Question about GE JKS05 Electric Single Oven
"locked door" My GE bulit in electric oven keeps flashing "locked door" and stops baking and will turn back on until completely cooled down. Can you tell me how to fix it?
    Problem Solver:
  • 16 Answers
Check temp sensor
Posted on Mar 08, 2009
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    Top oven control panel malfunction. While broiling then switching to bake, door began to lock, I open door before it could complete lock, now "door locked" keeps flashing & I can't...
    Hi, One thing you can try is turn off and pull out plug. If you can't get at plug turn off breaker down on pannel for 1 hour and them turn back on. if that does not fix it call repair man. pc board maybe at fault.
    Jun 11, 2011 | Kenmore 41389 Electric Double Oven
    Oven door is locked and won't open
    oven door locked during cleaning then would not unlock after cooling
    Jan 19, 2010 | GE JKP86 Electric Double Oven
    My GE drop electric range will not turn on the self cleaning unit. I set the time and push start and it flashes clean oven, door lock, however, the door will not lock. I hear a clicking sounds, it beeps...
    You will need to press the stop/cancel button, next press the self clean button, you do not have to set the time the cleaning cycle takes approx 3-1/2 to 4 hours and the cool down takes another 45 minutes to one hour, it will clean and cool down and you do not need to interrupt this cycle, it will let you know when it is complete.
    Nov 14, 2009 | GE Profile JTP18 Electric Single Oven
    I have a ge electric built in single oven which had a grease fire
    Its possible that the wiring harness to the door switch got a little too hot and have shorted. What I would do before I call a technician is to unplug the oven or turn the power off to it for a few minutes and then plug it back in to reset the control board. If you still get the error, I would recommend calling a service professional.
    Apr 03, 2009 | GE JTP20 Electric Single Oven
    GE Elec oven JT952-30" blinks the "lock" after self-clean
    Try unplugging power cord or trip circuit breaker, to cut the power to the appliance, then wait one or towo hours for the oven to cool down completely.
    If the door stays locked, then there is a fault, probably a faulty temp probe that had blown because of high temperatures generated on self cleaning, or a defective control assembly. In that case you will need to call a technician to take apart the oven and fix the fault.
    Enter model number here to find assembly diagrams and parts.
    Jan 02, 2009 | GE Profile JT952 Electric Double Oven
    DOOR Locked Flashing
    check the interlock switch, can be some object has stuck to it...
    Sep 06, 2008 | GE Profile JTP18 Electric Single Oven
    Oven fan keeps running even after off and door open
    3 to 4 hours is a long time. Get to the fans (behind the control panel) and check the screens for dust. Chances are the screens are clogged with dust and need to be cleaned so the fans can move air for cooling better. I had this problem on my GE JTP14, and after cleaning just one fan it can keep up with cooling the electronic area while the oven is running. It runs much less often.
    Safety first! cut the breaker before removing anything with a nice conductive screwdriver! Hope this helps!
    Jan 01, 2008 | GE Profile JTP18 Electric Single Oven
    Ge oven problem
    door lock is not work check wires motor and switchs.. you may have to replace the door lock
    Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
    Re.probe and bake
    I had the same problem and pulled off the contorl panel and removed the ribbion looking thing. You might have to do this a few times and wiggle it a little. It took me about 4 trys to get it to stop. also you can lock the control panel and the beeping will stop...this was my temp fix until I figured out how to get the control panel off and what to do.
    Oct 11, 2007 | GE Profile JTP56 Electric Double Oven
    GE JKS05 Electric Single Oven Logo
    109 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
