Question about Crosley Dryers
Dryer stopped heating how do you light the pilot
    Novelist:
  • 117 Answers
If your dryer doesn't heat, check these: Igniter Gas valve coils Thermal fuse Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too. The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.
Posted on Mar 14, 2011
Hooked up roper dryer and it's propane everything seems to be hooked up right but won't get hot or even heat up. This is first time ever having to use propane. Any idea what it might be or could have...
1.is the pilot light lite burning.
2. if pilot light light is on ,does the blue flame of the pilot light touch and heat up the thermocouple.
the dryer will not turn on the heat if the pilot flame does not touch and heat up the thermocouple.
3 is the dryer plugged in to the electricity.
4. is the dryer actually getting electricity.
If the dryer has electricity and the pilot flame is touching the thermocouple, then try buying and installing a new thermocouple.
****have you purged the air out of the gas lines so that the dryer is actually geting pure propaine and not just air getting pushed ahead of the propaine.
how old is your dryer, if new, warranty service will trouble shoot & repair for free.
you need to tell us more so that we have some facts to work with. vagueness does not cut it.
Oct 09, 2013 | Dryers
Stops and all the lights come on
Instructions
    • 1 Make sure the home's gas supply valve is turned on. Check your Maytag owner's manual to find the location of the dryer's gas shut-off valve. This is usually behind the dryer's front panel or in the back of the unit. Open the valve to allow gas to flow into the dryer.
    • 2 Open the lower front panel of the dryer to access the pilot light assembly. Press and hold the starter button as you light the pilot with a handheld lighter. If you have trouble getting it to light, release the starter button and wait a few minutes before trying it again. Once the pilot is lit, hold the starter button down for another minute to make sure it will stay burning.
    • 3 Close the dryer's front panel and run a test cycle to see if it is producing heat. Call a repairman to evaluate the problem if lighting the pilot did not restore the heat.
Jan 15, 2013 | Kenmore Dryers
Dryer runs but does not heat. It runs continually
If your dryer never quits on its own, then your main selection switch may be bad. Even if the clothes don't dry, the timer should still only run to the end of the cycle and then stop. The problem with the lack of heat could also be caused by a bad timer switch, but that is rare. Usually it is caused by a bad igniter/heat sensor unit. Sometimes you can use a piece of sandpaper and clean the carbon off of the sensor and then it will sense heat when the pilot flame starts, then it will let the gas valve send gas to the main burner. The heat sensor it the part that is in the flame of the pilot light.
Jun 11, 2010 | Roper RGX4634KQ Gas Dryer
Old maytag gas dryer. Does not heat anymore, gas
Maytag dryer series 05. How do I light the pilot?
Apr 04, 2010 | Maytag Dryers
How do I relight the pilot light?
There is no pilot light on many of the dryers of today. They light with a hot surface ignitor.
Here is a tip that I wrote about dryers and no heat on gas dryers...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Apr 01, 2010 | Kenmore 72802 Gas Dryer
No heat in dryer. Exhaust vent is clear
Heating element will need to be replaced
Aug 01, 2009 | Dryers
Kenmore dryer not heating
hi,
1) When this happens, something has interrupted the heat source. Run the dryer for a couple of minutes to see if it gets hot. Be sure you don't have the dial or controls on a non-heat setting, such as "Fluff" or "Wrinkle Control."
2) On an electric dryer, this may mean that the circuit breaker or fuse that controls the power has blown; reset or replace this. Be aware that a dryer may have two breakers or fuses. The motor will run when one works, but the heating element requires both.
3) On a gas dryer, recheck the control's setting to be sure it's not on a heat-free setting. Check the gas valve behind the dryer to be sure the gas supply is turned on. Also make sure the house's main gas valve is turned on.
4) Most modern dryers have electronic ignition instead of a pilot light. If yours has electronic ignition and isn't heating, call a qualified repairperson.
On an older dryer, make sure the pilot light is burning. If it isn't, relight it. You can find directions in your owner's manual, and pilot light instructions are often mounted next to the pilot light on the burner, too.
Thanks for using FixYa
Jan 03, 2009 | Kenmore 63942 Dryer
Finding pilot light for a Kenmore dryer model # 97581110
theres no standing pilot in dryers is it on a heat setting or air dry .then look thru that small hole while in aheat setting on the timer. when you press the start button you will hear two clicks the see the glow ignitor glowing.if its not glowingyou would need to check voltage at the ignitor if no voltage problem will be thermol cut out fuse
Jan 01, 2009 | Dryers
Hw120m washer/drier
Check if the dryer is heating, if it is not heating check the following There's no heat
Oct 16, 2008 | Hoover H130E Front Load Washer
Neptune Drying Center MCGAWW (No Heat)
Sorry no pilot light but you have ignite, flame sensor and a gas valve...all control heat...
let me know if I can help
krazytech
Mar 30, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
225 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
charles
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
