My furnace sounds louder than normal. It seems like it is making a rattling type noise. All of the flames are going when I looked through the glass hole, any ideas why?
rayname
  • 70 Answers
SOURCE: Goodman GMNT furnace goes into 'lock-out'.
check to see if your intake pipe or vent is clear this could cause a flame jump and make it look like a bad flame sensor let me know if this helps
Posted on Jan 08, 2009
daverh
  • 117 Answers
SOURCE: Makes a loud humming noise while operating
Almost certainly, the component called the "magnetron" has died. This is the valve (tube in the US) which actually generates the microwaves. The loud humming is the transformer that supplies the magnetron being overloaded and/or the magnetron itself. If the rest of the appliance is OK and not too old, the magnetron can be replaced. If you aren't familiar with these appliances, you *must* get this done by someone who understands the dangers of messing with them - if you get it wrong, they can bite! In some countries, only qualified engineers can buy the spare parts. In the UK, the part costs around £40 - £80, depending on the model. If the appliance is more than around three years old, it may be a false economy to repair it as other parts may fail soon after the repair.
Posted on Sep 24, 2007
hotuna
  • 288 Answers
SOURCE: ruud silhouette II furnace
Yes. On the board mounted inside the furnace box. There will be a series of posts that have numbers printed below each post. The heat motor uses low speed so it should be a sort of fat (larger than most of the other wires) red wire attached to one of the posts. If the wire is on 60, for example, then move it to the next lower post, like 30. unplug the cord on the furnace first. The wire SHOULD be red but may be blue, don't let the color guide you, look for the place where the wires go. If you find the place I'm talking about and the wire is black, then let me know, because its wired to high speed, which is wrong. I will help you.
Posted on Mar 13, 2008
aborcass
  • 2651 Answers
SOURCE: Rattling noise during high speed spin
sounds as if you might have a bad rear bearing, real obnoxious almost painful to listen too kinda sounds. big job, but might have some part warrentee depending on age of unit
Posted on Oct 21, 2008
  • 182 Answers
SOURCE: amana air command 90 model
It may be a delayed ignition.Try removing and washing the burners.
Posted on Nov 02, 2008
Why does new furnance with propane conversion have yellow flames?
Make sure the kit included smaller sized orifice's and spring kit for the gas valve. The number on each orifice should be cross referenced with total btu's rating of the furnace. It does seem like there is too much fuel or not enough air intake (combustion air). The inches of W.C. seem fine, but you still may be getting too much volume of fuel with too large of sized orifice's. Hope that helps
Dec 20, 2013 | Heating & Cooling
2006 Camry 2.4L 4 Cylinder inlet manifold rattle
quick fix and cheap drain a quart of oil out of the motor then get a quart of LUCUS oil conditioner add to the motor oil. about (12-15 dollars) it worked to quite the little 2.0 that has always had a little lifter/valve noise,
Jun 03, 2012 | 2006 Toyota Camry 2.4
Microwave won't start but rattles when close door.
It is possible you have one or more door switches that are bad and need replacement.
May 05, 2012 | GE Microwave Ovens
Rattling noise
Check catalytic converter.Catalytic converter could be breaking up inside.
Dec 09, 2011 | 2001 Chevrolet Blazer
FURNACE MAKES STRANGE INTERMITTENT CLICK SOUND
Measure the voltage to Terminals #2 and #3 on the main gas valve. If the voltage remains consistent while you hear the sound and the burners diminish slightly, the problem will be your main gas valve. If the voltage fluctuates, you will have to trace it back through the wiring to see through which switch you are losing it.
If this furnace has a hot surface ignitor with flame sensor, try cleaning the flame sensor with some emory cloth.
I hope you find this information to be very helpful as a good starting off point for you.
Please leave a rating. :-)
May 11, 2010 | Heating & Cooling
Furnace sounds louder and feels stronger heat coming through???
The service technician probably installed a larger motor pulley which increases the fan speed to blow more air which results in a slight increase in duct noise which is normal.
Jan 29, 2010 | Heating & Cooling
98 gmc jimmy makes a rattling/clunking noise on right front side. Sounds like its coming from tire but checked brakes, rim, lug nuts, and such but found nothing. It does it on and off but mostly on and...
If the noise gets louder around corners while the 4WD is being used the Constant Velocity Universal joint is worn out, if not the truck probably needs stabilizer link rods they are fairly inexpensive but the CVU joints are not.
Nov 06, 2009 | 1998 GMC Jimmy
The brain has to have constant verification of flame. If the burner ground is corroded then you will get the condition you prescribe.
Jan 08, 2009 | Heating & Cooling
1993 Toyota Previa makes a rattling noise when running
I have had this problem before, the first time it was discovered that the stand that support the hood was not properly secured in the clip slot.
The second time the grill was loose. Check these before going to the mechanic.
sirmickei - New York
Jun 14, 2008 | 1993 Toyota Previa
Engine Making Noise when accelerating
Could be carbon build-up on the pistons, causing erratic flame travel in the combustion chamber... 'pinging'...... Decarbon the engine and use a high grade fuel for a few tanks.... also an octane booster can help
May 15, 2008 | Mazda B4000 Cars & Trucks
Heating & Cooling Logo
219 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
