Question about Vtech 5.8GHz Cordless Phone with Digital Answering System
What does alternating leter A on readout mean,and how to cancelled?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vtech Master
  • 102,366 Answers
You've got your answering machine set on announce instead of answer. Since you declined to specify the model of your VTech system, enter it into the search box at
http://www.vtechphones.com/vtechphones/index.cfm/support/general/manuals/
to download a copy of the manual.
Posted on Sep 23, 2011
How can I stop the Samsung gusto 3 from reading numbers of incoming calls.
I believe one of the Accessibility Readout options is enabled. From the home screen, press the Left soft key. Select Menu, then Settings. Go to Accessibility and then Easy-Setup. Check that the following are off: Full Readout, Digit Dial Readout, Alert Readout. (Alternatively, you can look at each of these individually from the Accessibility menu.) There may be other options to check in the Readout options but these seem the most likely.
I hope this helps.
Dec 21, 2017 | Samsung Cell Phones
The digital readout on my dashboard dims during the day. They don't flicker and at night it seems fine. I have a 2002 Mercedes c320
The problem probable is a short to ground on one of ur circuits. when u drive at night u have ur headlights on which forces the alternator to produce more electricity. making it seem normal. or a defective alternator
Mar 30, 2013 | 2001 Mercedes-Benz C-Class
Changing temp readout on Midea Air Con Controller from F to C
  1. Make sure the unit is NOT on lock mode
  2. Press reset button for 2 second or until the Flashinf "F" appear on the temperature display or panel.
  3. Press Add button to change from Fahrenheit"F" to celius "C".
  4. Then press confirm and then cancel button to finish.
Jul 09, 2010 | Heating & Cooling
Our toilet doesn't flush well. what can we do? Sometimes we have to flfush three times and use a plunger before the bowl clears.
HI
Im Rossouw
Ajuste the flout so that the tank takes more water
Recomended would be 3 leters so empty the tank throw 3 leters in and mark the level , then adjust the flout so water fills up to that point
For big pot recomend 5 leters of water.
Plz rate my solution thanx
Jun 19, 2010 | Neptune FB1602 Roma Elongated Front Toilet
The readout is CH. The door are shut . Nothing
if CH blanks , your developer unit not inserted.
no blanks mean that side door or front door is open
May 22, 2010 | Sharp AR-156 Copier
Alarm lights keep blinking after I changed my printer ink.
E5 means cartridges error - to fix press the "stop\reset" button for 5-7 seconds and then release it.
You can also try this:
1) With the printer power turned off but connected to a power source, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4 times----Green (Power)------Waste ink counter resetting
Apr 07, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Copier Canon CLC 2620: What kind of error is E000602-0202 ?
Your error means the waste ink pads are full, its recommended you get them replaced but they should hold out for a bit. to get the printer going again you can follow these steps and reset the counter.
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button.
Oct 22, 2009 | Office Equipment & Supplies
My ge humidifer AHH140LK61 is showing a "P1" readout
Unit is defrosting – Allow the unit time
to automatically defrost. The error will
clear after the unit self defrosts.
Dec 02, 2008 | General Electric AHK30LK Humidifier
I need to know what the error codes 5100, and 5700 mean, and what causes those errors to come up on the screen. Thank you
Try resetting the printer:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Jun 20, 2008 | Canon PIXMA iP90 InkJet Printer
Vtech 5.8GHz Cordless Phone with Digital Answering System Logo
71 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
