Question about Vacuums
Changing filters - Vacuums
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 31 Answers
You didn't specify which brand of vacuum you need to change a filter on. Or which filter. Many machines have more than one filter.
Usually all you have to do is turn a butterfly clip to take the old filter out, or sometimes, just open a door or cap and it will come out to change it. This usually is not difficult to do.
Giving us the brand, and or model number of your machine, would help immensely, so we can give you assistance. Please post your problem again. Thanks.
Posted on Mar 14, 2011
How often do I change the filter on my Electrolux Jetmaxx
I can't answer that question, only you can....How often do you change the filter?
Now if you wish to know how often you should change the filter
every six months to a year depending on use.,,,once a week use- every year.....two or three time a week-every six months
Aug 09, 2013 | Electrolux Vacuums
My miele has no suction and i changed the bags
99% of the time you can fix this problem with a new filter i have put the link in for the filter for your vacuum cleaner if you have changed the filter in the last 3 months then you might have a blocked hose check the hose first then get yourself a new filter
Miele filter for s514
Jun 04, 2012 | Miele S514 Solaris Bagged Canister Vacuum
Why is the filter change indicater still on even after i changed the filter ?
Probably needs a good clean out around the filter area. Dust has probably got in the way of the sensor which tells the machine the filter has been changed.
Feb 06, 2011 | Vacuums
How often is it necessary to change the filter one on a Filter Queen Majestic?
The best thing to do to both, keep your Majestic suction and air flow strongest, and keep from pulling dirt & dust from being pulled past the filters which can cause damage to the motor, and charcoal filter, replace the filter once a month. If you use it longer than that it will both loose suction and will cause your Medipure or Enviropure "charcoal" filters to wear out prematurely. Mark the change date right on the filter or on your calendar to help keep track.
Dec 20, 2010 | Filter Queen Majestic Canister Vacuum
Vacuum getting hot in filter area
That's not abnormal, unless it's getting very hot. Have you changed the filter recently? If the filter is blocked it will get hotter than normal. the filter should be changed every 4 to six weeks of normal usage.
Apr 06, 2010 | Euro-Pro Shark Professional Upright Vacuum...
Kenmore canister vacuum will not turn on
No, the only effect of not cleaning them would be decreased air flow and consequently . The time between changing filters depends on how much the vacuum cleaner is used. Common failures are damaged cords and a damaged or failed power switch
Mar 29, 2010 | Kenmore 23513 Progressive Bagged Canister...
How to change upper filters?
Open the vac as though to change the cone and remove the plastic inner cone with the slotted screw at the bottom.. Underneath you will find a 5" disk , likely coated with fine dust.
That is the one which needs to be changed. Around that disc will be three more screws holding the upper housing onto the vac. These ones are accessible from inside, if changing the motor.
Below the handle of the vac there is a serial number ring and three screws in an offset triangle. If you remove these and the rubber cover for the toe switch, the vac housing will come off. This will reveal the `foam or cotton ``muffler``. You can replace it or wash and dry it if foam. It acts as a muffler more than a a filter....
Oct 17, 2009 | Filter Queen Majestic Canister Vacuum
Filter queen masjestic vacuum cleaner has a light that should light up when the filter needs changing, it doesnt want to light up. I dont think its burnt.
That is a overhead light not a filter light. If your waiting for the light to come on before changing your filter or haveing the vacuum serviced your going to kill it. Every time you empty the container you should replace your white filter come and ONLY use genuine filter queen cones the aftermarket cheap-os will burn up your vacuum.
Aug 10, 2009 | Bosch Vacuums
Vacuum gets hot loses suction and turns off
you have replaced all three filters?
if its turning and sucking with all new filters you have a glog somewhere
Apr 23, 2009 | Filter Queen Majestic Canister Vacuum
How often should I change a hoover empower filter?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=545652
Generic problem for all Vacuums
How often should I change?
Posted by jdl185 on Apr 25, 2008
How often should I change a Hoover Empower filter?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Depending on what type of filter it is, the suggested change for a filter is every 6 months to one year if it is a cartridge filter or HEPA filter, if it is a filter that can be vacuumed off or it might be a washable filter – you can clean it that way until the filter starts to fall apart – then @ that time you would want to replace it @ that time. Please check with you local vac dealer. Filters
It's important to replace your vacuum filter or HEPA filter regularly to keep your Hoover vacuum working best. Not only will this increase the life of your vacuum, it will also keep unwanted dust, dirt and allergens out of the air. Keep your home Hoover clean with genuine Hoover filters.
So If you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 25, 2008 | Vacuums
Vacuums Logo
61 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
