Question about Gaggia Baby Espresso Machine
Stuck Button Yesterday, the button that you press to activate the pump (the one with the cup icon) stopped sticking in properly. In other words, when you press the button, it is supposed to "lock in" until you press it again, to stop the pump. Now I can press it in, and the pump works, but it doesn't go in all the way and lock in, so if I take my finger off, the button comes out and the pump stops. I can still make espresso, but I'd still like to fix it if I can...
    Sergeant:
  • Gaggia Expert
  • 223 Answers
You need to replace your coffee button. If you need to order the part please contact:
Authorized Gaggia Service Center
Cerini Coffee Services
New York, USA
www.CeriniCoffee.com
support@cerinicoffee.com
Posted on Sep 12, 2008
Hot point washing machine WMA76 stuck on child lock
Child Lock
?When activated all the buttons will be disabled and a child will not be
able to alter any wash programme or option settings. Once selected
this feature remains activated, even when the machine is 'off'.
To use this feature press the 'Child Lock' button and hold down for 2
seconds.The child safe icon will begin to flash.When the icon stops flashing
the feature is activated.If any of the control buttons are pressed, the child
safe icon will flash and the machine will bleep 3 times: no alterations to the
control settings will be allowed.If power is interrupted, at any time,pressing
any button will reactivate the child lock feature.
To deactivate this feature hold the 'Child Lock' button down for 4
seconds.You will then hear a bleep and the child safe icon will go out
Mar 27, 2016 | Washing Machines
When I press the espresso button instead of esspreso makes a long coffe .I must ad I descaled it yesterday .
You may have accidentally changed the amount setting for your espresso shot when resetting the descale counter.
If you lost the manual you can find one here.
http://www.gaggia-usa.com/support_docs/Gaggia_Brera_Quickstart_Guide.pdf
On page 11 (with the printed number 31) you find how to change these settings:
• Place a cup under the dispensing spout.
• Hold the "espresso size" button pressed for 5 seconds to enter the programming mode; the "coffee" icon will blink quickly and the coffee will start to be brewed; the icon will flash during the whole coffee brewing cycle.
• Press the same "espresso size" button again when the amount of coffee in the cup reaches the desired level.
At this point the button "espresso size" is programmed; each time it is pressed and released, the machine will brew the same amount of coffee that was just programmed.
The same operation can be repeated for the "Lungo size" button.
Jun 15, 2015 | Gaggia Brera Coffee Maker
I have a krups xp2070 that i just put a new motor in. When making espresso, the water pump does not turn off. Is it related to the little relay switch that connects to one side of the pump?
The unit is programmed to operate the pump for a very specific period of time depending on the function. Power to the pump is provided by the main power module but controlled by the control module. Either the module is not sending the right signal or the relay on the power module is stuck on. You could try programming the espresso time to reset the pumping time. Will the pump stop if you press the espresso 1/2 cup button again?
Dec 12, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
My kenmore elite washer just stop working. My mom
When activated all the buttons will be disabled and a child will not be able to alter any wash programme or option settings. Once selected this feature remains activated, even when the machine is ‘off’.
To use this feature press the ‘Child Lock’ button and hold down for 2 seconds. The child safe icon will begin to flash. When the icon stops flashing the feature is activated. If any of the control buttons are pressed, the child safe icon will flash and the machine will bleep 3 times: no alterations to the control settings will be allowed. If power is interrupted, at any time, pressing any button will reactivate the child lock feature.
To deactivate this feature hold the ‘Child Lock’ button down for 4 seconds. You will then hear a bleep and the child safe icon will go out.
If this is not the problem than turn off the AC power for 30 mintes and then power the machine back on an everything should be OK to use as long as no Error Codes are displayed.
Nov 13, 2009 | Kenmore Elite 45986 Front Load Washer
How do we get childlock off a hotpoint wm 864
Oct 25, 2009 | Washing Machines
I can't remove the childlock on my washing machine! Can you help?
Sep 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
My tmobile wing keeps freezing up when I try and text
It took me a long *** time to fix my wing, but this is the only way i found. shout out to my homie muhammed for showing me:
hold both left and right toggle button simultaneously, and use stick to press the reset button. continue to hold buttons....
it will reformat. press send to wipe the phone.
then, use active sync to completely wipe the micro sd memory card once wipe is complete
this will delete the static charge virus
lastly, go to tmobile website and download the rom software upgrade.
reconnect the wing to your pc
charge the phone past 50%
click on the new software upgrade icon and follow instructions.
the screen will show 3 lines, green red and blue with the new upgrade version numbers.
once complete, you have completely upgraded the tmobile wing to the fullest extent
if this does not work, then sadly enough.... your problem is from dropping your phone too many times and causing the components to become loose connections. aka the sliding keyboard.
i also noticed that the only thing stopping the keyboard from stopping is a tiny square piece of plastic. but then again, this phone was crafted in china. chinese plastic isn't the most sturdy composite material.
Dec 01, 2008 | T-Mobile Wing™ Smartphone
My wireless keyboard stopped working the mouse works but not the keyboard what can i do
1)Verify that the batteries are correctly installed in the keyboard and mouse. If possible, use a fresh set of alkaline batteries. 2)Reset the keyboard and mouse connections : --With the receiver plugged in, press and hold the Connect button on the receiver until the activity LED flashes. --Press and hold the recessed connect button on the underside of the keyboard until the activity light on the receiver stops flashing. When you release the button, make sure it does not stick in the depressed position. --Press the Connect button on the receiver again until the activity light flashes. --Press and hold the recessed button on the underside of the mouse until the activity light on the receiver stops flashing. Make sure the connect button does not stick in the depressed position. --Make sure that the receiver is at least 20 centimeters (8 inches) away from other electrical devices (computer, monitor, keyboard, etc.). --Remove any other objects that are between the keyboard, mouse, and the receiver, especially speakers. Hope this should resolve the Issue. Thank you.
Sep 30, 2008 | Computers & Internet
Too little coffee
reset to factory default...
1. Power switch off
2. Press & hold coffee cup button while powering back ON
Mar 22, 2008 | Nespresso Essenza C100 Espresso...
Honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Gaggia Baby Espresso Machine Logo
149 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
