Question about GE Refrigerators
My ge refrigerator heating element is staying on melting the ice
  • 55 Answers
Hello, Not knowing the model you have I'll assume it is a profile since that is the most popular model. Try unplugging it for 7 to 10 minutes to reset the control board. If after that is does not return to normal ( it may take a few minutes to come back on) then you may need a new control board. It is located on the back of the frig behind a rectangular silver color panel. Usually three screws hold it in place. you can goto - http://www.searspartsdirect.com/partsdirect/index.action - to find a parts breakdown and order parts. Good Luck
Posted on Mar 14, 2011
Why the heat exchanger between the freezer section and the fridge section freezes up around the second element closer to the door and makes ice on the roof of the fridge section.
If your freezer is icing up it is the defrost mechanism consisting of the timer, heating element, and defrost thermostat.
When you unplug unit everything melts and it runs fine for a few days till it freezes up again.
Usually it is the heating element that just burns out and has to be replaced.
Sep 14, 2015 | GE Refrigerators
Freezer drain may be blocked. Freezer not working effeciently the freezer always icing up
. If the freezer is always icing up , you probably have the problem in your defroster circuit . The refrigerator cycles once every six to eight hours into the defrost mode . This is controlled by the defrost timer. when in this mode , a heating element located close to the evaporator heats up and melts the ice. This heating element will heat up any ice enough to melt It and drain out of the unit. I would check this first .
Feb 19, 2011 | Maytag MZD2766GES Side by Side...
Side by Side GE Refrigerator freezer will not defrost which allows frost/ice to build up. I have cleaned all the areas behind the unit as well as under the unit. After I manuely defrost the freezer it...
The defrost circuit has failed in your fridge. Typical failure is with the defrost heating element. To troubleshoot, you need to remove the remove the contents of your freezer section and remove the freezer back panel to access the evaporator coil. You will need a hair dryer to melt the ice on coil. The heating element is attached to the coil. Use a meter to confirm that the element is bad. Hope this helps you.
Nov 08, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
My fridge side by side the freezer develop a lot of ice in the back and wont defrost it supposed to defrost by it self but it wont, tried to clean the back and remove all the melted water from the back ,...
Your problem is in the defroster circuit . Most defroster circuits contain only three components. They are : a timer , a heating element , and a temperature sensing cutoff switch.
Your refrigerator defrost timer shuts down normal operation every six to eight hours and goes into the defrost cycle.
Line voltage is applied to the heating element . It heats up and melts the ice on the evaporator. Once the ice is melted, and the evaporator area warms up to a certain temperature, the temperature sensing cut off switch opens up and stops the current flow through the circuit. The timer is a running clock, so to speak , and will eventually deactivate the defrost cycle return the refrigerator to its normal operation .
Normally, the element or sensing switch will be the component to replace. Also, sometimes it can be just a bad connection in the element and sensor wire connectors.
Mar 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker water overflows into freezer
the condensate tube is run incorrectly on this model and goes uphill into the area above the refrigerator where there is a condensate pan. This will plug and back up and cause this problem. I have fixed ours several times but it always came back. The last time I bought a new clear plastic tube and reran the condensate out the back of the refrigerator and down through my floor. It's all downhill now and seems to have fixed the problem.
Nov 28, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Ice maker stopped making ice. I had to melt ice
Jim, you will need to replace the heating element and most likely once this has been replaced, your ice maker should work properly unless the ice broke another part on your ice maker.
I would start with the heating element first.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service with your model number and we will get the correct part out to you asap!
We look forward to getting your ice maker working properly again soon!
Thanks, Ella
Nov 09, 2009 | GE Profile Arctica Stainless Steel Top...
GE Arctica Refrigerator suddenly stopped cooling. Motors are running, controls are responding, but interior of freezer and refirgerator section is not cooling down.
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Refrigerators
Refrigerator cools fine but the freezer does not. It stays at about 20 degrees f. It is a GE
Aug 16, 2009 | Refrigerators
Freezer not freezing
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Thick layer of ice has formed at bottom of freezer. Cannot even pull out the bottom basket
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
162 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
