Fat alloc error in micro sd memory card problem: and does not full format
    Scholar:
  • 114 Answers
Dear Amir,
Memory cards are just a bit better than old Floppy drives according to me they get struck by some viruses or may get corrupted when you pull it out with power on or you can say without the wizard safely remove hardware.
your SD card seems to be corrupted.
Gagan
Posted on Mar 14, 2011
    Problem Solver:
  • 14 Answers
Sounds like your sd card is damaged. Try to get a warranty replacement. If it is out of warranty, there is nothing to be done.
Cange file system RAW in FAT
SD cards take on a multitude of formats.
For a card that needs to work on operating systems such as Windows 98, ME or XP Home Edition, it must be converted to a File Allocation Table (FAT) format.
Also, some devices, such as a GPS unit or MP3 player, may require a FAT-formatted card.
Insert the SD card into your computer's card reader.
Click Start, then "My Computer."
Right click on the drive representing your SD card and click "Format."
Choose the memory capacity that fits what the SD card's capacity is.
If the exact option isn't available, get as close as possible.
Choose "exFAT" from the "File system" option.
Click "OK" and confirm you want to format the drive.
Hope this helps.
Nov 20, 2012 | Computers & Internet
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
I have msdc card errroro i want to format
buy a card reader.put your msdc in the card reader slot.connect the card reader to computer andyou can format it just like a pendrive.
Jun 05, 2011 | SanDisk 2GB microSD Memory Card
My micro sd memory card 2gb was not format complete and also fat alloc error
You must reformat the card again. If you have problems, try using Disk Management (if you have Windows)
Mar 14, 2011 | Computers & Internet
1st time set up for sd memory card on sharp xe-a203 cash register, i keep getting error code e-sd-99. i've retried it 3 times and keep getting this error. the card is 128mb.
According to my manual, the cards should be formatted on a Windows PC. Insert the card into any computer and wait for it to be recognized. Access the card's memory by clicking on the icon in the "My Computer" (or equivalent) window. BE SURE THERE IS NOTHING ON THE CARD THAT YOU WILL LOSE. This process will erase everything on the card. Right-click on the card's icon. Click "Format." Set formatting options to FAT memory. Set the allocation size to 16. Start formatting. Double-check your manual to be sure for the specifics on your exact model of calculator.
Sep 24, 2009 | Sharp Office Equipment & Supplies
Unable to add default folder, root directory full
after restarting the phone don't press any key until 2 minutes.
Jul 27, 2009 | Samsung SGH-E900 Cellular Phone
P3400I
Sir,
In My HTC P3400i the start menu containt application and setting are removed how to get them back.
Please provide solution.
URGENT.
Mar 19, 2009 | HTC S710 Smartphone
D900 mp3 problem
Just try formatting the SD card. Hope it works fine.
Just connect the micro SD with computer.(You need SD adapter, SD card reader, and USB connection) Most computer will recognise the SD card automatically. Format the micro SD in the Window Explorer(or My Computer). Format menu can be found if you click right-button with cursor on the drive letter. After formatting, re-insert micro SD into your D900.
Some Korean experts says the problem might be caused by different file system (e.g. FAT, FAT32, etc) in each memory card. So they recommended not to share your memory card with different mobile phones as well as any electric devices (eg. MP3 player and digital camera).
Nov 24, 2008 | Samsung SGH-D900 Cellular Phone
Micro SD problem loading music
Just a guess, but I'm thinking the problem may lie in the format of the media. Try to format in FAT32. Also make sure that the full card is used ( don't do only 500mb or such ) FAT file system used to only allow a certain amount of space for
(F)ile (A)llocation (T)ables, and I think only a certain length of file names ( I'm thinking 8 character ), while FAT32 allows for 32 character file names, and allows for more FAT table information. I wouldn't ty NTFS if it does allow, as some portable devices do not read them, but fat and fat32 should be universal...
Jan 03, 2008 | SanDisk Memory Media
Computers & Internet Logo
774 people viewed this question
David Payne
David Payne
