Question about Toshiba Satellite A105 Notebook
My laptop can not start up. The power light is off. The power adapter is ok. What's wrong with may laptop?
  • Ben Williams
    Ben Williams Mar 14, 2011
    any sounds from fans or hard drives spinning?
  • nugroho_anto Mar 14, 2011
    no sounds either from fans or hard drives
  • 340 Answers
There is any indication on power light when u insert your battery. check that also check yours laptop adapter pin there is any malfunction of pin in the laptop
Posted on Mar 14, 2011
Nc6000 will not power on and i have repaired it once.after a month the problem comes back,WHAT MAY BE WRONG WITH MY LAPTOP?PLSSSSSS I DONT MONEY TO KEEP REPAIRING IT.
When you connect the power adapter into the laptop, does the power LED light up If not then
The battery adapter or the adapters power lead or the laptops power socket could be faulty.
Check power adapters DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power battery charging LED light and wriggle the power plug in the laptops power socket. If the power battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
May 03, 2013 | Computers & Internet
Screen of lenovo G475 does not want to light up. Laptop does start up
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Sep 04, 2012 | Lenovo Computers & Internet
Hp 4510s not charging
Sep 01, 2012 | HEWLETT-PACKARD HP ProBook 4510s Notebook
My click botton to take the picture doesnt work, idk how to actually take the picture, am i doing something wrong??
Aug 14, 2012 | ASUS Computers & Internet
Compaq 610 laptop will not power up, any fix?
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Aug 05, 2012 | HEWLETT-PACKARD Compaq 610 Notebook
Can not be powered up, adaptor is alright but the laptop cannot be powered. battery was removed but the power still can't come on.
Hi
Try to remove the battery, hold on power button for about 50-60seconds, then plug-in the charger and turn the laptop ON, see what happens.
If it was OK, then plug-in the battery and try to start your laptop.
If it was OK, Congratulations.
If not, so it's bad news, the battery is dead.
Please tell us your results
Good Luck
May 18, 2011 | Acer Computers & Internet
I donot have any light or power when I started my LAptop Power jack is ok
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Apr 01, 2011 | Acer Aspire 5500 5570-2609 Laptop
Worked great for 6 months, now it doesnt start at all, if it is start after 2 minutes it will be shutdown and no charge light is glowing when it is off charge light is glowing but no battery back up. If...
FixYa does not carry out any repairs only advice.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Aug 11, 2010 | Acer Computers & Internet
No power
suspect either dc adapter or dc jack, bad pin. easy fix
Feb 11, 2010 | 3Com Computers & Internet
Laptop will not power up, ac adapter issue, battery, or someting else?
You can try taking your battery off the laptop and just have the power supply hooked up. If it will start up like that, your battery or the charging portion of your motherboard is probably bad and you should have a technician look at it. If it doesn't start, your power supply is more than likely bad and you can order a new one from eBay. Also check to see if there are any lights on the computer or power supply. If the laptop has lights on it is almost definitely a laptop issue, if nothing is on (including the light, if there is one, on the adapter) then it's probably a adapter problem and your battery is dead. You could try getting a new one on eBay or a universal adapter in a store. That way if the adapter turns out to be ok you can return the universal adapter.
Jan 24, 2010 | Toshiba Satellite M45-S269 Notebook
Toshiba Satellite A105 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
