Question about Amana Washing Machines
Amana Washer mdl LW8303W2, mfg. PLW8303W2B: Washer intermittently seems to skip past end of cycle. Is this strictly a timer issue or is there something else that could cause the timer to continue into the next cycle?
5 Suggested Answers
SOURCE: Amana Heavy Duty Extra Large
my heavy duty 7 speed motor cut off because of over heating and the belt was changed can you suggest a suitable model of fan belt for it. ?
Posted on Aug 20, 2008
localwonder
  • 6784 Answers
SOURCE: TIMER ON WASHER MAKES A TICKING SOUND DURING CYCLE
HI, this timer is faulty and, these are early warning signs of potential failuer of this device in the near future. i would prepare to replace the timer control soon. the actual mechanism is showing signs of breakdown.
Posted on May 23, 2009
jumptrout51
  • 3361 Answers
SOURCE: Amana top load clothes washer dial malfunction
Bad timer. Replace it.
Posted on Jun 08, 2009
SOURCE: what size is an Amana
I had the very same question, so I can buy a replacement that is just as big. Not finding the answer online, but only your question, I measured mine and calculated the volume at about 2.5 cubic feet. I am surprised it seems so small, because it is labeled as an extra large capacity. Of course, it is now about 15 years old, so maybe the new ones are mega washers or something. I wonder if I will get that much time out of a new one.
Posted on Feb 08, 2011
Timer stops intermittently during spin cycle
When it stops try wiggling the timer knob if you get it to start most likely have a timer problem not connecting inside the timer. Hope this helps
Jan 03, 2018 | Kenmore Whirlpool Washer Timer 3351811...
What size is an Amana washer LW8303W2
Jan 17, 2011 | Amana NAV2335A Top Load Washer
The machine completes 2 cycles instead of 1
Based on your description of the problem. The only way this can happen is if the timer is faulty. It is simply skipping the intended end time and continueing the cycle. However when is the timer, it usually wont run correctly for both cycles..but it sounds like you may have sort of lucked out on how it has become faulty. Hope this helps.
Thanks
Nov 22, 2009 | Amana Washing Machines
May 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
The selector for the spin cycle intermittently does not work
Yes. It is a timer. A lot of time though, the washer stop because the lid control switch is open. I means the washer has a sensor to stop when the lid is open or when the spin go widely unbalanced. Sometimes this sensor is too sensitive to vibration and stop the machine. The switch is in the back just behind the timer.
Jul 21, 2008 | Amana ALW480DA Top Load Washer
My Amana top load washer does not spin when it gets to this cycle and just "hums". Suggestions?
You probably have a motor issue, Have you checked the spin in the other cycles, if the washer spins in other cycles its not the motor, its a timer issue.
A new motor will cost you $120 american and a timer will cost you about 85. try repairclinic.com or partselect.com.
Price out replacing the washer vs fixing it.
Jul 11, 2008 | Washing Machines
Skipping throygh cycles
Timer ? Are you referring to the main control board ? How much extra water is being added on the first cycle ?
Jan 14, 2008 | Maytag MAH6500 Neptune Front Loading...
How do you remove the knob off the Timer?
look for a small hole along the side of it that may hold a set screw...turn the screw counterclockwise...the screw may be a hex-head
May 24, 2007 | Amana NAV5805A Top Load Washer
Washing Machines Logo
74 people viewed this question
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
