Question about Lexmark X1270 All-In-One InkJet Printer
Fitting drive belt on lexmark x1100 3 in one printer
To fit replacement belt on scanner bed on lexmark x110 3 in 1 printer dont know where to place scanner on belt
  • Lexmark Master
  • 2,794 Answers
You should probably look on the internet for a service manual for it. It may have a specific place to put it for timing purposes.
Posted on Aug 01, 2008
Belt for cradle movement slipped,dont know how to re conect the belt...plz help me with this :(
you will have to dismantle the entire machine to remove the axle that holds the cradle in place , and remove the cradle and then you would be able to fit the belt back
Oct 11, 2013 | HP Deskjet D2360 InkJet Printer
Can you buy sheets for sofa beds easily?
You can just use regular fitted sheets on a sofa bed although sometimes they don't fit very well or get torn. There are places that sell sheets specifically for sofa beds, such as;
Sep 10, 2012 | Furniture
HP Deskjet f4435 will print, but won't scan. Orange light blinks
When I press the scanner button the top power button starts blinking but the machine does not scan. I have not used the scanning function on this machine before. Please may need to reinstall your ..
Aug 16, 2011 | HP DeskJet F380 All-In-One Printer
I cant seem to find where i load the ink cartridge into the printer
1. Raise the scanner bed and position the scanner support to hold the bed up, exposing the printer cartridges.
2. Press down on the tab on the end of the cartridge cover to open the cartridge bay. Pull the old cartridge straight out of the bay and properly dispose of it. Remove the tape and stickers from the new cartridge and insert the new cartridge into the bay.
3. Press the cover down until it locks in place, securing the cartridge. Repeat the process on the other cartridge if necessary.
4. Lift the scanner bed to release the scanner support. Lower the scanner bed to close the printer.
Mar 16, 2011 | Lexmark X2350 All-In-One InkJet Printer
Hp laserjet 3055 scanner error 5 turn off then turn on
Fat bed lid should be clean and closed, Scanner assy should move and scanner bulb should glow for a while, during the booting process.
The Flexible Flat Cable (pitch 1 mm x 30 Pin) should not be damaged (replace if damaged) and well pushed inside its jack in the formatter. (Open the right side cover and check).
The flat bed scanner's glass frame & Door base should mate perfectly with ease. If opened earlier, the ADF wire harness which passes on the inside along the rear right corner, can prevent PERFECT mating (if in palce the mating would not need any pressure and would fit in place easily), A gap of less tahn 1 mm can be the culprit.
If problem still persists open the scanner flat bed cover, clean the guide rod, check the laser assy movement, clean the black stripe above the resting place of the laser unit, laser unit mirrors ( 4 nos - with lint free fabric and Iso=Propyal Alcohol) re-assemble the flat bed cover with laser assy mid way on its path (to check movement when you boot). Ensure perfect mating as above stated.
If problem persists I fear you may have to replace the scanner assy or the formatter. Before you decide to replace formatter try "Permanent Storage Init" process posted by me for PC scanner "No connection" error.
Jan 23, 2011 | HP LaserJet 3055 All-In-One Printer
I dont know how to change the ink cartridge on my lexmark 5500-6600 series
just near the control panel lift the top portion of the printer which is the flat bed scanner assembly and that should give you access to the ink station
Aug 05, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
Cant get scanner to work
follow the link and it will show how to use the scanner.
Apr 29, 2009 | Lexmark X2600 InkJet Printer
Lexmark 6100 will not unlock after unlock procedure is done.
Thank you for contacting Fixya.
Please ensure that the scanner is unlocked. The scanner lock is situated under the scanner bed towards the left. To unlock the scanner, please lift the scanner bed and push the red switch towards the back of the machine. Please try scanning again and let us know the results.
If the issue still persist, please follow the steps given below:
1. Press "Copy" button.
2. Press "Options" till the display reads "Set Defaults."
3. Use the "Arrow (right/left)" buttons till the display reads "Use Factory."
4. Press "Select."
Please let us know the results.
Apr 15, 2009 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
112 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
