Question about GPS
I HAVE AN OLD FURUNO 1830 RADAR UNIT IT'S OK BUT THE RADOME RSB-0034 IS NOT OK AND I WOULD LIKE TO KNOW IF ANY OTHER MODEL/TYPE WILL WORK WITH THE DISPLAY
RadarRon
  • 398 Answers
SOURCE: Furuno 1623 Radar reading "no heading pulse"
The messages “NO HEADING PULSE” and “NO BEARING PULSE” means that the display is not communicating with the scanner (antenna). Both of these signals are generated in the scanner if you get this error check that the antenna cable is firmly connected and that the contacts are clean and corrosion free.
If the connection at the display looks good and feels like it’s properly connected, check the cable for any damage If you find damage you could try to repair the wires BUT (because of corrosion and moisture problems) IT IS STRONGLY REMENDED that the cable be replaced, but it’s kind of expensive $275.00.
The Part number is 000-130-034. Depending on the marine shops in your area they may have it in stock (or they can order one) but you can get it directly from Furuno at;
http://www.furunousa.com/Furuno/Rooms/Search/ProductPropertySearchResults?_webrFormIdentity=com.webridge.layout.FormLayoutExImpl%5BOID%5B47F81E95CB197F4C8708859EA0E22F08%5D%5D&_webrFormUniqueID=0&_webrCharacterEncoding=iso-8859-1&_webrLocale=en-us&_webrClusterUpload_2=&ptype=com.webridge.entity.Entity%5BOID%5BE670694808555649838ED263AA4CAB0A%5D%5D&productname=000-130-034&searchOption=normal&searchOption_webrHidden=radio
I hope it’s just a loose connection. Good luck!
Posted on May 03, 2008
MarineTech1
  • 76 Answers
SOURCE: furuno 1621 radar will not power up
With a voltmeter, verify that you are getting 12V at the plug end of the power cable. If so, check the fuses (there should be one or two fuse holders on the back). If all of that fails you will need to send it in to Furuno for repair.
Posted on Aug 23, 2009
SOURCE: testing and operation of furuno 1621 radar.
I have the original manuals.....
Posted on Jan 11, 2010
  • 111 Answers
SOURCE: may i upgrade furuno 1920 gps/ploter with radar
If it has a round radar plug in the back then the answer is yes and it already has radar support. However to upgrade your unit to the latest software you will need a dealer for that. It's a very tricky process and if not done properly, you can ruin the bootloader programming that starts the unit. I know of a dealer that does this if you want to check in with them. You can even send them the unit. Try www.mid-shore-electronics.com.
Posted on Jan 25, 2010
SOURCE: I have a furuno 1621 mark 2 radar but the display
vorrei se e' possibile avere il manuale in irtaliano del radar furuno 1621,grazie
Posted on Dec 13, 2010
Radar furuno 1721 mark-2
Must have RSB number and FCC ID number
Nov 09, 2013 | Furuno 2.2kw 18" Radome
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
I have a Furuno Radome RSB0094-075 with a Navnet RDP 139 10.4" What I dont have is the antenna cable to connect the two units. What cable should i be ordering for this?? Thanks, Mike
That is a Furuno 1823C Radar -000-138-972 (10 meter Radar cable) $150.00 msrp from Furuno. Give their Camas Office a call or your nearest dealership. The Furuno number in Camas, Wa 888-834-9330
Nov 06, 2010 | Furuno NavNet vx2 1920C GPS Receiver
Hi. Looking for a new radar cable for Furuno 1720 say 5m to replace existing cable rather than splice or use a junction box. Can you supply? If so how much? Thanks
yes, this is available from Furuno give me an email address and we will quote can drop ship to marine operation or 10 days delivery John Barry 847-746-0100 john@technicalmarine.com
Jun 06, 2010 | Raymarine Radar Cable, 25m, For 2kw Or 4kw...
My radar displays all contacts reverse. How do I get the display reversed? model #1731
I agree with Nico-Fixus, the heading alignment is one of the things to be checked. Unless this is a new installation it is unlikely that the Radome (antenna) got removed and reinstalled facing the wrong way. So antenna orientation would not be a concern.
I have seen units that for some reason the wrong Radome was selected in the configuration of the Navnet display.
Read the model number on the Antenna, then check that correct antenna type in loaded in your display.
Oct 22, 2009 | Furuno Navnet 1732 GPS Receiver
Furuno radar antenna not rotating
yes, this is a common failure after hours and hours of use
Apr 06, 2009 | Furuno 2.2kw 18" Radome
The belt on the radome drive sprocket jumps off of
The belt pully on the motor has a set screw that tends to get loose causing the pully to change position on the shaft. Position the pully on the shaft (move up or down) for better alignment with the pully on the rotating array pully and tighten the set screw..
Feb 23, 2009 | Furuno 2.2kw 18" Radome
GPS Logo
115 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
