Question about HP Compaq Business d530 PC Desktop
Whenever I play a music trick it always stop and start again near the end of the track. What is causing this problem?
  • 902 Answers
Update your audio drivers and try using a diff audio program i suggest winamp or windows media classic
Posted on Mar 14, 2011
Is having trouble reading or tracking disc.I opened top and while playing disc the tracking mechanism goes out then back in and starts playing where it stopped?
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 22, 2015 | Audio Players & Recorders
Tascam cd-rw750 - while recording from another CD player (using digital coax connection), machine records for some time and then just "jumps out of record mode" and goes back to the beginning like nothing...
1. First problem: "like nothing is recorded". IS something recorded or has it been left in Pause Mode so long (instead of Recording) that it just got impatient and time out?
2. Get yourself a couple of CD-RW Digital Audio discs to play with until you're past this learning curve/problem scenario. That way you can always erase them and start over without having to discard the disc.
3. Dropouts on playback. Are they repeatable - always at the same place, even on different CD players? If so, the data is bad on the disc. If not, the data is probably marginal.
4. If you have a DVD player, try to play the failed recordings in it. Some DVD players can play back unfinalized CDR's. You may be able to recover the data by copying it back to the CD Recorder from the DVD player. Just be advised that an unfinalized CD-RW may not have 'silence' following the last recorded track due to old data remaining from a previous session, so be ready to pause or stop the recorder when the last track finishes.
5. "Scratches near the outside of the CD". Were these NOT present prior to entering the CD Recorder? Do they seem to coincide with about where the recording may have failed?
6. 20 vs 19 tracks: Is this a constant problem or only when there is a failure during CD creation? If the latter, it would make sense as the last track in isn't technically completed.
Apr 09, 2010 | Tascam CD-RW750 CD Recorder
I'm recording from cassette tape to CD and cannot figure out how to create a new track when I do it. I remember from the manual (which is lost) that a silence of ~4sec should automatically do it, but that...
Can you name the make and model? Maybe we can find a manual. I find a lot of them at retrevo.com. Just register for free and download whatever they have.
I think you have the 4 second thing backward.
Most CD Recorders will interpret a 4-second silence while recording as the end of a given track and will stop or pause. Some can can be set to leave a blank of 4 seconds between tracks (or not) when manually starting a new track. That can really be a problem on continuous recordings like live music or some classical material where brief silences occur routinely.
On my Pioneer PDR-509 there is a "Track No. Auto/Manual" selection that allows me to write a track manually whenever I want to. This is good for live or segued musical selections and doesn't require a stop/start of the recording. Of course, any time you pause or stop the track number will be incremented.
I can't really speak to the TOC errors. The fault could be with a) your machine, b) the media or c) the playback machine. The TOC is automatically created when you Finalize the disc. My machine takes 4 minutes to write it.
Little-known fact: a CD that is not finalized will not read/play on a CD player but a DVD player might play it from start to finish just fine, but without the ability to skip around because of the missing TOC. Nice to know if you mess up an original irreplaceable CD recording by not finalizing it and need to copy it over.
Jan 30, 2010 | Audio Players & Recorders
I have a Missil A920 MP3 player but always shuffles!
what you need to do is go into the settings area of your player and go to play mode. There is can change the way your player goes through your files. Thank you for using Fixya. hope this helps.
Nov 04, 2009 | Audio Players & Recorders
Technics 373 Dual Cassette - Playback Stops
Suggest having a good clean and replace belts. If it stops around halfway on a C90 or near the end then there's a load problem on the take up reel, before halfway the supply reel.
Dec 13, 2008 | Technics RS-TR373 Single Cassette Deck
Me, again... ^^v;
I would delete and start all over again. It is certainly a pain, but it is the best way. The quickest way to delete all the songs is to format the player inside Windows Media Player itself (I have a tips and tricks entry on formatting an mp3 player for instructions).
Jun 13, 2008 | SanDisk Sansa e260 MP3 Player
DRM
Thge SA6045 does not support DRM protected files. If you are downloading these files from the internet, then you'll have to look elsewhere for files.
If you are ripping your own CDs to .MP3 or .WMA with Windows Media Player, then you need to change a setting in Windows Media Player.
Open Windows Media Player. If visible, click on "Tools" then options. If the menus are not visible, right-click at the top of the Media Player Window, then select "Tools" and click options.
Click on the "Rip CD" or "Rip Music" tab (depending on version).
Remove the tick from the box next to "Copy Protect Music" (or similar)
This will stop DRM protection on any further tracks ripped.
You will need to rip any DRM tracks again.
Apr 25, 2008 | Philips GOGEAR SA6045 MP3 Player
Skipping tracks
Did your music subscription service expire? That would cause it to read every song as zero. Definitely try the rest method first. Disable auto-synchronization feature for all programs that you sync the device to.
Oct 15, 2007 | Apple iPod nano
NaNO 2G Skips music Mp3 Sometimes Stops
In a mater in fact it could be the mp3 the mp3 was copy right protected so it skips and doesn?t let you listen to them.
Nov 02, 2006 | Apple iPod nano
HP Compaq Business d530 PC Desktop Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
