Question about Cameras
My zoom stucked when i on my cam the it will not return still in open possition
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 14, 2011
2002 Chevy trailblazer 4.2 I6 P1345 code keeps returning
The following conditions may cause this DTC to set:
If this DTC sets, there is a problem with the camshaft position actuator solenoid high control circuit shorted to voltage or the solenoid stuck open.
An improperly torqued harmonic balancer
A misbuilt or mis-timed engine
A loose or missing crank damper bolt
The camphaser solenoid stuck open
The camphaser stuck in a position other than 0 degrees
The camphaser does not return to 0 degrees within 16 seconds
Oct 15, 2015 | Cars & Trucks
Zoom error olympus
Lens is out of possition and stuck.
Jul 31, 2014 | Olympus Camedia Cameras
Zoom lever gets stuck
Very slight lubricating spray should suffice ..... but see to it that its very little .....
Oct 30, 2012 | FUJIFILM FinePix F200EXR Digital Camera
Zoom button stuck on full in zoom
Possible that the zoom switch is short or struck in action where by the zoom has gone to the extreme end. Wriggle the switch after the cam is switched off and see if it returns. If not the unit must be opened to check for the switch failure or possible motor failure, drive circuit or a mechanical jamming.
Nov 30, 2011 | Canon MVX200i Mini DV Digital Camcorder
1997 volvo 960 2.9 liter cam possition
zoom-icon.gif Zoom 1997 Volvo 960 Crankshaft Position Sensor Beck Arnley BECK ARNLEY ENGINE CRANKSHAFT POSITION SENSOR -- A high quality, direct fit OE replacement engine crankshaft position sensor. Condition: New FITS (ENGINE/CHASSIS) SKU PRICE QTY 1997 Volvo 960 BEC1800432 $49.85
  • 1997: All Submodels; All Engines;
    is this what your looking for 1-800-262-0795
    Dec 09, 2010 | 1993 Volvo 960
    The hook on my latch assembly wont grab the loop on my hood.its stuck in the open possition. the cable doesnt return and the handle is loose. the truck is a 97 f-150 pick up.
    the hood release cable is stuck inside the plastic sheath, you can try spraying with WD 40 repeatedly and let soak in between cable and sheath and using needle nose pliers gently try to slide cable back and forth but most likely the cable needs to be replaced.
    Jul 16, 2009 | 1997 Ford F150 Regular Cab
    Cord will not remain OUT..keeps slip-sliding back in
    The return is stuck on your cord retractor. Take the machine apart untill you can see the retractor, then there is a button or wire that retracts the cord. If it is stuck in the down possition simply reset it, if it is broke you must replace the complete cord retractor.
    Apr 11, 2009 | Hoover S3755 WindTunnel Bagless Canister...
    Zoom lens stuck / jammed
    how old is the cam
    i'd be taking it back and trying again to have it replaced
    most stores don't want a bad rap so they'll fix it or replace it
    Aug 18, 2008 | BenQ DC E600 Digital Camera
    Digital camara zoom
    samsung digitmax d73 zoom lens will not retract, just pull lens outward gently it will click, then turn on camra ,you should be able to zoom now turn off camra lens should return & close
    hope this helps
    Oct 17, 2007 | Samsung Digimax S600 Digital Camera
    Cameras Logo
    11 people viewed this question
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
