Question about Behringer XENYX 2442FX Mixer
When i record thru my mxl genesis mic with the mixer i get like a loud distorton. Im using magix 14 ,and i have downloaded the audio driver off the disc that came with the mixer....Help
  • Behringer Master
  • 5,603 Answers
It is likely you do not have the levels set correctly and are over driving the mixer. Reduce the trim settings using the PFL buttons and monitor the level indicators to insure you are not clipping.
With a condenser mic you CANNOT have any speaker in the room that the mic can hear of course. These mics are so sensitive. Your mixer and monitor speakers and recording will be in a separate room from the soundproof studio typically.
To monitor the system anywhere in the same room as the mic you MUST use headphones that do NOT leak sound or you will get feedback and distortion.
Posted on Mar 14, 2011
  • Bennieboombb Feb 28, 2012
    I have a mxl genesis and wen I turn it on my mic starts to pick up a lot of air for no reason and it picks up a lot wind
Im Using Acid Music Studio 8.0 With & Xenyx502 Mixer. Every Time I Record It Sounds Fine But When I Play It Back When Im Finished Its Off Beat How Do I Fix This??
check the "buffer" setting - set to the lowest number possible. You can't eliminate the "latency" but you can reduce it a lot. Also 0 try to monitor what you are recording with "live" sound (input instead of output) - also, you may need to download a different driver for your audio card, try ASIO4ALL
Oct 13, 2013 | Lexicon Alpha Personal Recording Studio
Im trying to connect a peavey kb300 with a mackie micro series 1402-VLZ 14 channel mic/line mixer
The mixer is stereo and the amp is mono. The line level out of the mixer MAY overwhelm the KB2 regular inputs so try running the mixer into the PA input jack.
Apr 27, 2011 | Peavey Kb 2 Keyboard Amplifier
I have 1604-Vlz3 mixer recorded on cubase5 best matchable sound card is? I have M-audio delta 1010LT.This not so good sound.after recording. For like "Bollowood Hindi VocaSetting" EQSettings...
The problem is that card has only UNBALANCED inputs. You really need balanced or first run the mixer outputs through a DI backwards. Frankly, I would recommend NOT using a card within the PC as there is so much digital noise. Use either a USB or Firewire external convertor and for goodness sakes use balanced lines from teh Mackie... ALL interconnected equipment needs to be powered from the same receptacle or source. M Audio, Roland/Cakewalk and Presonus all make cards as do others.
Mar 16, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
I have a tower computer kind of older . when i plug in the microphone to the back i.e. microphone port, nothing happens to signal it reads the microphone and when i try to use the microphone for fruity...
Assuming you are running windows XP you need to
1. right click the speaker in the lower right corner and select adjust audio properties.
2. Select the audio tab
3. Pull the drop down menu under sound recording and make sure it is selected to your audio driver device. Most are either soundmax, creative(for soundblaster and audigy standalone cards), realtek, or ASUS.
4. Next repeat step one but select open volume control
5. Go to options and then properties
6. Select the circle for recording and make sure your mic input is checked.
7. Close that window and recording mixers will pop up. Select the input you need by checking the box in the lower left corner of the mixer channel. Adjust the level and then use your recording program or sound recorder under Program files>accesories>communication>sound recorder.
Mar 08, 2011 | Philips Phillips...
I have a behringer xenyx 1204usb mixer with a mxl 990 mic and i have problems with static. thats all i have hooked to the mixer so i dont think its a conflict. i have tried recording in audition, pro...
Yep ! First thing is to eliminate any processing resource "hogs" that **** respources and can cause buffer overruns. Eliminate Antivirus, antispyware, and network communication and wireless network programs running in the background while recording.
Next make sure that ALL equipment is powered from the same receptacle or power source. In your case that should be the mixer and the PC.
Next remember that the condenser mic picks up everything... I have 5 of those mics and seemingly noise free environments turn out to have little things that generate fast rising pulses that you don't notice till they are recorded.
Lastly, the air here is very dry and plain old static electricity is rampart... Lady shuffling her feet was sending pulses through the mic cable at our church. They are NOT audible until they get into the sound system as clicks.
I have found that trying to record directely to a USB stick often has ooverruns and clicks... also burning a CD from stick to the CD results in noise due to buffer underuns. Burn from Hard drive to CD and make sure all the other hog programs are shut off.
Jan 04, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Need to connect to a sound blaster live sound card for recording using sonar as recording program. hace had it in storage for sometime and can't remember what went where
This particular mixer offers a usb (2 channel connection) that can be simply plugged into the computer usb 2.0. These channels should be available in Sonar from the channel Input/output drop boxes. You may need to restart Sonar, the mixer or both for them to be recognized. You may also need to run the Wav Profiler in Sonar. Typically the Wave Profiler is found in the Options>Audio menu but may be different on each edition of Sonar. The above info is for Sonar 7.
If you are wanting to record several channels at once then I would recommend connecting your Mixer's Direct Outputs from each channel to a corresponding input of the soundblaster if your soundblaster supports multiple channels. And then use the usb outbut from the Sonar to monitor the computer playback of your master stereo channel. Or, you may connect the soundblaster outputs to unused channels of the mixer or to the tape return or auxilary inputs to monitor the computer playback on the mixer.
Alternately you can send the signal to your soundblaster via the buss outputs. This will limit the number of simaltanious output channels to the number of busses on the mixer, but you can send any mixer channel to any buss without unplugging the instruments or mics.
Here's the link to the page where you can download the free pdf manual for this mixer. Page 14 explains the output connections and has diagrams.
http://www.behringer.com/EN/Products/2442FX.aspx
Oct 09, 2010 | Behringer XENYX 2442FX Mixer
Mic output of my pmp3000 is weak,levels must all the way up to get any mic sound louder,Im using balanced xlr's for my mics, Is there any adjustable sensitivity adjustment inside the mixer? like the...
The answer to your question is NO, there is NOT an internal adjustment.
For many mics the trim is used full clockwise. Some higher output mics I use the trims are run at 3 o'clock which is mostly turned up. This is NORMAL for most mixers. If you don't have enough mic gain relative to other inputs, the fault is balancing the other inputs down and using higher setting on your MAIN slider.
If you use 8 ohm speakers then you can expect to get about 200 Watts of audio per side with this amp. You can get about 400 Watts RMS (600 Watts peak) using 4 ohm speakers.
The efficiency of the speakers makes a lot of difference in the sound level output/
Sep 15, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
I am currently having problems with our PA System. We use a Behringer PMP3000 Mixing Board, with a Peavey PV115 Speakers. We can't get them to reach the volume these speakers are ment for. We would run a...
The speakers are 8 ohm so you can probably get near the 400 Watt per side when connected to this mixer. You don't need bridge mode to get this and I would recommend not using it anyway. Whatever you do make sure the speakers don't get disconnected when running at high volumes as you will arc out the amp in the mixer... I know this as I fix them... I have two PMP5000's that I repaired. Lots of work to repair...
The feedback is NOT the fault of the mixer or speakers but instead of something picking up sound from the speakers and sending back to the mixer.
The mic must be well in back of the speakers (say at least 10 feet) to avoid this or you need to use anti-feedback hardware to avoid the problem or highly directional close talking mics. Reverberation off walls can also get back to mics and cause problem. I was able to use a wireless Peavey mic which seemed to disrupt the phase enough to never get into an oscillation even when in front of the speakers.
Apr 18, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
No live sound using Samson CO3U and Windows 7 x64
I don''t think you can solve this problem. The problem is that the computer has to digitize the incoming audio, then echo it out. This conversion takes time and is also governed by the real time clock servicing of the devices. You could try upping the priority of the conversion process, but I don't think you are going to be satisfied with the result either.
You would be happier to use a mic and external mixer where the audio is true real time rather than having the conversion latency time.
Jan 29, 2010 | Samson Audio C03upak Co3u Microphone with...
I have a behringer xynyx 1204,and a protools personal studio,with mbox2 mini,and im just wondering if its possible to plug the mic into the mixer,instead of the mbox,and still be able to record vocals into...
It is possible, you can simply put a Y-cable for Mic or a splitter for the mbox and the Mic. You can plug the mic directly to the mixer then the other jack on the splitter connected to the mbox.
Jul 25, 2009 | Behringer Music
Behringer XENYX 2442FX Mixer Logo
100 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
