I am trying to burn something to a disc, and a note appears that maybe your disc is not formatted. So how can I format the DVD +RW disc?
  • 35 Answers
Depending on your burning software, there should be an option to format the disk, maybe under options or tools.
Posted on Mar 14, 2011
How to erase a dvd dics
dvd are read only.
dvd-r; dvd+r and dvd-rw are the re-writeable discs. mostly once only.
DVD Media Formats Explained
There are many different types of writable and rewritable DVD media on the market today. These formats include:
There are also "General Purpose" and "Authoring" discs. DO NOT confuse the "Authoring" media with the term for content development (making / editing what eventually goes on the DVD). The most common type of DVDR is the General Purpose type - if you do not know that you have an actual authoring recorder drive then you most likely have the general purpose type.
DVD-R is a write-once recordable format which allows excellent compatibility with both standalone DVD-video players and DVD-ROM drives. There are two main types of 4.7GB DVD-R discs: DVD-R for General Use and DVD-R for Authoring. Most consumer drives use the former cheaper General Use discs, while many higher end professional drives use Authoring discs. The correct media type appropriate for the drive must be used when burning. However, once burned, the discs should be able to be read in either drive type. (General Use DVD-Rs are designed to prevent backup of encrypted commercial DVDs).
DVD-RW uses rewritable discs which are rated at more than 1000 rewrites in ideal situations. Unfortunately, DVD-RW does not enjoy the same excellent compatibility with DVD-ROM drives and standalone DVD-Video players that DVD-R enjoys. Another drawback is that unlike DVD-RAM, one must generally erase a DVD-RW disc before reuse.
Most DVD-RW drives should also be able to record to DVD-R. However, the reverse is not true. Many older and some current DVD-R drives are not capable of writing to DVD-RW discs (but may be able to read burned DVD-RW discs). Some drives can also record to CD-R and CD-RW.
Currently DVD-RW and DVD-R are most popular in the multimedia market as well as the general consumer market. For instance the Apple SuperDrive, found in higher end Mac computers used in multimedia creation, is simply a DVD-R/DVD-RW (and CD-R/CD-RW) capable drive.
DVD+RW, like DVD-RW, is a rewritable 4.7GB DVD format. DVD+RW, however, in some ways offers some technical advantages, which for example include: lossless linking (which in turn more readily allows editing of a disc's contents after an initial write while maintaining integrity of the remaining data), currently slightly faster recording speeds, and optional future Mount Rainier drag-and-drop file access support (also known as DVD+MRW). However, DVD+RW does not have the very high compatibility with standalone DVD-video players and DVD-ROM drives that the DVD-R format enjoys. The level of compatibility of DVD+RW is said to be similar to that of DVD-RW. Also, DVD+RW does not currently have the same level of market acceptance as DVD-R.
DVD+R is a format that only was introduced to the public very recently (early 2002). DVD+R is a write-once 4.7GB format which promises to dramatically increase the compatibility with standalone DVD-Video players and DVD-ROM drives. Whether that claim is fulfilled remains to be seen, but initial reports have been very positive. It must be noted, however, that 1st generation DVD+RW drives do not support DVD+R burning, and it is likely that most cannot be upgraded to do so either. If one wishes to have DVD+R burning functionality, one must purchase a newer drive specifically designed to do so. DVD+R discs currently are somewhat more expensive than DVD-R discs, but prices will likely drop with time. Burners that write to these discs is the HPDVD100i and the DVD-Writer DVD200i drive
Thanks to www.AnandTech.com for this helpful information AnandTech Home
Mar 07, 2016 | Televison & Video
I own a Toshiba SD-3980SU2 DVD Video Player. I keep getting an Incorrect Disc comment, and bad comment. I an using DVD-RW discs. I have tried disconnecting and reconnecting the player.
You are probably using incorrect disc formats in this DVD player; try DVD+RW if you must use re-writables, or DVD-R (finalised in a recorder or burned on a PC). I doubt this model supports DVD-RW, so the problem wouldn't be with the player; it would be the formats of the discs you use.
Don't use DVD-RW discs in this player if it does not support that format.
Apr 22, 2011 | Toshiba SD-3980 DVD Player
How do I format a DVD+RW disc?
Hello and Welcome to FixYa!
Here are the instructions for formatting DVD+RW discs.
  • Locate the CD-ROM drive door on your computer. The location of the drive depends on the computer you have. You will see a small rectangular button on the door.
  • Press the button and the drive door should slightly open. Lightly pull the door open and insert the blank DVD-RW disc into the drive. Close the drive door and wait for the computer to detect the disc, which will trigger an "Auto Play" screen to flash on the desktop's taskbar. The screen will prompt you to choose an action you'd like to perform for the disc.
  • Click "Burn Files to Disc: Using Windows." This link will redirect you to your Windows Explorer disc burning application. You will be prompted to enter a title for the disc.
  • Enter the title of your choice in the form and click "Next." The last screen will ask if you'd like to continue with the formatting; click "Yes" to continue. The "Elapsed Time" screen will appear indicating how long the process will take. When the process is complete, another screen will automatically appear indicating the formatting process is complete.
  • Click "OK" to continue. Your Windows Explorer panel will appear. In the upper-left corner of the panel, you will see a horizontal menu bar with different options for the disc. Now your disc is formatted and you can begin burning files to your disc.
    Have a nice Day,
    Concerned.
  • Jan 28, 2011 | Roxio Easy CD & DVD Burning for PC
    My laptop will only burn DVD-RW but i only have DVD R dvds and i was wondering how can i get my latop to burn DVD R dvds?
    Hi there!
    What is the model of your laptop? Its is actually will depends on your laptop, but here's some infos about it, a DVD-R is a write-once format: once you've burned the data onto that DVD platter, the disk is forever frozen with that information. Add the "W" to that, and you'll find that DVD-RW can be erased or rewritten up to a thousand times. Seems kinda weird, but if you can do so, DVD-RW obviously has significant advantages over DVD-R. DVD-RAM was even more flexible, however, since it let you erase and rewrite sections of an existing DVD, something that you cannot do with DVD-RW.
    Moving to the plus side is where things get a bit confusing, because DVD+RW came before DVD+R. The plus formats have the same data storage capacity as the minus formats (4.7GB), but DVD+RW offers faster writing, better internal linking (a technical obscurity you don't have to worry about), and support for drag-and-drop desktop files, which makes it easy to compose the contents of a disk. DVD+R is a write-once format intended to be more compatible with more DVD players, though at this point it seems to be about even with DVD-R, which remains the most compatible computer-burned DVD format.
    In your case, since your drive is a DVD-RW, you're effectively limited to DVD-R and DVD-RW format discs. Stay away from any of the "plus" formats, as those won't work with your drive (and being newer, they cost more anyway). As to whether you want to use DVD-R or DVD-RW, that depends on what you want to use them for. DVD-R is a write-once format, just like CD-R, and you can't erase the data once it's written. DVD-RW is rewritable, so you can use it somewhat like a 4.7GB floppy disc, for all intents and purposes. In general, I suggest that you use DVD-R for archival purposes -- stuff that isn't going to change, and DVD-RW for more fluid data. DVD-RW discs are more expensive than DVD-R discs, so that may also influence your decision.
    How do you confirm what format your drive works with? One way, if you're on a Mac, is to use the System Profiler application. You'll find this useful utility in Applications -> Utilities. Launch it, then click on the "ATA" item on the list. If you have an internal DVD burner, you'll see something like what I get: "PIONEER DVD-RW DVD-106D". If it's an external DVD drive, you might find it in SCSI, USB or FireWire, depending on how you hook it up.
    As far as your second question, your data-burning application definitely has to be aware of the DVD format you want to use (i.e. DVD-R or DVD-RW in your case). For Windows, you can use GEAR for burning CDs, but you'd need to upgrade to GEAR Professional Edition to be able to burn both CDs and DVDs. Toast Titanium does burn DVD-R and DVD-RW so you should be set in that department.
    Hope it helps, if you need further, pls contact me.
    regards, fossildude
    Oct 15, 2010 | Computers & Internet
    How do I format a DVD-R disc so that I can use it again?
    You can't format a DVD-R disc. A DVD-R is a write-once format: once you've burned the data onto that DVD platter, the disk is forever frozen with that information.
    Please refer to the link below for more details on DVD formats:
    http://www.askdavetaylor.com/whats_the_difference_between_dvdr_dvdr_dvdrw_dvdrw_and_dvdram.html
    Generally, you can erase DVD-RW discs using any CD/DVD burning utility (e.g. Nero). They usually have an option to erase a disc.
    Nov 02, 2009 | Compaq Presario 5000 PC Desktop
    I have a Sony CRX320E CD/DVD unable to write a DVD
    CD-RW drives can only read all CD-rom and CD-RW formats and read DVD formats but cannot write to a DVD, if you want to write a DVDs you need to buy a DVD-RW burner which can burn all CD-formats
    Jan 16, 2009 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
    Format dvd rw
    if your noterbook comes with a dvd-rw drive, then you can format dvd-rw discs by opening your burning program like Nero and selecting the "erase disc" option
    Oct 22, 2008 | HP Pavilion dv6000z Notebook
    Camcorder won't format my DVD-RW disc
    try a different brand of dvd recordable disks? maybe? that would be my suggestion before anything else...hope it helps.
    Sincerely,
    Rabeka Jo
    May 15, 2008 | Video Cameras
    Computers & Internet Logo
    23 people viewed this question
    David Payne
    David Payne
