What is the voltage for the ac adapter for aopen ms805 speakers treker88@gmail.com
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
The most likely DC voltage for that system is either 10V or 12V. You can actually test it safely by starting from 5V and work up to 9, 10, then 12 until the lowest will work. It should also be shown on the output of your AC Adapter
Posted on Mar 14, 2011
I need to know the voltage of the speaker for ac adapter matching
The speakers may have a label that has the voltage printed on it.
You can check the Bose WEB site for the specs of your model speakers. You need to know the polarity of the connector, if you get it wrong you could destroy your speakers.
You may need to contact Bose support if the specs do not help you.
Jun 14, 2012 | Bose Companion 2 Computer Speakers
What voltage and polarity do the ACS-5 speakers require?
Computers always use DC voltage. Computer speakers receive DC voltage from the computer.
DC voltage has a Positive and Negative polarity.
In the power jack of the speaker, the Center pin is the Positive connection. The outer shell is the Negative connection.
Center hole of the DC adapter plug - Positive.
Outer shell of the DC adapter plug - Negative
Voltage 5 Volts DC.
In case you need it,
http://support.dell.com/support/edocs/dta/acs5/
Nov 29, 2010 | Computers & Internet
Aopen ms-805 s/n 10800730 RWE1 What DC Voltage
A/C Adapter Output: 120V AC 500mA UL Approved
Nov 13, 2010 | AOpen MS-805 Computer Speakers
I need the input voltage for ac adapter for my GE 98903 2.1 Pro Speaker System
The AC adapter input voltage is 120 Volts AC as it plugs into a wall outlet. I suspect you want to know the output voltage of the transformer. If you have the old transformer the output voltage is listed on the transformer top. May be hard to read but it is there. This system is also sold under then brand name Jasco. The Input voltage of the system should also be printed next to the power connection or on the speaker itself.
Nov 11, 2009 | Cars & Trucks
Ac adapter for my GE speaker system
This is an old type of PC speaker system. Can it be powered by batteries. How many batteries needed??
Multiply the number of batteries by 1.5 volts and you
get the voltage rating of your needed adapter. You can also take a look at the back of these GE speakers. Maybe you can find the voltage rating.
You may also consider buying a new set of PC speaker that can be plug direct to your power outlet.
You can buy it at a cost slightly higher than your
needed adapter.
Nov 11, 2009 | Computers & Internet
Adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Oct 17, 2009 | Audio Players & Recorders
Output voltage of 120volt AC brick & approx dimensions
Any PC speakers that have a AC plug pak attached can probably use 12V simply cut off the AC plug packs lead that goes to the speakers, and connect up 12V ya should be good to go.. some connect with a Phono Plug, and usually the Outer is Minus Voltage and the Centre is Plus Voltage .. they are also generally Diode protected so a reversal shouldn't cause too many probs... GL
Jul 29, 2008 | AOpen MA-691 Computer Speakers
Speakers Model #: MS-608Pro Power supply
AC 9V/400mA
Specs at:
http://usa.aopen.com/products_detail.aspx?auno=1050
Jul 27, 2008 | AOpen MS-608PRO Computer Speakers
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
