Question about JVC CP6U Adapter
I have a JVC C-P6U Cassette Adapter,I have not used it for some time as there was a cassette inside I put it in my TV and played the tape which was great when it was finished I wanted to remove it and play another cassette but could not remove same from the adaptor.There is a little switch at the bottom with an arrow I assume that was to release cassette to no avail Canyou help
  • 902 Answers
The adapter is probably jammed you may need to use a little force for the switch also a little force to try and pry it may work without damaging it. please let me know if this helps if now i will glady do more research on it for you but this is what i found when i was looking up the adapter issue.
Posted on Mar 14, 2011
  • Precious Hollinger
    Precious Hollinger Dec 09, 2011
    I also have a problem. it sounds to me that the person with the problem and i have the same kind of cassette adapter. my problem is taking the tape out and putting another one in. it too has been so many years that i have forgotten how. could you help?
8mm JVC tapes put into a VHS tape that will play on a combined TV and VCR. Please, please, I need your help! Found tapes from 15 years ago.
You need an 8mm player or the camera that recorded the tapes. Connect the video and audio from the 8mm player/camera to a VHS recorder. Put the 8mm on play and the VHS on record.
Jan 08, 2015 | JVC P-6120JDU Video Cassette, 8mm 120...
Cassette adapter for toyota harrier
sounds to me like your tape belt in the other motor has broke ,the drive for the tape deck has a rubber band putting it crudely and these belts are a special rubber ,it should be a easy repair but make sure you get the right size rubber band but they must be made for a tape deck and not one from office draw
Apr 27, 2012 | Lexus RX 330 Cars & Trucks
How to open jvc c-p6u cassette adapter?
Change the AA battery. I did and the switch worked and it ejected.
I had no idea there was a battery involved.
Panel on left end
Aug 15, 2011 | JVC CP6U Adapter
Casstte Player- '94 ford
I think you are saying you are using a cassette adapter to play the external iPod/PSP etc. and I presume the cassette plays regular tapes OK. The auto-reverse cassette player thinks the 'tape' is over, so reverses then ejects. You can try putting in a regular tape, change sides then eject. Try the adapter again. Hopefully the adapter will work in 'one' direction.
Apr 13, 2009 | Car Audio & Video
Can get my cassette adapter for my ipod to work it keeps ejecting the cassette
I also have a '95 ford explorer. Same problem. I took the screws out of the tape and opened up the adapter. I took out all the gears EXCEPT for the one large one in the middle two on either side. Now it works perfectly.
Nov 19, 2008 | Audio Players & Recorders
1995 Saab 900S Left speaker doesn't work when using tape player
sounds like the cassette adapter has a bad channel, or didn't fully seat into place. Try removing and re inserting, to play the other side of the adapter if the wires will allow it. Then auto reverse the cassette deck to allow a different portion of the cassette head to be used for the signal. Those cassette adapters are poor quality, and put alot of time on the mech.
Jul 12, 2008 | 1996 Saab 900
Jvc HR-S9700 -TAPE JAMS, THEN SWITCHES OFF,CASSETE DOOR REMAINS OPEN,DOES NOT ACCEPT OR PLAY
the switch is on the electronic board under the tape compartment. you have to unscrew the screws and unplug all the wires to take it out. be careful though, you have to put it back the way it was otherwise you will mess up the machanisim on that machine. good luck
Aug 18, 2006 | JVC HR-S9500 S-VHS VCR
JVC HR-S9700 TAPE STUCKS, HAVE TO BE PULLED OUT, CASSETTE DOOR REMAIND OPEN,VCR SWITCHES OFF-CAN NOT BE PLAYED AGAIN
Check out the drive that works the unloading and loading operation of your machine. Also check the switch that is activated by the presence of your cassette. If something is wrong with the latter, the tape will not load and unload properly. And under those circumstances your machine will not work.
Try Google search for your questions. You may get lucky and get the answers right there!
Mar 13, 2017 | JVC HR-S9600 S-VHS VCR
My VCR is egecting the tape with the casstte adapter.
The cassette adapter uses 1 AA battery. When you place your VHSC tape into the adapter and close the cover, you will hear the motor running and the red piece on the adapter will move inside. Check the placement of the battery and make sure the clear shrink wrap has been removed from the battery
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
JVC CP6U Adapter Logo
1,764 people viewed this question
Top JVC Cameras Experts
Michael Galve
Michael Galve
Are you a JVC Camera Expert? Answer questions, earn points and help others
