Question about Home
The pump won't shut off. A new on/off switch, perhaps? And if so, how do i get the old one out?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
Yes most likely need a new switch. The switch should be screwed in from under the bottom of the switch which means you will need to have a way to access it.
Posted on Mar 14, 2011
Pump shuts off at 20psi
you need a new pressure switch or adjust the old one for a higher limit ,
Dec 30, 2015 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Pump won't shut-ff
Hi Ron...
Check your float switch....sometimes they can get stuck to cause this problem of not shutting down after draining the orginal water.
Take the float switch and move it up and down...this may help to clear the stuck switch inside of the float
Bud
Apr 24, 2013 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Pool filter pump won't shut off.
I'm assuming it continues to run when you switch the system to "service" mode. You probably have a relay stuck shut. Unless you are very comfortable with working with high voltage it's best to get a tech out to verify the problem and switch out the relay. If you are okay with it the replacement isn't very difficult. You'll have 4 or 6 wires to move from the old relay to the new one, and switch out the small black and red paired wires that go from the relay to the control board. Make certain that your breaker is off while changing it out.
Apr 12, 2013 | Water Pik Aqualink Rs4 Package - Pool and...
2002 olds alero was running then would not start back up.New fuel filter and the fuel pump is fine,but it turns over,won't start
Have you reset the fuel pump switch...bled the lines? Try starting fluid for a few times then look at these issues.
Dec 30, 2012 | 2002 Oldsmobile Alero
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Dec 09, 2011 | Maytag Washing Machines
1993 chevy caprice classic wagon 5.0 8 cylinder hads a problem with engine shutting off with in seconds after start ! i did check for vapor lock in gas line, had new spark plugs replace, new fule...
Think the oil pressure switch keeps the fuel pump running once started. Suggest replacing Oil pressure switch. And no it won't effect oil pressure reading when it goes bad. The switch is a safety device. When you roll it over and the oil pressure drops the switch cuts off the fuel pump. Neat huh? Need some good feedback Thanks!
Jul 21, 2011 | 1993 Chevrolet Caprice
We have a flotec well pump, less than a year old. The pump is working fine, and is primed. The switch doesn't appear to be working. Is this a difficult item to replace? Home Depot sells the pump and...
To replace the switch, shut off power, remove wires noting all wire locations.
You may have to relieve pressure in the system by using water until the surge tank is empty.
I'm not sure about that.
You do have to either remove the switch from the piping by unscrewing it or remove the piping from the switch by removing the connector and unscrewing the connector from the switch.
Assembly is the reverse. You should use teflon tape of dope on the screw connection below the switch.
The procedure should take about a half hour but you won't have any water during this time.
Gary
Jul 21, 2011 | Flotec TC2151 P2 Well Pump Pressure Switch
Alot of rain flooded the area arond the pump twice which shut off power.now motor is quit noisy?Whaddyathink??
the water has damaged the bearings, it's only a matter of time before the bearings get louder or seize all together. You can have the bearings replaced or get a new motor installed. A bearing replacement is 2/3 the cost of a new motor and the rest of the components are still old and perhaps damaged from the flood. Your call, I'd go for a new motor.
Sep 15, 2010 | Hayward 1 Hp Max - Flo Swimming Pool Pump
Shutting down
Try replacing the air filter.
Dec 21, 2009 | 2003 Oldsmobile Alero
Home Logo
21 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
