Question about Nokia 6300 Cellular Phone
My 6300 was working perfectly and i just finish back up and i want to update software. so i just unplug the usb cable and after that my mob does not open even i press the on button many time as usual way hold for a second. but blue light still on so pls suggest me what i have to do now. eveything happand when i upedate the software pls pls help me i need some important mob no. which only i feed inside thanks in advance. nj
  • 340 Answers
Its an software problem you have to flash your mobile obviously you cannot able to take informations stored on your phone. Try switch on your mobile by power on + call+3 by pressing 3+call button switch on the phone
Posted on Mar 14, 2011
I can't open my 6300 because i forgot my password..please help to solve this problem.. tnx, FCC ID: PPIRM-217 IC: 661U-RM217 Type: RM-217 Model: 6300 MADE IN CHINA 359835/01/718610/3
1. first install phoneix service
2. open it
3. In Phoenix, click File>Manage Connections.
4. Now click New.
5. Now select the type of cable you are using. If you are using DKE-
2, CA-53 [N-Series] cable, select USB.
6. Click Next. It will find your product and say FOUND. If it doesn't
find any, you can try changing your cable type by clicking Back.
7. Click Next and then Finish.
8. Now your cable type [USB] appears in the connection list. Select
it. Click APPLY and then CLOSE.
9. Now select File>Open Product.
10. A list of RM code will open. Select your phone's RM code. Like
RM-133 for Nokia N73. Click OK
11. Now select File>Scan Product.
12. Your phone's firmware info will appear at the extreme bottom of
the Phoenix window.
13. Now go to Flashing>Firmware Update.
14. A window will open.
15. On that window click Browse button [the one with three dots].
16. A window will open with various products and various regions.
Choose the region or country of your choice according to the
language pack you want to install.
17. Click Ok.
18. Click Refurbish.
19. Now your actual flashing has started. Don't touch your phone or press any button until the flashing has finished. Also don't touch your data cable and your computer system.
20. At the end Phoenix will tell you to remove your phone as the
21. Now wait for your phone to reboot into latest firmware.
22. The flashing procedure takes 8-9 minutes, a lot faster than Nokia
Software Updater.
Flashing dead phones [Which show only white screen on startup
this will reset your password
Jan 09, 2011 | Nokia 6300 Cellular Phone
I want to update it software version via USB cable
Nokia 6300 firmware update
Subject: how to update firmware for Nokia 6300 to the latest official version
1. You need download and install NSU - Nokia Software Updater (http://europe.nokia.com/support/download-software/device-software-update/download#) and run it to ensure that all is ok! (don't forget to switch on and connect Nokia 6300 via USB with PC)
2. You need to download and install NSS (Nemesis Service Suite) (http://www.b-phreaks.co.uk/index.php?main_page=page_2), the latest version of NSS was 1.0.38.15 (select "Virtual USB Device" mode)
3. Close NSU if it's not closed and load NSS then click icon "Scan for new device"
4. Click icon "Phone Info" and button "Scan" inside it
5. If all is ok you'll see some lines with Phone Version, Phone IMEI and so on
6. Click button "Read" and remember your "Product Code"
7. If your want to clean your phone go to tab "Tools" and switch to subtab "Factory Setting", choose option "Full Factory" then press button "Reset" (NOTE!!! all personal data and settings will be cleared!)
8. Return to tab "Phone info" and type in the field "Product Code" the following code 0537621 (or any code from (http://www.expansys-usa.com/ft.aspx?k=96957)) for version 7.21, or code 0557624 (or any code from (http://www.a2phone.com/6300-rm-217-dp20-900-sw-0730exe)) for version 7.30, select option "Enable" then press button "Write"
9. Close NSS, run NSU
10. Now NSU should update firmware to version 7.21/7.30 (or any latter build) (http://europe.nokia.com/support/download-software/device-software-update/can-i-update)
11. Repeat stages 3 - 5
12. Type in the field "Product Code" the code that you remembered before, select option "Enable" then press button "Write"
13. Close NSS
14. Use you clean phone with new firmware!
Mar 17, 2010 | Nokia 6300 Cellular Phone
Download songs tp nokia 6300
download song from net.and copy to ur pc...then copy to ur mob thro ur nokia usb cable or thro nokia suite
Aug 07, 2008 | Nokia 6300 Cellular Phone
How to update 6300
goto nokia site and update ur new version of ur mob software..this update will takes place upto 2 hour..
Aug 05, 2008 | Nokia 6300 Cellular Phone
Contact Service in nokia 6300
its ur mobile software problem..after few days it ll show oly tat msg...operation of ur mob ll struk in future...so better reinstall ur mob software and then use it....same pro had for me also..i cleared by tis way oly
Aug 04, 2008 | Nokia 6300 Cellular Phone
N73 start up problem
Your phone needs to be reprogrammed, only a repair shop can do this for you.
You need to download the latest Nokia PC Suite to do an update on your phone.
Before updating software you should check that there’s a newer version of software available.
WARNING
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don’t unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you’re up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
May 05, 2008 | Nokia N73 Cellular Phone
Nokia 6300 incompatibility with Nokia PC suite
You need the latest Nokia PC Suite installed on your PC.
Then do an update of your phone software. Nokia PC Suite v6.85
WARNING
Mar 30, 2008 | Nokia 6300 Cellular Phone
Software Upgrade
install the cd that came with the phone, once that is done and you have connect you phone via usb cable to the pc, switch on the phone then when the pc has located and recognised your phone go to the update column and the pc will search nokia site for a new upgrade.
Dec 11, 2007 | Nokia N70 Cellular Phone
Nokia N73 software update problem
during software update N73, the phone does not switch on. what can i do
Aug 07, 2007 | Nokia N73 Cellular Phone
Nokia 6300 Cellular Phone Logo
141 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
