Question about VTwin Horizontal OHV Engine with Electric Start 670cc GX Series
Why is my 24 hp fouling one plug and smoking. What could be the fix.
  • 48 Answers
Sounds like it has a bad cylinder and the oil bypassing is fouling up the plug in that cylinder. Do a compression test on the cylinders to see if they are both the same and match what they should be. If it a bad ring that is causing the problem it will have to be rebuilt. Check the cylinder walls to see if it is worth rebuilding before you spend too much on it
Posted on Mar 14, 2011
  • gphox Mar 15, 2011
    What kind of compression should be on each cylinder. What is the spec. measurement for the bore. thanks
  • tiltdeck Mar 15, 2011
    Sorry but i don't have that info at hand but I am sure if you look online at the manufacturers website or email them you will be able to get it.
97 CAVALIER Z-24 UNDERSIDE OF THE CAR GETS SO HOT IT SMOKES YET THE ENGINE DOESNT GET HOTALSO IT IS MISS FIRING
Everytime it missfires the unburned fuel will be burned in the catalytic converter. Hopefully you can get it tuned up before the cat. conv. is ruined. Plugs, wires, coils etc. While the plugs are out run a compression test . Look at plugs for oil fouling at that age valve stem seals sure could be an issue and feeding oil into the exhaust system fire you have going on.
Dec 30, 2016 | Cars & Trucks
Spark plugs foul immediately
Fouled plugs may be caused by oil leaking into the cylinder. Does it smoke when running (cold), are you using up the crank oil. Black smoke is excess gas comsumption, blue smoke is oil burning. If your plug is fouled with black carbon, you are most likely running to rich.
Apr 07, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
Truck starts but stops immediately and smoke comin out of my tailpipe
Well it depends on the color of smoke if it's WHITE; it could be a blown head gasket (check coolant levels and then oil to see if it is milky looking) BLUE: could be burning oil, which could result to fouling plugs (check spark plugs for fouling) BLACK; too much fuel flooded (check spark plugs for fouling)
Oct 12, 2013 | 2000 Chevrolet Blazer
Husky 18 hp tractor smokes white and fouls plugs
Sounds like you got blown head gasket.
Mar 24, 2012 | Husqvarna Garden
Help with 76 ironhead 1000 fouls plugs when it get hot and it wont charge
Ok, you have two problems. Fouling plugs and charging system problems. Work with one problem at the time. I'd work on the plug fouling problem first. What is fouling the plugs? Is it oil or gasoline fouling the plugs. Take one of the fouled plugs out and smell of it. Is it gasoline or oil fouling the plugs? If its gasoline, you have a problem with the carburetor. In this case, I'd need to know what kind of carb is on the engine. Is it the original Keihin or has someone put an aftermarket carb on the engine? Do you know how to check the jet sizes in the carb? If it's oil fouling, is it due to valve guides or rings? Does the engine smoke from the tailpipes? What color is the smoke? Black or blue smoke is caused by a too rich fuel air mixture. White smoke is oil burring.
As for your charging system, the first thing to do it to polarize the generator by momentarily shorting the positive battery post with the armature of the generator. If the generator still does not charge, you need to check the brushes in the generator and the output of the generator.
Good Luck
Steve
Jun 13, 2011 | Harley Davidson XLH 1000 Sportster...
I just got a 2000 zr 7 and it has good compression but smokes after a few minutes of running. The far left cylinder fouls the plug, as I said it has good compression, but has been sitting for 3 years, how...
What color is the smoke? A blue-ish smoke is burning oil, a blackish smoke is unburnt gas. If the plug fouled with gas or oil? Does the plug foul at idle, or while riding it? Full throttle? or partial throttle? Answer those questions and you will know if you have a an oil leak in the head or overly rich mixture at idle, or during an open throttle position.
It sounds like too much gas (since you say it has good compression -- did you do a real compression check?). I'd get the carbs synch'ed and make sure they all have their idle mixture screws set correctly.
Dec 16, 2010 | 2000 kawasaki ZR-7
I have a briggs 24 hp twin v intek engine, started smoking last year with only 50 hours, now with a little over 60, it smokes like a steam train and uses 1 qt oil/30 min. Last week it fouled a plug, I...
Double check that the head bolts are properly torqued.There is a crankcase breather if stuck open could be drawing oil into the intake, and there is a valve stem seal on each intake valve that could be leaking. All this is assuming that the oil level is not over full. They will smoke like a banshee if they have to much oil in them.
Oct 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine smoking and missing
too much oil...drain it (all of it !!) and refill with "no more than" 2 qts...keep checking it as you fill...now...since it has been smoking, it will for a while until the oil residue in the muffler is burned out...also, replace the plugs...cleaning is no guarantee that they won't foul out...
Apr 27, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Gpz1000rx number 1 cylinder fouling spark plug, causing miss fire and light blue smoke
Your cylinder is worn. Its allowing oil past the ring. The oil is fouling the plug and the burning oil is causing the blue smoke. After 22 years the Kawi needs a freshened up top end.
Feb 20, 2010 | 1988 kawasaki GPz 1000 RX
My B & S fouls plugs, runs rough, almost stalls when blade
THE PROBLEM SOUNDS LIKE THE CARB IS RUNNING TO RICH OR TO MUCH GAS IS BEING PUMPED INTO THE CYLINDER. IS THERE ANY SMOKE AND WHAT COLOR SMOKE
Jul 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
VTwin Horizontal OHV Engine with Electric Start  670cc GX Series Logo
131 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Spud Howell
Mike Carew
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
