Question about Coolit Systems CoolIT VAN-R120 Vantage A.L.C. CPU Fan, Noise Reducer, Cooling Fan, Radiator
I have a 2000 cavalier my radiator cooling fan not working
  • 592 Answers
Hi.
Three things can cause this to happen.
Bad or corroded wires.
Faulty or damaged fan assembly.
Blown fuse between the fan and the power supply.
First, check over all the wires, make sure that they aren't damaged somehow.
Next, look over the fan itself, check to make sure that the fan hasn't been hit somehow, causing it to not work.
Next, check all the fuses, both the ones under the dash, as well as the ones under the hood on the fender.
Most people don't even realize that those other fuses are even there.
Also, check to see if there is an in-line fuse, or a fuse-able link that might be the cause of your fan not working.
I hope this helps steer you in the right direction, and good luck!
Posted on Mar 14, 2011
My 2000 chevy cavalier temperature gauge starts to starts to rise an if I give it more gas for a little while it goes down .I have put new water pump an thermostat did not fix the problem .
Try flushing the radiator. It may need cleaning. Also even if fan is working it may not be pulling enough air to cool radiator.
your radiator cap may need replacing if system isn't holding pressure.
Apr 29, 2017 | Cars & Trucks
Where can I get pictures of the fans in the engine compartment?
Radiator Cooling Fans - Professional Mechanics Online
www.2carpros.com/articles/how-an-electric-cooling-fan-works
Aug 1, 2015 - Step 1 - There are primarily two types of engine radiator cooling fan, electric and manual. A manual fan is connected to the engine drive pulleys ...
article How a fan clutch works
https://www.2carpros.com/articles/how-a-clutch-fan-works
Sep 3, 2015 - Step 1 - A fan clutch function is to engage the fan blade to the shaft when heated which is mounted to the front of the engine attached to the ...
Improving an Engine Cooling Fan Using Design for Six Sigma
www.mathworks.com/.../improving-an-engine-cooling-fan-u...
MathWorksA key component of an engine's cooling system is the cooling fan, which ... a shroud to direct airflow through the radiator (image courtesy of Novak Conversions).
Dec 21, 2015 | 1996 Chevrolet Cavalier
Spark plug
Well there is no cooling fan spark plug. You do have a temp sensor that tells the computer what the coolant temp is. And that could be the problem. But you should have a check engine light on if it is.
Your radiator fan motor could have failed, or the relay that powers it. Jumping the relay would tell you if the fan works.
Jul 01, 2013 | 2000 Chevrolet Cavalier
I need to find the fuse or relay for the radiator/cooling fan on my 1993 chevy cavalier
simple on the cavalier go to the relay box section open it and there will be a symbol of a fan that is the cooling fan for radiator okay under the hood right front section
Apr 22, 2011 | Chevrolet Cavalier Cars & Trucks
If the radiator cooling fan motor does not work. Would it keep the A/C from working.
yes , it sure can , i believe that fan works for the engine
cooling and a/c condensor cooler as well.
If it doesnt work , you risk dammaging your motor and
a/c compressor as well.
Aug 20, 2010 | 2000 Chevrolet Cavalier
Cooling fan not turning on
Check power to and operation of the cooling fan relay. (location shown in pic) If good, then test for power to cooling fan motor. If present & motor has good ground then it's a bad fan motor. Pic is for vehicle with 2.2L engine.
May 24, 2010 | 2000 Chevrolet Cavalier
Over heating and radiator leaks. overheats after sitting at idle for around ten minutes. its a 5 speed manual transmission 2000 chevy 2 dr cavalier.
if there is a leak then of course you will get overheating from the engine..Be very careful as this can cause permanent damage to the head gasket and it will cost a lot more to fix..First try to stop this leak before you proceed further.
Dec 08, 2009 | 2000 Chevrolet Cavalier
Engine light is on the cooling fan dont come on
it most likely is telling you your fan is not working and you are in danger of overheating. some systems need a full radiator to work so make sure the radiator is full make sure it is not warm when you check this let it cool down before removing cap. if fan still isn't working check fuses for fan. you may still have to take it in to check engine light some auto parts stores can check it for you and if the problem is fixed you still may need a scan to eliminate the code or shut off the light.
Nov 25, 2009 | 2000 Chevrolet Cavalier
I need help on replacing a radiator on my 2000 chevy cavalier
Disconnect negative battery cable. If you have Delco Loc or Theftlock audio system, turn off feature which reqiers disconnecting the battery. Make sure engine is cool and turn cap slowly to release pressure. Drain cooling system. Disable airbag system by disconnecting the electrical connector from the airbag system's forward discriminating sensor located on the hood latch support bracket. Remove the cooling fan and shroud assembly. Next loosen clamps for upper and lower hoses then Disconect from radiator. Disconect the coolant reservoir inlet and outlet hoses from radiator. You will need a couple drain pans and rags. If your car has an automatic transaxle, Disconect it from the left side tank of the radiator. Use a back-up wrench on each welded nut while loosening the cooler fitting. Be careful not to bend or brake any lines when loosening the fittings. If they are tight spry some WD-40 and wait about 10 mins. Plug the ends of the disconected lines to prevent leakage. Remove right and left head lamp assembiles. Remove hood latch support brakets from radiator crossmember. Remove condenser mounting bolts. Remove the radiator upper mounting bolts located at the upper left and right ends of radiator's side tanks. Now carefully remove radiator. To install just follow directions backwards. I hope this helped.
May 08, 2009 | 2000 Chevrolet Cavalier
Coolit Systems CoolIT VAN-R120 Vantage A.L.C. CPU Fan, Noise Reducer, Cooling Fan, Radiator Logo
271 people viewed this question
Top Coolit Systems Computers & Internet Experts
David Payne
David Payne
Are you a Coolit Systems Computer and Internet Expert? Answer questions, earn points and help others
