Question about Olympus Stylus 7010 Digital Camera
I own the Olympus Stylus 7020 and have been having troubles since I turned it on and the optical zoom went out and then the camera shut off because there wasn't enough battery. So I took the battery out and charged it fully and replaced it back in the camera and proceeded to turn it on. When I did, the power light flashed and it sounds like the camera is trying to turn on but the zoom stays out and the camera shuts off. So I charged the battery again to see if that would make a difference, but it didn't. If I turn the camera on while it is on the 'play' setting, the camera will turn on so I can view the pictures but if I switch it to another setting the camera will turn off. What is the deal?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 14, 2011
Olympus stylus 7030. No zoom function when using video setting?
The optical zoom will not work while recording video with sound. To use the optical zoom, turn the sound off. See pages 16 and 33 of this manual.
Jan 06, 2013 | Olympus Stylus 7030 Digital Camera
Zooming with Olympus Stylus 820
Hey missy0528,
There are a few reasons your images might be grainy, one of which is your image quality is set to low. I would always have the camera set to the highest resolution possible, because you can always reduce the size of an image but you can never make it bigger. Another cause of grainy images in digital cameras is the sensitivity of the camera (ISO) is set to high. Since you are only seeing grainy images when you use the zoom the reason for the grainy images is most likely do to using the digital zoom. All a digital zoom does is crop the image much as you can do in some computer applications, and by doing this you greatly reduce your image quality. I would never use a digital zoom. Your camera has a 5x optical zoom and a 5.6x digital zoom. I would only use the optical zoom. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 09, 2008 | Olympus Stylus 820 Digital Camera
Zoom
Hey bello205,
This camera does not allow the user to actually turn off the optical zoom, but does allow the user to shut off the digital zoom. If you are talking about the digital zoom make sure it is turned on in through the menu system. As far as the optical zoom goes make sure you are not in playback mode. If this doesn't work you can try having the camera reset to the original settings every time you shut off the camera by choosing this option under the setup menu in playback mode. If none of this works have the camera looked at by an authorized service technician.
Sincerely,
Allan
Go Ahead. Use Us.
May 01, 2008 | Olympus Camedia C-720 Ultra Zoom Digital...
Trouble when Zooming
well did the camera got wet???, if soo it needs the mainboard to be replaced, if not could just be the mainboard also, but if it´s the second one the repair centre will fix it for free if ?t´s under warranty
Jan 30, 2007 | Olympus Stylus 720 SW Digital Camera
More telephoto zoom
The Stylus Verve has a 2x optical zoom and a 4x digital zoom, which gives you a total zoom of 8x seamless zoom. Use the shooting mode menu to activate the digital zoom feature.
Sep 01, 2005 | Olympus Stylus Verve S / ?-181 mini S...
Options for telephoto zoom
Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
Telephoto zoom
The Stylus 500 has a 3x optical zoom and a 4x digital zoom, which gives you a total zoom of 12x seamless zoom. Use the shooting mode menu to activate the digital zoom feature.
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
Olympus Stylus 7010 Digital Camera Logo
77 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
