Question about Microsoft Windows XP Professional
I have bought microsoft office home and student 2010 for my windows xl my microsoft outlook keeps coming back saying it is unregistered i have put the id code in 3 times it wont accept and now saying its expired. I cannot delete microsoft.net frame work 2.0 and 3.0 service packs my comp tells me both have fatal error. please help me fix my problem. I am an oldie and still trying to learn
  • randb281 Mar 14, 2011
    thanks for your email my comp is a windows XP not professional So sorry to confuse you I tried to uninstall microsoft net frame work 2.0 & 3.0. to free up space but unable to do so.What is a fatal error. I have so much rubbish on my comp and not much room left even after defrag.thus slowing everything down. I live in a remote area and satelit is my only option. many thanks
  • randb281 Mar 16, 2011
    yes many thanks for being so helpful with microsoft office this oldie is very greatful
  • 415 Answers
Do you have the right version for your computer? for the operating system. I haven't checked but it probably requires xp or newer to run.
Double check to make sure it was the right number you put in. The numbers in the box on a stick or a page.
Check your windows updates first and get those up to date. It might have to reinstall ms netframe etc.
Did you delete it or uninstall it? In the box is an 800 number for microsoft. You will need to call them and tell them the number is expired, that you tried installing too many times etc and they will give you a new one that works.
Posted on Mar 14, 2011
  • mszona Mar 15, 2011
    You need microsoft net frame work to work in the newer windows versions. You may need to reinstall it. Again check to see what windows updates you need and get them.
    Before removing something from the system you should use google and check what it is you're deleting first to make sure it's not something necessary. Too often people accidentally remove critical parts of windows and then get errors.
    If you are out of space on the hard drive first thing to look at doing is getting rid of temp files. Go under Internet Explorer, TOOLS, INTERNET OPTIONS and delete those files. Also go under SETTINGS and see how much space it is using to save temp files. The lower the number the more space you'll conserve on the harddrive, but the less pages it will save as well. If you don't go to the same page often then you won't need much space reserved.
    You may still need to call the MS number and get a new registration number from them for Office.
    Guru:
  • 767 Answers
Firstly don't delete those Microsoft dot net frameworks, they are vital updates needed by your system. If you want to free up a little space I suggest you run a Disk Cleanup.
Disk cleanup
The Disk Cleanup tool helps you free up disk space by searching your disk for unwanted files and temporary files that you can safely delete without problems. It can remove all of the following:
Files in the Recycle Bin.
Temporary Internet files.
Temporary Windows files located in the Temporary files folder.
Optional Windows components that you are not using.
Installed programs that you no longer use or wish to use.
To launch the Disk Cleanup tool via Start menu go to Start > All Programs > Accessories > System Tools
A dialogue window should now appear enabling you to select the drive you want to clean up. Select the required drive and click OK.
The specified drive will be examined and the amount of space you can potentially free up is calculated and displayed.
The results, showing the amount of space that can be recovered by deleting files a secific type of file that is not needed is then displayed on the Disk Cleanup I have bought microsoft office - slasher_x_25.gifow.
Select the files and click Ok to remove these un-needed files.
Now that a Disk Cleanup has been performed your hard drive should perform slightly faster and have less clutter lying around.
I suggest you perform the disk cleanup tool every once in a while to ensure that your hard drive has a greater lifespan, never has any need to crash or come up with errors caused by unnecessary files, greater performance and increased productivity especially where it is needed most, in the workplace.
From what you have said the Microsoft Outlook 2010 software is telling you that your registration key has expired. All you have to do is contact Microsoft's support center and provide them with proof of purchase. They should then supply you with a new key.
To contact them go here.
Type in Outlook 2010 into the Quick product finder box.
Then select Outlook 2010 from the drop down list.
Then follow the questions.
What to do after I put in my product key for Microsoft Office Home and Student 2010 and configuration stops midway?
The first port of call should always be Microsoft support. They see all the errors that their product can possibly generate,so you should start there too. They even have handy fixit program's to help. Go to http://bit.ly/1p8knEg and see if your error is mentioned there. Then follow the troubleshooting steps. Good luck!
Sep 10, 2014 | Microsoft Office Home and Student 2010
Had a problem with my installation of Home & Student 2010 which upgraded everything to 2010. I have a product key for Office Home & Student and now want to install my upgrade for word, excell from...
Just intall office 2010 because outlook 2007 has been replaced by windows live mail
here is the Download to windows live mail
http://explore.live.com/windows-live-mail?os=other
Jun 05, 2011 | Microsoft Computers & Internet
I took my PC in for repairs and it came back with a new microsoft windows office student 2007 which is expired and I cannot use my PC. I have my own Windows XP Professional but will not load as it comes up...
Windows and Office are 2 separate products. Reinstalling Windows XP Professional will not get you Office. If you went out and bought Office Home and Student 2007, you should have the box still that has your key on the cardboard insert. Otherwise, you probably had the trial. You can reinstall the trial if you like for another 30-90 days, but I would recommend you go to a big box store (best buy, staples, etc) and buy Office Home and Student 2010 for about $125. That gets you Word, Excel, and PowerPoint. If you need Outlook for email, you need to get the Home and Business 2010 edition for a little bit more.
May 21, 2011 | Microsoft Computers & Internet
Download microsoft 2007 student ediction dosnt have product key so so looking for a huck key so i can pass my crouse please help need today
Hi, why just download 2007.. why dont u go to this link and download the full version of MS-Office 2010 Professional.. Free of cost.. with lifetime subscription.. the link is http://www.microsoft.com/office/2010/en/download-office-professional-plus/default.aspx this one comes with all the professional content.. comes with like word.. excel.. PPT.. one note.. outlook and much more.. --------------------------------- and their Home and office product is here below http://www.microsoft.com/office/2010/en/default.aspx this one comes with all the home and home office content.. like word.. excel.. PPT.. one note.. outlook
All you need to do is create an account with them.. i.e., a windows live ID .. and it will provide u with a Serial Key also.. Store that and download it online..
ITS FREE AND HAS A LIFETIME SUBSCRIPTION.. have fun regards..
May 05, 2010 | Computers & Internet
Outlook will not activate
It is because MS outlook is not a part of the ms office home and student 2007 package. That's the reason why your outlook is saying trial and its not working.
Mar 20, 2010 | Microsoft Office Outlook 2007: Windows
Student office 7 verson I bought doesen't have outlook i now don't have any e-maiol account and my data has gone. contacts and current mail & outlook
The student versions do not have Outlook or Access with them. Try searching this site under Microsoft Office. http://download-at-now.blogspot.com/ You might find something that would help you out.
May 02, 2009 | Microsoft Office Home and Student 2007...
I have microsoft home and student and I can't find outlook.
Hi Steven,
This fact is annoying but the home and student version of microsoft office does not have outlook installed with it.
you will either have to download the trial pack or buy a different version of the software (standard or professional ).
you can also use windows mail provided with vista..
www.microsoft.com/outlook
Regards,
Anup
Apr 06, 2009 | Microsoft Office Home and Student 2007...
After downloading a trail we have problems with outlook express
The version you first downloaded was a trial version. After 60 days, it stops working. Also during the 60 day trial, the program keeps asking you for the product key because they want you to purchase that version. If you do, you will only need to purchase a product to put in and away you go. The program is already installed from the 60sday trial.
The Standard version comes with Outlook, not Outlook express. The Student & Home version does not come with outlook. You can download outlook express 6.0 at this link: http://www.tucows.com/preview/194179 and install for free.
Apr 04, 2009 | Microsoft Office Professional 2007 Full...
Microsoft Windows XP Professional Logo
115 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
