Question about Whirlpool ADG450 Slim-Line Built-in Dishwasher
My dishwashers water will not drain. The water is standing at the bottom. I already tried drano, and nothing happened. what else do i do?
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Mar 14, 2011
Dishwasher flooded
That happened to us and our plumber came. He said our pipe under the sink was bent up so the water wasn't draining properly. Also, check for clogs. Use Drano or a snake to get all the gunk out of the drain.
Jan 03, 2015 | Whirlpool Dishwashers
Start light flashing. Dishwasher wont start
I'm guessing as you did not list the model number. Something similar happened on mine. Due to a freeze, there was a small crack in the inlet and water had slowly leaked. As a safety feature, the Asko has a tray under the dishwasher inside the overall dimensions. It has a float. When the float rises, the drain pump starts and the dishwasher will not start. In my case, the drip pan is not connected to the drain which gave me the drain sound, but did nothing to remove the leaky water.
I suggest you take the front bottom panel off the dishwasher and check for water/leaks.
Oct 29, 2014 | Asko 24 in. D3121XL Free-standing...
Kenmore ultra wash II dishwasher has standing water in bottom of washer Where can i pour drano
no drano but a lot of tomes the drain hose under the sink where it drain into the garbage disposal needs to be looped up when you use the sink where the disposal is it drains back down into your dishwasher
Dec 15, 2013 | Dishwashers
Hello the bottom of my dishwasher keeps filling up with water. How can i fix that??
The problem may be in one of several places, here's a list of things to try, starting with the easiest and progressing to more difficult:
1. Run your hand around the bottom of the pool in the dishwasher looking for paper or cellophane that may be covering the screen of the drain. 2. Disconnect the drain hose from under the sink (get a bucket and rags) looking for a clog at that point of connection. Run the dishwasher drain cycle while you have this hose pointed into a bucket - if nothing comes out, the problem is between points 1 and 2. 3. Partially remove the dishwasher so you can get to the drain hose where it connects to the dishwasher. Temporarily put another drain hose on it, with the other end in a bucket. Run the drain cycle of the dishwasher. If it comes gushing out, the drain hose is clogged. If it still won't drain, your will need some disassembly of the drain & pump. good luck, Al K
Dec 21, 2010 | Mx Commercial Line Drano Max Clog Remover
There is a lot of standing water on the bottom of the washer and it just wont go down. Tried using DRANO but it didn't work at all.
if you have had a new garbage disposal in stalled then make sure the plug has been taken out of it.
If you have a wet dry shop vac you can use it to drain the water from th unit by attaching it to the end of the drain hose. if the water comes out easy you may have a faulty pump if it comes out kid slow then there is a restriction some where in the line of the sump area of the dishwaher and needs to be cleaned out.
Nov 24, 2010 | Dishwashers
Water staying at the bottom of the washer.When i close the washer an press start the inlet/drain light comes on and nothing else happens.Miele G 692 SC PLUS
Your drain outlet is blocked , pull all the filters out and then check nothing is stopping the impeller from turning. You have to bucket out all the water first of course. It can be a toothpick or just some gunk,
Mar 25, 2010 | Miele 24 in. G692SC Plus SS Free-standing...
Water not pumping into dishwasher
I first checked the water valve in the dishwasher. It was working properly. The overflow or water level sensor had become stuck in the 'high level' position, thus telling the washer that it was already full of water. I corrected that and it began working properly. As for water in the bottom of the dishwasher that didn't seem to be draining completely - I turned the timer to a point in the cycle where it would drain, making sure I turned the washer off before it cycled back to the 'fill or rinse' cycle. I think the water had accumulated because of the timing of the cycles getting out of sync with the water level in the washer.
Jan 06, 2009 | Dishwashers
Dishwasher overflowed out of d/w during wash cycle; not draining
2 things to check
First turn off the power(breaker box to dishwasher and sdisposal
open the doors to your sink and and check the hose for any kinks etc
open the dishwasher door, bail out water remove the spinning hub and see if you can remove
the strainer and bail out more water
you can use a baster to **** out more to view
to see if the pump area is plugged
reverse proedure and turn on dw
listen to see if the pump engages on that cycle
hopefully this solves problem
If the pump does not engage you wil need to call for service
Jan 01, 2009 | Mx Commercial Line Drano Max Clog Remover
Dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Whirlpool ADG450 Slim-Line Built-in Dishwasher Logo
506 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
