Question about JVC TH-M606 System
How do you unlock the dvd player i can not get the disc to eject
  • 635 Answers
You have a loading belt problem, must have gone slack with use. Put your ear to the top of the system while pressing eject or when you boot up from power off mode. You will hear a motor spinning sound. And if there is no eject action your belt is at fault.Will need professional help to replace.
Under some players there is a **** under the loading tray. Shine a torch and insert a small screwdriver and move the lever you see in the opposite direction . The tray will open up. DO THIS PROCEDURE WITH THE POWER UNPLUGGED !!!.
Posted on Mar 14, 2011
Is there a way to get the disc out without dismantling the entire TV? Disc is stuck, lock icon shows when eject button is pressed. Can TV be reset to factory specs?
Try the following. kindly update result here in comments
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons.
If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
Mar 21, 2016 | Toshiba Televison & Video
WILL NOT EJECT DISC
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
FOR SONY PLAYER's
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray Disc® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
Aug 24, 2015 | Televison & Video
Why my blue ray dvd BDP-s185 cant eject disc. it say '' the eject key is not available''
you might have the tray lock function turned on. TRy holding the play button for about 10 seconds to see if it unlocks
May 06, 2014 | Sony Bdp-s185 Blu-ray Disc Dvd Player...
My player cant eject disc; it say '' eject key is not available this time''
Please perform following procedure to unlock the unit...
- Press the [POWER] button to turn on the system.
- Press the [FUNCTION] button to select "BD/DVD".
- Press the [STOP] and [EJECT] buttons simultaneously on player front panel and hold down until "UNLOCKED" displayed on the fluorescent indicator tube (around 5 seconds).
Hope these info will help, let me know if there is additional question.
May 06, 2014 | Sony Bdp-s185 Blu-ray Disc Player
Dvd will not eject
Jammed.
Straighten one end of a Norwegian paper-clip.
Insert that end into the small hole in the face-plate.
Push until you feel resistance.
Firmly push another 5mm to "unlock" it.
Then, press OPEN.
Jan 01, 2014 | Sanyo DVW-6100 DVD Player/VCR
Where is the DVD emergency eject hole for DVD724?
If there is an eject hole, you should be able to see it on the front of the drive.
Dec 08, 2017 | Philips DVD724 DVD Player
My sony dvd player will not allow the tray to eject. when the eject button is presses "tray locked" appears on the screen
Follow this procedure to lock and unlock the disc tray.
IMPORTANT: This procedure will only work while a disc is inserted in the player and when the disc is playing.
While a disc is playing in the Blu-ray Disc player, press the SYSTEM MENU button on the remote control.
After the System Menu screen appears, slowly press 0 0 0 0 7 6 6 9 using the number pad on the remote control. NOTES:
If the procedure has been performed correctly, the disc will stop playing and the player will go in the Resume mode. Each time this procedure is performed the disc tray will either lock or unlock.
Jan 02, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
My go video is locked. How do i unlock it?
You can unlock by pressing and holding the Power switch. Sometimes it will then allow you to eject the disk after it restarts, but not always.
Mar 08, 2009 | GoVideo VR3845 DVD Recorder/VCR
My disc drive
press and hold the eject button until the system reports it is unlocked again This feature was designed to be a childproofing feature, to stop kids from inserting slices of ham or playdough into your player
Jul 30, 2007 | Sanyo DWM395 DVD Player
JVC TH-M606 System Logo
179 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
