My dvd player worked fine until I mistakenly inserted a bluray dvd. Now dvds will only have video - no sound. And, there's no sound at all for cds. How do I get audio for dvds and cds again?
    Problem Solver:
  • 14 Answers
Assuming that this is an entertainment center (TV, stereo) DVD player:
It seems likely to me that at some point, the sound cables were accidentally loosened. Double check that the sound cables are plugged in on both sides. They will probably be 2 plugs, one white and one red.
Check to make sure the volume is turned up.
Failing all of these, it may be possible that the added weight of the Blu-Ray (Blu-rays are heavier than DVDs) may have caused some damage internally and the unit either needs repair or replacement.
Assuming that this is a computer DVD drive:
Check the Windows volume control by left-clicking on the speaker symbol next to the clock in your task bar. Push the slider all the way up. You should hear a sound. If not, there is a problem with your speakers or sound card; either way, the appropriate component needs repair or replace.
If you do hear a sound, but still no CD or DVD audio, I would suspect that your computer expects an analog sound link for DVD and CD audio. Inside the computer, look for a small black connector that is loose on one end, but plugged in on the other. If you find one, one side needs to be in the back of the DVD drive, and the other needs to be attached to the appropriate socket on the motherboard or sound card.
Posted on Mar 14, 2011
Want to play my sounds through my tv or bluray
This unit has HDMI out so if you can connect it to your TV with an HDMI cable it should carry both Audio and Video. You say that it won't play DVDs so it makes me think you might have a bad player that you will have get replace through warranty. If you have it connected to your tv and you see some form of welcome screen come up when you power on the DVD player but it won't play discs I would exchange it. As far as other codec are concerned, it says that WMA and other formats are "available". This seems to mean that they are not pre-loaded but the device is capable of using them after some process is followed to install them. I can't tell from their site if the player has internet capabilities or not. One spec said that it has wireless but no other details. If you can connect it to the internet then I would guess the menu would have a way to update it through the internet adding in the new Codec other wise you might have to download them from another computer and put them on a usb drive to install them.
I hope this helps. Good luck
Mar 17, 2014 | Samsung BD-D5500 3D Blu-ray Disc Player...
Black and White Image
Yes there is video format for our TV and dvd players. NTSC & PAL...
NTSC SYSTEM SELECTED IN TV & DVD PLAYER PLAY PERFECT NTSC CDS & DVDS, BUT IF PAL CD OR DVD IS INSERTED SUCH PROBLEM COMES.
EVEN IF, THE DVD PLAYER SETTING IS KEPT AS PAL, AND WE INSERTING THE CORRECT CD OR DVD AND ALSO IT SHOW BLACK & WHITE PICTURE, ETC.... so please check your video system in TV, DVD PLAYER and check the CD or DVD you are inserting is of same video format you have set in DVD player.
Apr 23, 2009 | Cyberhome CH-DVD 300 DVD Player
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
My burned media from my new DVD Burner ASUS DRW-2014L1T isn't able to be read by my DVD Player
no data dvds work on the players.
use NERO 6 OEM to write Video DVDs or CDs they will run Players
Jan 07, 2008 | ASUS (GENEIRC DRW-1608P BLACK)...
No sound from my clarion vrx755vd
I have a 7in in dash dvd player but it does not want to play cds or dvds. it gives me an error notice. it won't even eject the cds. Where can I fix it?
Thanks
Dec 14, 2007 | Clarion VRX935VD Car DVD Player
DVD lag
You need to install a codec pack. k-lite mega one is good and free :)
http://www.codecguide.com/download_mega.htm
Nov 22, 2007 | Toshiba Tecra A7-S712 Notebook
Portable dvd player will play music cds but not video dvds
Chances are, your DVD player uses one laser to read CDs, and a different laser to read DVDs (since Cds and DVDs are read at different wavelenghts of light). If the DVDs you're trying to watch work properly in other DVD players, it probably means that the DVD laser is dirty, damaged, or burned out. Though you can try cleaning the laser (use Google for suggestions on how to do this, or check the Audiovox website), you will most likely have to get the DVD player repaired, or buy a replacement. Many of the newer CD/DVD players sold today use a single combination laser, which reads both CDs and DVDs, which means that when the laser fails, it will not work at all. Wish I had better news for you, but I guess that the only consolation you have is that your Audivox player still works with CDs...
Apr 01, 2007 | Audiovox D1812 Portable DVD Player
Plays cds but wont read dvds
upgrade the firmware on the product.
Nov 10, 2006 | Sanyo DRW-1000 DVD Recorder/VCR
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
