My Accel a Writer 4N does not have display when powered on. If I press and hold the "online/ready" button on the display panel and then power on the printer, the panel shows "Main code abort" "-----Release keys----" Please advise which part of the controller is causing the problem. Thank you .
We had the same problem occur on the same day! We don't have any display and it won't print.
Posted on Mar 15, 2011
How do I reset a hp LaserJet 3055
Soft reset:
1. Press Menu. 2. Simultaneously press and then release the * button and the # button to open the developer's menu. 3. Press the < or > button until the message REINIT FFS appears on the second line of the control panel display. 4. Press . 5. The process takes approximately 2.5 minutes. During that time, the control-panel display will change several times before returning to Ready. 6. When the Ready message appears on the control-panel display, press Cancel to exit the developer's menu.
NVRAM reset:
1. Turn off the all-in-one. 2. Press and hold down the * and 5 buttons. 3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout the entire power-on sequence. 4. When Permanent Storage Init. appears on the control-panel display, release the buttons. 5. When prompted, set the language and telecom country/region. 6. Allow the all-in-one to return to Ready before using it.
Best of luck..
Oct 12, 2014 | HP LaserJet Office Equipment & Supplies
12345 also canot..
just format it by following my simple instructions.
with yo 4n off press the buttons [*],
[3] and the green(calling button) at
the same time them switch on yo 4n
while still holding the buttons (note
that u'll lose any data on the 4n)
please notify me when it works on facebook just search for Eng Kasule
Ronald
Jan 16, 2012 | Nokia 6630 Handheld
May nokia 6630 will always restart and i forgot my password for format it pls help me
Ronald
Oct 11, 2011 | Nokia 6630 Handheld
My Xante Accel-a-Writer is not communicating with my macmini. I understand that OSX 10.6 doesn't support appletalk, and have configured the xante as an LPD printer and entered its IP address. The mac...
First, I would recommend that you connect the Xante Accel-a-Writer to a Windows OS computer (xp/vista). Observe if it will function perfectly. This will determine whether you are doing something wrong or if the problem is from the Xante Accel-a-Writer or if they don't support each other.
You can test the Xante Accel-a-Writer on a friends windows OS computer if you don't have one.
Let me know the out come so that I can direct you further.
Good luck.
Oct 19, 2010 | Office Equipment & Supplies
When trying to print it says
HP LaserJets - Cold Reset Instructions Cold resetting a printer resets the printer to factory defaults.Please note: Any settings you make at the printers control panel will be reset to factory defaults, including the IP address if you have a JetDirect card installed. Remove the JetDirect card while you cold reset the printer if you don't want to erase the JetDirect card's settings.
You can also reset the NVRAM. Resetting the NVRAM will clear the page count and reset the service mode settings to factory defaults. On printers with a display panel you need to enter service mode to manually change the information stored in NVRAM. On printers that don't have a display panel, such as a 5P, 6P, 2100, 2200 there is a different procedure outlined below.
"Older" printers with a display panel. (e.g. 4000, 4100, 5si, 8000, etc.)
Cold resetting the printer is simply a matter of turning the power off, holding down the GO or Online button while turning the printer on.
Resetting NVRAM settings must be done manually through service mode. See entering service mode.
"Newer" printers with a display panel. (e.g. 2300, 2400, 4200, 4250/4350, 4300, etc.)
Turn the printer off and then on. When the printer begins its memory count, press and hold down the Checkmark button until all the main LED signal lights illuminate and stay illuminated. Then release the Checkmark button, and use the Up/Down arrow keys to find the Cold Reset option, then press the Checkmark button again to choose that option.
Printers with no display panel.
HP 1100, 1200 - While the printer is on, press and hold the Go button for 5 seconds. This will reset the printer.
To reset the NVRAM. Turn the printer off. Press and hold the Go button for 20 seconds while powering on the printer.
HP 2100 - To perform a cold reset, turn the printer power off, then press and hold the JOB CANCEL button. Turn the printer power back on and after all the LEDs come on release the JOB CANCEL button. A cold reset changes most system parameters in NVRAM to the factory defaults. The JOB CANCEL button must be released within 20 seconds after all of the LEDs come on; otherwise, an NVRAM initialization is performed instead of a cold reset.
HP 2200 -
Cold reset:
1. Turn the printer power off.
2. Press and hold GO.
3. Turn the printer power back on and continue to hold GO until the Attention light turns on.
4. Release GO.
5. The device lights will begin cycling from front to rear. The cold-reset process will run until completion and the device will go to the ready state.
NVRAM Reset:
3. Turn the printer power back on and continue to hold GO until the Attention, Ready, and Go lights turn on.
4. Release GO.
5. The device lights will begin cycling from font to rear. The NVRAM initialization will run until completion and the device will go to the ready state.
HP 5P & 6P
Cold reset:
Turn the power off and hold the reset button (button closest to the back of the printer) for LESS than 20 seconds while turning the printer on.
Reset the NVRAM:
Turn the power off and hold the reset button for MORE than 20 seconds while turning the printer on..
Aug 30, 2009 | HP LaserJet 3015 All-In-One Printer
Will Accel-a-writer 4n work running Leopard 10.5.6?
Just download the PPD Installer from here: AW4N_OSX then install the driver. Use System Preferences -> Print and Fax to create new Xante Printer using Default or Apple Talk section of Control Panel.
Jan 02, 2009 | Xante Accel-a-Writer 4N Laser Printer
Hp deskjet 5552 how to reset?
HP LaserJets - Cold Reset Instructions Cold resetting a printer resets the printer to factory defaults. Please note: Any settings you make at the printers control panel will be reset to factory defaults, including the IP address if you have a JetDirect card installed. Remove the JetDirect card while you cold reset the printer if you don't want to erase the JetDirect card's settings.
HP 2200 -
Cold reset:
4. Release GO.
NVRAM Reset:
4. Release GO.
HP 5P & 6P
Cold reset:
Reset the NVRAM:
Dec 02, 2008 | HP DeskJet 5550 InkJet Printer
jasbo
jasbo
