Question about Exercise & Fitness
My landice 8700 programable is showing an L5 error and does not run how do i replace the switch that is bad with this treamill it only has an up and down button for more or less speed
  • 914 Answers
LS Error on Landice L-Series Treadmills with Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. This error can occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:A) Speed sensor is out of adjustment
B) Speed sensor is damaged or faulty
C) Display cable is damaged or faulty
D) Improper speed control wiring Corrective Action A) Speed sensor should sit parallel with the flywheel and gap between speed sensor and flywheel should be within 1/16". Adjust speed sensor if necessary.
B) Inspect speed sensor connector to relay board. Check for pushed pins or loose wires. Repair or replace speed sensor assembly if necessary.
C) Inspect upper harness or display cable connector to relay board. Check for pushed pins or loose wires, giving specific attention to pin 5 (brown) and pin 9 (green). Repair or replace display cable if necessary.
D) Inspect speed control wiring:
  1. Checking purple wire from V+ on pwm board to P3 on the relay board
  2. Checking orange wire from P1 on pwm board to P1 on the relay board
  3. Checking brown wire from P2 on pwm board to P2 on the relay board
  4. Confirm P3 on pmw board has no connection
Correct speed control wiring if necessary.
Details about LS Error on Landice Series Treadmills with Belt Movement
Posted on Feb 04, 2015
4 Suggested Answers
SOURCE: landice 8700 sprint starts at full speed and then
This happened to mine and I figured out that the sensors were dirty. I got some canned air that you spray on computers and sprayed out the mother board. I also sprayed the electrical contacts with electrical contact cleaner and the treadmill is a good as new.
Posted on Jan 31, 2010
outfield502
  • 79 Answers
SOURCE: ? L5
Upper display lights up;treadbelt moves;speed will not increase;L5 error.
Check speed sensor alignment.
It should be within 1/16" of the flywheel
and parallel to the flywheel.
Is it out of position?
Unplug 3 wire speed sensor connector from
wires.
Any found?
Unplug 12 wire upper harness connector
from relay board. Check for pushed pins or
loose wires. Specifically look at 8 (White)
and 12 (Green).
Any found?
Is speed control wiring OK?
Purple wire from V+ on pwm board to P3 on relay board.
Orange wire from P1 on pwm board to P1 on relay board.
Brown wire from P2 on pwm board to P2 on relay board.
P3 on pwm board has no connection.
Adjust speed sensor:
1.Use 1/2" wrench and loosen
the two lock nuts securing
sensor to it's bracket.
2. Adjust sensor gap to 1/16".
3. Tighten lock nuts.
sensor / harness assembly.
Part# 71007
Repair or replace upper
harness. Part# 70251
Correct speed
control wiring.
Replace the speed sensor.
Part # 71007
Posted on Feb 06, 2010
maxtreadmill
  • 832 Answers
SOURCE: Landice L7 gives me a L5 reading on the screen
Your L7 error looks like L5 , but its really LS which mean lost signal. Unplug unit take motor shroud off then plug unit back in wall outlet. When looking in front unit you will see a Motor control board and there are LED lit up one of them should be an amber light this is you speed sensor which is attached to the top of your motor. Manually rotate the fly wheel and see if that light flickers if it does then your speed sensor is working properly if not replace speed sensor. The next thing to look at is the motor brushes to if they are worn unplug unit you should see slitted caps on both side of motor remove them if they are less than 3/8" they need replacing. That for the most parts should take of your problem. Call Landice @ 1800-526-3423 have the serial# handy their on all the components in the unit
Posted on Feb 28, 2010
My treadmill not running after 7 seconds diplay shows L5
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
It is common to see this error as and L5 error, but it is actually an LS error. The following information will define this error and give you the possible solutions to fix this issue.
LS Error with No Belt Movement on Landice Series Treadmills
LS Error on Landice L-Series Treadmills with No Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. If this error occurs with no belt movement, the causes for the LS or L5 error are:A) Faulty upper display board or faulty relay board
B) Improper speed control wiring
C) Improper motor control wiring
D) Worn or faulty motor brushes
E) Faulty pwm/relay combo board or faulty drive motor
Corrective Action A) Enter Open Loop Speed mode and set treadmill speed to confirm proper line voltage to pwm board and that the green BELTSW light is lit on the relay board. Replace upper display board or relay board if necessary.
B) Inspect speed control wiring and correct wiring if necessary:
C) Inspect motor control wiring, checking wires from motor to A+ and A-. Correct wiring if necessary.
D) Inspect motor brushes verifying brushes slide freely, are at least 3/8" long, are curved and have no burns or cracks. Also check the brush springs and verify that the brush copper wire is not burned or broken. Replace both motor brushes if necessary.
E) Inspect motor turns and is not seized up or has a broken shaft. Replace motor if necessary. Also verify at least 90VDC present from the black (A+) wire and white (A-) wire from the pwm board to the drive motor. If voltage is present, replace pwm/relay combo board. If no voltage present, replace drive motor.
Oct 13, 2015 | Exercise & Fitness
How do i fix an landice l8 trainer l5 error
that is a loss of speed error. you only get rid of it when the belt starts moving again
Jul 22, 2014 | Landice L8 80 LTD Executive Trainer...
Speed sensor L5
follow this steps and fix it. God bless you
SAFETY SHUTDOWN Loss of Speed Signal" or "L5" WITH belt movement
This is usually an indication of a speed control malfunction. The upper board is not recognizing a signal pickup from the speed sensor. This could be due to the speed sensor being misaligned, improper connection, or bad speed sensor. Refer to the flowchart on page
"SAFETY SHUTDOWN Loss of Speed Signal" or "L5" WITH NO belt movement
The speed sensor is not recognizing any motor movement. This displays the error message to the upper board.
NOTE: USE THIS FOR DIAGNOSING THE PWM/RELAY COMBO BOARD
Oct 21, 2013 | Landice Exercise & Fitness
Error code L5 on schwinn 820p
Landice L9 tredmill, L5 display on screen,belt runs slow and nothing else works to the touch.
May 13, 2010 | Schwinn 820 P Treadmill Silver Service...
Feb 12, 2010 | Landice L7 LTd Pro Sports Trainer...
? L5 Landice 8700
wires.
Any found?
and 12 (Green).
Any found?
Part# 71007
Correct speed
control wiring.
Part # 71007
Feb 05, 2010 | Exercise & Fitness
Landice won't start, it gives a L 5 error. I already replaced both chip boards. but the light on the board closest to the motor does not come on! Not sure if I got a faulty board? Is there any information...
Oct 14, 2009 | Landice L 7 Club Cardio Trainer Treadmill
I have a Landice L8 and the error code L5???
Jul 09, 2009 | Landice L8 LTD Cardio Trainer Treadmill
Landice treadmill 05 error code comes on when i hit start
Jun 28, 2009 | Landice L8 LTD Pro Sport Trainer Treadmill
Exercise & Fitness Logo
631 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
