I have replaced the old sata drive in an acer 5315 and now it will not boot the vista disc from the external disc drive
    Master:
  • 525 Answers
You have to format your hard drive with special software from acer before you can reinstall the operating system. I had the same exact problem one time.
Posted on Mar 14, 2011
Removing Vista and installing windows xp
Before you attempt it, make a couple of changes in the BIOS to hopefully work around a few problems that might crop up.
"BIOS setup (f2) and set the hard drive to ATA compatible."
I would go ahead and disable everything in the boot heading besides the DVD/CD.
You also need to disable caching module before you change the drive SATA settings.
Jun 17, 2010 | Acer Aspire 5315 Notebook
0xa0000002 acer aspire 5315 recovery after new hard drive. Replaced the hard drive. got the system and recovery discs. system disc asks for language, then kicks out and asks for recovery. recovery disk...
make sure disc is clean wash gently with warm soapy water going from middle to outer edge then dry with soft cloth going from middle to outer edge make sure cdrom is set to boot first then put RECOVERY DISC in first when finished put system disc in.
hope this helps.
Apr 28, 2010 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Vista Windows boot problem
have you checked if your pc is compatible with win7? use this to check it: http://www.microsoft.com/windows/compatibility/en-us/default.aspx
and if it is, try to do a clean install. boot from the cd. insert the disc. restart pc, as soon as it has power, press F12 several times and highlight cd/dvd drive or ODD using your arrow keys then press enter. it will load the cd from there. And that should work fine.
Apr 03, 2010 | Acer Aspire 5315 Notebook
Have acer 5315 will not boot giving PXE-E61 an PXE-M0F code what to do
OK, here is the deal with your system.....It looks like you have had a hard drive failure and the computer is trying to boot from a network drive or NIC card. That is what the PXE is, in the BIOS the computer is peobably set to boot from a network if the hard drive is not found hence the PXE code.
Replace the hard drive and get yourself a EIDE / SATA to usb adapter so that you can attach the old hard drive to the adapter and attempt to get some of your personal files off of it. The hard drive may allow itself to run as an external so you can access it....maybe not, but worth a try. The only other reason I know of for the code would be if there was no operating system to be found, then it would throw the same code.
Oct 07, 2009 | Computers & Internet
Acer Aspire 5315 lcd screen corruption. External lcd partially ok
i know your problem. even if you change the inverter it will not work. the real problem of your notebook is vga memory or video memory. use hot air to resolder your memory. trust me!
May 20, 2009 | Acer Aspire 5315 Notebook
No boot disc
Yes bunnydawg could be indeed correct. Although also make sure you don't have a flash drive, external hard drive, or any CD/DVD left in the drive first. As they could try to boot from the device and fail (because they are not setup and formatted as bootable) and it will report the very same message.
Jan 30, 2009 | Acer Aspire 5315 Notebook
Cannot reload operating system
for xp in acer 5315 you have to load sata driver from external floppy disk with floppy and press F6 optin at starting point of xp boot disk while booting.
and follow the instraction when ask for sata driver spacification.
and enjoy loading xp.
Jan 19, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 5315 - Logon process failure.... Failure-Security Opt
hey i believe u got some problems somewhere with ur windows think est thing to do is take it bk if that is not possible to get it replaced for another 1 then simply reinstall windows vista think they are around 86.00 on sale at pc world if u can get that place disc in drive u will need boot laptop from disc by changing settions in bios then click install now u will see a bit where u can format the partition ur windows is already on format that then reinstall ur new windows on that partition mate
Dec 27, 2008 | Acer Aspire 5315 Notebook
Install xp on acer extensa 4220 hard disk not detected
Acer Extensa supports two model of HDD installation 1) AHCI and 2) SATA.
Windows Vista get installs on both but for Windows XP you need to Enable SATA option.
For that go into Bios, Change option of Hard Disk from AHCI to SATA. After that you can install both XP as well as Vista.
Try it, and mail me update: ansari.yasser@gmail.com
i am using Windows XP on Acer Extensa-4220
Jun 21, 2008 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
