Moved TV to a different room and the TV power button is blinking like it is in "standby" mode. How do I get it off "standby" mode??????
  • 902 Answers
Unplug it for about 30 mins it will reset it. if that doesnt work it will be stuck in standby mode until a video source is activated. if you are using hdmi both the tv and the hdmi device must be on. (hdcp compliant devices must be turned on at the same time otherwise it will say stuck in stand by mode they do this to prevent people from trying to rip content off hdmi and blu rays had the same issue with my tv and xbox.
Posted on Mar 14, 2011
Tip
Sony Brava Blinking Code and their meaning
Hello,<br /><br />Below are some blinking code interpretations for your Sony Brava TV;<br /><br />ONE Blink--- not used for the self-diagnosis<br /><br />TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.<br /><br />THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.<br /><br />FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505<br /><br />FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly.<br /><br />SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.<br /><br />SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.<br /><br />EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.<br /><br />NINE blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).<br /><br />TEN blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.<br /><br />Intermittent problems ?? This is a great feature. You can also bring up these fault codes ON-SCREEN to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, Press the following buttons:<br /><br />Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC. We have repeated them in parentheses in the text for the "Blinks" described above so you can correlate between the diagnostic screen and the blink codes.<br /><br />So, now that you know about these self-diagnostics, how do you use them? Say that you have a set with a black screen. You see that the LED is blinking 4 times....This would tell you that you have no vertical and that is why the video is muted. If it was blinking 6 times, you would know that you have a horizontal fault.<br /><br />I hope I have helped someone.<br /><br />Regards.<br />
on May 17, 2011 | Televison & Video
Define "standby" mode.
The standby mode is a power saving feature. In this mode, a it does not shut down completely, just goes to low power state and so it consumes less power. When it resumes from the standby mode, full power is restored.. During the standby mode, if the power supply is disconnected or interrupted, data might be lost.
Hope this helps,
Lucas
Jul 08, 2011 | Uniden CEZAI998 Phone
I have my PS3 plugged into my tv with an HDMI cable, and it was wroking fine just yesterday. But today I moved it back to my living room tv where it usually is but nothing shows up. It just says...
Please do the following to reset your display -
1. Turn the PS3 off into standby mode (red light on)
2. Press and hold the power button for 2 beeps (the first beep will be when you first press the button and the second beep will be around 5 seconds later)
3. Release the power button after you hear the second beep
4. Wait for the display to restart
Hope this helps and thank you for using FixYa
Jan 13, 2011 | Video Game Consoles & Games
I pressed the sleep button by accident and the pic and sound went off and the stand by/timer red light started blinking. what does it mean?
Depends on how many times it blinks,just count the blinks Example: if it blink 2 times then pauses and blink 5 times then the code would be 25 and so on
Once you have this code,please post it.
Jul 30, 2009 | Sony KV-32S40 32" TV
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
How do I get to standby mode?
There are three modes — standby mode, radio mode or CD mode. To enter CD mode, press the power button and then the CD button. To enter radio mode, press the power button and then the radio button. To enter standby mode, press the power button.
If you're in standby mode and press the time set button, the clock digits will blink. If they don't blink, you aren't in standby mode.
Dec 28, 2008 | TruTech Clock Radio
Sony tv model KP53V25
After movement things to try; 1) make sure a/c outlet is working, try with lamp, notice bulb brightness. 2) disconnect all cables from tv 3) unplug tv from a/c out let for 2-3 minutes plug back in. 4) still no work? count blinking of light; eg two blinks slight pause six blinks= fault code 26. Repost.
Feb 22, 2008 | Televison & Video
Trouble code: Standby LED blinks 9 times
Try pushing the buttons on the remote and let me know what comes up on the screen if anything.
codes.
Jan 13, 2008 | Sony KP-51WS510 51" Rear Projection...
TV won't turn on, red lights blinks twice.
The blinks can tell you the problem , is it 4 blinks that could be 3 different ics IC1509 Q1505 or IC502
Aug 06, 2007 | Sony KV-32FS13 TV
Televison & Video Logo
156 people viewed this question
Top Televison & Video Experts
Electro Med Services...
