Question about Sanyo Refrigerators
The unit doesn't get cold. It just makes a click a clicking sound..
  • Sanyo Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 14, 2011
I have a 2001 Ford Focus DOHC. Heater doesn't blow hot. Hot cold indicator switch clicks as i9t should when I turn indicator but it doesn't seem to change anything
Feel your heater hoses and see if they are getting hot..If so when your click from the switch ,,make sure the door is switching from hot to cold
Sep 16, 2011 | 2000 Ford Focus
Heater making clicking sound when change temp from cold to hot. doesn't make noise on cold just on hot.
Is it a gas heater? If so the clicking you are hearing is the igniter trying to light the heat exchanger.
Sep 04, 2011 | Heating & Cooling
I have a hairer wine cooler,m#BC112G. It wont start, cool, or run.'I have reset the thermostat several times, unplugged it for 72 hrs, and am sure there is power to the unit. When it is plugged in, it...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 17, 2011 | Refrigerators
Air conditioning cycling on and off to fast, does not seem to know when to shut off, clicking or shut off sound when it wants to shut off but doesn't it keeps running. It is blowing ice cold air.
It sounds to me like the thermostat needs replaced. If what you hear clicking noise but the unit does not shut down that is probably the problem. Thank you.
Jul 25, 2011 | Dometic Rooftop RV Air Conditioner
The monitor doesn't have sound and microphone It doesn't play any sound ,music or tones
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it:
if your computer came with a motherboard disc the sound drivers could be on it:
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps:
Jul 07, 2011 | Computers & Internet
The freezer doesn't work, refigerator does. it periodically make a clicking sound and water is dripping from the freezer door.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Jul 05, 2011 | Maytag PTB2154G Top Freezer Refrigerator
The freezer side of this unit quit freezing. Everything is thouging out. Fridge side isn't as cold as it used to be. Both controls have been set on factory recomemded settings since install. I keep...
A popping noise? Could it be the clicking of a relay? There is a relay that activates the compressor that could cause a clicking sound if it doesn't hold. A popping sound could be a bad capacitor but normally isn't a continuous popping sound, unually only one pop.
If the unit is only 4 monthes old it should still be under warranty and you should call it in for repair.
Jun 16, 2011 | Refrigerators
Very low volume HK 695-01
There are several ways in which you can increase the volume.
First, the most obvious way is to use the volume control attached to the speaker unit itself. If that isn't working, there's also an icon in the lower right-hand portion of the task bar in Windows. Simply click the ^ button, select the icon that looks like a speaker, then drag that up to your desired preference.
If that doesn't work, click on Start, go to Control Panel, click on Sound, then search for your Speakers in the "Playback" tab. First, make sure it's set as your Default Device. There should be a green check mark in it. Double click on those, select Levels, then make sure Play Control is set to maximum.
If that doesn't work, then check the settings on your Sound Card. Make sure the wire going into the back is plugged in properly. You may need to update your sound card drivers. If you aren't sure who the manufacturer of your sound card is, you can find out by going to Start > Control Panel > Device Manager. The Manufacturer will be under Sound, Video and Game Controllers.
Once you have that information, you can go to the Manufacturer's website and update the Drivers. If this doesn't resolve the issue you are experiencing, or if you require more specific / additional information, simply respond to this thread. I'll be happy to assist you further.
Regards,
Aaron Busch
Senior Tech of LiveFix Support Services (LiveFix.net)
May 03, 2011 | Harman Kardon HK695 Computer Speakers
Kenmore freezer on top refrigerator is making a clicking sound and some cool/colder air is being blown into the unit but not keeping cold enough. Any suggestions?
sounds like the main board has failed . if this unit is g e made the clicking sound is the relay on the board / a very common problem with g e units. mm
Jan 18, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
141 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
