Question about Apple iPhone Smartphone
The apple appears when turned on but quickly disappears. it fell in te toliet for about 3 seconds.how can i fix it?
  • 53 Answers
If it was working fine before it fell in the toilet, it probably has water damage. Take it to an Apple Store or contact Apple for tech support.
Regards,
Matt
Posted on Mar 14, 2011
Ipad 2 was stuck on Apple logo. Managed to finally get it turned off. Logo appears again when turned on but frozen. Can't reboot. Help!
Depress and Hold your home button and power at same time . This will or should take a few seconds but Keep holding until you see the apple icon . When you see it let off both at same time . After a minute or more it will disappear . After it disappears wait a couple 3,4,5, seconds and you should be able to press the home button and your home page should display .
Sep 21, 2016 | Apple iPad 2 Wifi 16GB
Ipod Touch wont turn on
Your iPod has been working fine and all of a sudden it won't turn on. Not sure why? Before you rush to your nearest Apple store, try these easy-to-use, at-home solutions for fixing your iPod.
Check the Hold switch to see if it is off. Located on the top or the bottom of the iPod, when it is in the "on" position you will see an orange patch of color. Slide the switch until the orange coloring disappears. Try to turn on the iPod. Make sure the battery is fully charged by connecting your iPod to your computer's built-in FireWire or USB port or into an electrical outlet using your Apple iPod power adapter. Note: iPods without a click wheel cannot be charged using a USB port. After your battery is fully charged, try to turn on the iPod. Reset your iPod. iPod Shuffle: Disconnect iPod Shuffle from the computer if connected. Move the power switch to the off position. Wait five seconds. Move the switch to the play in order or the shuffle position. iPod Touch: Press and hold the Sleep/Wake and Home buttons together for at least 10 seconds until the Apple logo appears. iPod Nano (all generations), iPod Classic, iPod Mini: Turn the Hold switch on and off. Press and hold the Menu and Select buttons at the same time until the Apple logo appears, making sure to not touch any part of the click wheel. This should take about six to eight seconds and may need to be repeated. If your iPod still won't turn on, check the following: Make sure the iPod is the only device in your FireWire or USB chain. Disconnect everything but the mouse, keyboard and iPod, and try again. Double check that you are using the FireWire or USB cable that came with your iPod, and that it is in good condition. Try the built-in port of a different computer.
iPod won't turn on
http://support.apple.com/kb/ts1383
Mar 01, 2013 | Apple iPod touch
How do i fix my iphone? its stuck on the apple screen
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least ten seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 14, 2011 | Apple iPhone Smartphone
Screen has frozen and I can't get anything to work!
In order to solve this problem all you need to do is the following: 1) Turn the the hold switch on 2) Turn the the hold switch off 3) Hold down the Menu and Select buttons at the same time 4) Wait 8 to 10 seconds or until the Apple logo appears 5) Repeat steps 1-4 if necessary
Hope this helps, Joe
Feb 19, 2010 | Apple iPod nano
My ipod touch fell in the toliet and now it turns on but wont respond to my touch. how can i fix this?
you will have to send it to the shop for repair... if you are pay as you go it could be under warrenty or if your pay monthly you shouldnt have to pay
Jan 22, 2010 | Apple iPod touch
Apple icon is all that comes up.
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Aug 12, 2009 | Apple iPhone Smartphone
MOTO Q dropped in toliet (USA)
open u mobile wash it with pcb cleaner or Petrol than heat it with SMD. if any proble contact me.
sr99mobiles@yahoo.co.in
Nov 21, 2007 | LG VX6000
Apple iPhone Smartphone Logo
37 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
