Question about Microwave Ovens
I bought a water filter from Regal Ware, Inc & I need a replacement filter but cannot find one.
  • 112 Answers
Regal Ware customer service should be able to help you. Please call 262-626-2121, or email wbws@regalware.com with your inquiry. It will be helpful if you have the brand name of the water filter available.
Pat Seitz
Regal Ware, Inc.
Posted on Mar 14, 2011
Cleaned my fan oven . try to turn it on the fan will come on but try to turn it up slowly for heat it cuts all the electric off . same with the grill
Could be that water got in some ware ware it shorts to ground and the earth leakage are tripped. I had a similar problem with a microwave oven. You can leave it to dry for a day or two? I left the microwave in the sun for a few hours.
May 10, 2011 | Microwave Ovens
We got a new kenmore frige and when we hooked up the ice maker/water dispen. water came running out from under.
check your connection where you hooked water up to the frig. Also on some models there is a water filter on the front toe-plate. These filters will leak if they have a crack in them, so try replacing the filter first. If the filter and the connection are not the problem, you might have to replace the filter housing. Hope this helps, Clint
Mar 21, 2011 | Microwave Ovens
Regal breadmaker model K6750 instruction book
Regal Ware provides scanned copies of some of their Breadmaker Guide & Cookbooks. For the K6750 see here:
http://www.regalware.com/documents/Breadmaker_Books/K6750_C6750_Breadmaker_Guide_Cookbook.PDF
Mar 19, 2011 | Microwave Ovens
What am I doing wrong. Cusinart 1200 less than a year old. Takes an hour to brew. Took out permanent filter and use paper #4 filter. Has been slow since I bought it. Please advise. Other than that,...
Try cleaning it with vinegar. Sounds like you need alot of help on this one run a full pot of vinegar through the machine. with a paper filter in the basket. then run two to three full pots of just water. this should help decale the coffee pot.
Mar 09, 2011 | Microwave Ovens
I bought Cook's Essentials cook ware many years ago and I have 2 pieces that need to be replaced but i have no idea how or where to send them to be replaced under lifetime warranty, can you help.
There doesn't apear to be a web site for the company. I can only suppose that it is just a trading name.
Try speaking to Argos or QVC.co, for advice but "Lifetime Warranty" doesn't mean anything. The LifeTime of the product could be 21year for instance and probably won't cover anything that has broken.
Have a try, nothing to lose.
Jan 02, 2011 | Microwave Ovens
WMH 1162X VS -1 (watts unknown) Builder purchased
If the oven is set up to vent outside, then the metal mesh grease filters are used, and they should be cleaned in warm soapy water whenever they look greasy or dirty.
If the oven is set up to recirculate, then the charcoal filter is used, and it must be replaced (not cleaned) every 6-12 months, depending on use.
This model does not have a separate cooling fan like most other models. It replies on the vent fan for magnetron cooling, so if the filter(s) gets too dirty, it can reduce the cooling air flow, which can allow the magnetron to overheat and be destroyed.
I would need to know a little more to help narrow down the "no heat" problem.
If the cooling fan, turntable, and inside light all come on when you press "Start" to cook, then I would ask if you here a "thump" when you press "Start."
If so, then the high voltage section is getting energized. If not, then it may be the cook relay on the control board, which I can affordably repair.
The support page for your oven is here, and it has manuals and part lists you can download.
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 10, 2017 | Whirlpool WMH1162XV Microwave Oven
Light won't go on; Model MMV1153WB-O
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Enter it as MMV1153WB0 (no dash, zero on the end, not "oh")
Or just get it here, to be more exact.
On page 4, it says:
"Installing/Replacing Filters and Light Bulbs
■ Grease filter: Grease filter is on the underside of microwave
oven. Clean monthly. Slide the filter away from the tab area,
and drop out the filter. To reinstall, place end of the filter into
the opening opposite the tab area, swing up the other end,
and slide it toward the tab area.
■ Charcoal filter: The charcoal filter is behind the vent grille at the
top front of the microwave oven. The charcoal filter cannot be
cleaned, and should be replaced about every 6 months.
Remove 2 screws on the vent grille, tilt the grille forward, lift it
out, and remove filter. To reinstall, place the filter into its slotted
area – wire mesh side up, replace vent grille, and secure with
screws.
■ Cooktop light(s): The cooktop light bulb(s) is(are) located on
the underside of the microwave oven, and is(are) replaceable.
Remove bulb cover screw, and open the bulb cover. Replace
bulb, close bulb cover, and secure with screw.
■ Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove 2 screws on the vent grille,
tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws."
HINT: Unplug the oven before removing or installing the bulbs, or you may need this service.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. Hope this covers it.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
May 06, 2010 | Maytag Over-the-Range Microwave
Why double filter on Maytag Microwave
If your range hood or microwave recirculates back in to the room.
Both filters are required. The mesh filter catches the grease & air particulate. The carbon filter should be changed regularly www.HoodFilterFactory.com ( avoid range fires that spread quickly) & clears the recirculated air from smoke,odors, & airborne particulate.
With yours venting to the outside, you ONLY need the mesh filter. These filters should be cleaned regularly ( Avoid mentioned hazard) & should be replaced when you can no longer clean them enough to see through them when holding up to the light.
Good Luck
Apr 30, 2010 | Maytag MMV4205 Microwave Oven
LG RefrigeratorModel LFX25960ST - icemaker has been replaced once
Most ice maker heads cost less than $49 to replace if you get it at a wholesaler. The water quality going to it will effect how long it will last, Reverse Osmosis treated is the best, filters will help some but are not a cure. Your budget is the determining factor in this equation.
Nov 21, 2009 | Microwave Ovens
Microwave Ovens Logo
137 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
