Question about Iomega Prestige 1 TB USB 20 Hard Drive
Have plugged the external hdrive into 4 different computers but no computer will recognise the devise light are on everything is plugged in . Brand new h drive only opened today as it was bought as a gift
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
You might need to double check to make sure this is made for a Mac, PC, or Both. You might need to have it formated from the Disk Management (assuming you are using a Windows computer) so your computer recognizes the hard drive.
Here is a link.
http://windows.microsoft.com/en-US/windows-vista/Create-and-format-a-hard-disk-partition
If this does not work then it is likely you have a faulty unit and should ask for a replacement.
Posted on Mar 14, 2011
Can't get my computers to recongize my Ipod Touch (Gen 4)
connect usb cable with computer and ipad keep holding home button until computer recognise ipod then release it
Apr 06, 2014 | Apple Ipod Touch 4th Generation
No drive letter is assigned to a USB mass storage devise. it is recognised in devises and says it is working properly. A thumb drive works OK and is assesable. This as a 20GB external HD in a Centre X 2...
Well, you can manually assign the drive letter for the Drive. To do this, follow the instructions below:
Right-Click "My Computer" > "Manage" > on the left pane "Disk Management" > on the right pane check out which one is the drive that's not available with it's drive name, after it's located, right-click on the drive and select "Change Drive Letter and Paths" or "Assign Drive Letter", give any letter you want to assign and "Ok". Close the window and open My Computer, you'll be able to see the drive with the drive letter you just assigned. If it doesn't show up, restart your computer while the external hard drive is still connected to the system's usb port.
It's also important to try it on different usb ports or on another system to make sure there's not internal problem or connector/cable problem with it.
Good luck.
Thanks for using FixYa.
Aug 10, 2010 | EliteGroup ECS P4VXASD2 VIA P4X266A...
I have a Maxtor One Touch 4 Mini 120GB External USB 2.0 Hard Drive, I've previously used it multiple times in the past, importing AND exporting data. For some reason though after using it on one computer...
try testing it in another computer. if you have the same problem. then there might be an issue with the drive.
to recover your data. unplug external drive from the computer and open the external hard drive case. remove the hard drive inside. with you computer off and disconnected from the wall open the case to your computer. look and see how the hard drive inside is connected in your computer and add the external the same way. you might need a cable to connect it. you can simply disconnect the cdrom and plug the hard drive instead. make sure the external hard drive is not touching any electronics inside the pc. now you can turn on the computer. give the computer a minute to detect the new drive and assign a drive letter. navigate to my computer and select the newly added hard drive. copy and paste all the data you want to save. after everything has been backed up format the external drive to clear any bugs that may be causing it to be recognised in its case.
when finished remove the hard drive, plug in the cdrom, close the case, plug back into the wall, and return external drive to its case.
Feb 28, 2017 | Maxtor OneTouch 4 Mini 120GB External USB...
1 tb western digital hard drive is not being recognised by my com
Try plugging the external Hard Drive to a different computer and see if it would recognize the device. If not, go the store where you purchased the external hard drive to have it replaced since it is still under warranty.
Mar 26, 2010 | Western Digital My Book Essential 1TB...
Usb devise not recognised
You probably damaged the drive from sudden disconnection of the signal line. I would suggest trying it on one other computer before considering it trashed.
Jun 08, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
When I plug in the HDD16 into the USB my computer says devise is not recognised
Please clean the usb cable. Use a cotton swab with Alcohol on it. (Not dripping). You may need to use a few. If that fails to help, try another usb device in your PC & check if the PC can see that device. The cable could be defective. The FAT on the drive could have been damaged or the drives file system could be corrupt. The usb port could be loose from plugging in & out. If your OS is Vista that can be the problem. Try a Pc running XP.
Please check these links for more options.
http://support.microsoft.com/kb/871233 Try this as well.
http://www.hat.net/geeky/node/221
Post back & we'll go from there!
please vote after everything...
Feb 07, 2008 | Toshiba 120GB (MK1234GAX) 5400rpm 8MB...
Wd 120gb External no longer recognised by my PC
hi there
have you tried looking at the device manager?
you can also try transfering it to different usb ports.
hope this helps
Feb 04, 2008 | Western Digital Passport WDXML800UE...
Computer will not recognise camera.
hey,
have you tryed to plug camera into another computer, maybe a windows?
have you tryed to use another usb cable?
also connector in camera can have bad soldering
check this movie
hope this help you get closer to solution
;) /michael
why pay when you can play
Dec 19, 2007 | Cameras
Iomega Prestige 1 TB USB 20 Hard Drive Logo
81 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
