that antenna wire! It's probably pulling out at the antenna/magnet end. Adam, I checked that and sure enough, it was pulling out. So I put on a new antenna and problem solved! Thanks Adam!
Mar 20, 2007 | Sirius Satellite Radio Sirius SIR-ALP1...
Sirius sir-pnr1
I'm having the same problem and all they reccommend is unplug the unit from the back for ~2 minutes and then plug it back in and power up.
Jan 06, 2007 | Sirius Satellite Radio Sirius SIR-PNR1...
Stays on even if HU (CDA-9833) is off
It is possible that the SIR unit stays powered as long as the red wire is powered, since it is normally connected to a switched source. To test this, disconnect the red wire or move it to a switched source (you could even add a switch on the wire and flip it manually). If the battery stays healthy after that, then the red wire being constantly powered is the problem. Otherwise, it is possible there is a problem with the Ai-NET cable connected to the SIR unit.
Sep 26, 2006 | Sirius Satellite Radio Sirius SIR-ALP1...
Sirius Satellite Radio Sirius SIR-ALP1 Satellite Radio Receiver Logo
118 people viewed this question
Top Sirius Satellite Radio Audio Players & Recorders Experts
John
John
Colin Stickland
Colin Stickland
Tom Chichester
Are you a Sirius Satellite Radio Audio Player and Recorder Expert? Answer questions, earn points and help others
