Question about Holmes Products HAOF90-UC Table Fan
How do I disassemble the Holmes Haof90 fan to clean the blades?
4 Suggested Answers
  • 168 Answers
SOURCE: grinding of fan
There should be a black round nut in front of the blades in the very center. It will have ribs on it so you can grab it. Turn it Counter clockwise, and it should unscrew.
Then you can remove the blade assembly and get to the back cage to tighen the screws.
This should take care of the problem.
Re assemble in reverse order.
Let me know if you have any more questions or if this doesnt work.
Good luck.
Mac
Posted on Sep 11, 2008
SOURCE: i have a holmes blizzard fan and need to clean the
Turn the fan around there are four screws on the backside of the grille. You will need a long philips head screwddriver.
Posted on Jul 13, 2009
ZJLimited
  • 17970 Answers
SOURCE: I can't get the shield
Additionally this diagram information could helpfull: SAF-16%20Stand%20Fan.
Hope helps.
Posted on May 31, 2011
What size fuse for this fan?
Divide the power in watts by the voltage and this will give a figure in Amps. The fuse should be slightly above this. ie; 1.2kw (1200w) divide by volts(120) = 10(Amps) Fuse should be around 10-12 amps. If in doubt consult the handbook or an electrician.
Nov 18, 2014 | Holmes Products HAOF90-UC Table Fan
How do I get the front cover off the Holmes table fan HAOF90?
Should be three clips that fold over the outer cover pry up clips with a screw driver.
Jul 21, 2014 | Holmes Products Dryers
How to clean this fan does it come apart
If you have a air compressor with a blowgun use that, otherwise a can of electronics duster will do the job. Otherwise some of those little fans have 3 or 4 screws around the plastic shroud removie those and you should be able to access the fan blade.
Of course try all this with the fan unplugged
Aug 15, 2013 | Holmes Products HAOF90 Table Fan
Hdf1209
your motors thermal fuse has burned out you have to buy a new fan sorry but they are made so cheaply unlike the ones that i have which were made in the 70's and are still working but those fans have a thermal fuse and if you let the on for too long they will burn out
Dec 31, 2011 | Holmes Products HAOF90-UC Table Fan
My fan is not rotating when I connected to plug. There is no burning smell or anything. How can I fix the problem? Thanks in advance
Hello.
I have a Holmes pedestal fan that does this every few years. I have had this fan for about 10 years.
Unplug the fan and remove the fan blade guard. The fan blade should spin easily when you tap the edge of the fan blades with your finger. If the blade barely moves and abruptly stops, the bearings are dirty and need to be cleaned and oiled with 10W non-detergent motor oil. A quick-fix is a tiny bit of WD-40 where the motor shaft (the rod that the fan blade is mounted on) meets the bearing (the part of the motor that the shaft spins on). To properly fix this, you must oil both the front and back motor bearings which requires removal of the motor housing.
If the fan blade spins easily and you are certain that the fan is getting power (try a different outlet) the motor may be bad. Likewise, if the fan blade will not move at all. I do not know if Holmes sells motors for these fans. Here is their online support website:
www.holmesproducts.com/Support.aspx
Good luck from Detroit, MI.
P.S.: Never turn a motor-operated appliance on for more than a second if you know it's not working. That will cook the motor windings.
Jun 12, 2011 | Holmes Products HASF1710-UC Stand...
I have a holmes blizzard fan and need to clean the blade. how do i take the front cover off
Jun 30, 2009 | Holmes Products Holmes HAOF951T-U Blizzard...
Fan turns very slowly for a few seconds and then stops
it may have pulled in some hair around the shaft. disassemble and clean
Jun 24, 2009 | Holmes Products HAPF622R Floor / Box Fan
Cleaning the fan
There are 4 small screws in the rim between the ribs accessible from the back. Remove the screws and the cover will come off.
Jun 18, 2009 | Holmes Products Holmes HAOF951T-U Blizzard...
I can't remove the grill above the fan so I can clean the blades
I have a Holmes cool-mist One-Touch Humidifier, and you can't reach the blades to clean them, and you can't take the console apart. I finally decided to use two spray bottles and clean and them rinse the Humidifer while holding the console upside down and over a sink. The one bottle you could fill with any mild cleaner plus a lot of water to dilute the cleaner. Maybe dishwashing liquid (not the dishwasher stuff), or a little bit of ammonia, or rubbing alcohol, or vinegar. Spray that on the blades while the machine is upside down, and a lot of sooty dirt drips out. Then rinse with another spray bottle full of plain water. Leave the console upside down on a towel to drip-dry. This is also how you can clean silk flowers that collect dust.
Mar 07, 2009 | Holmes Products Cool Mist HM3500...
Holmes Products HAOF90-UC Table Fan Logo
1,319 people viewed this question
Top Holmes Products Dryers Experts
Jay Finke
Jay Finke
James Coghill
ray gallant
Are you a Holmes Products Dryer Expert? Answer questions, earn points and help others
