Question about Dryers
Our Whirlpool gas dryer does not heat up. We have checked all the vents (they are clear) and opened the back and all is clear. Any ideas why it is not heating up (and how to fix)? Thanks!
  • 55 Answers
the most common problem with gas dryers is the hot surface igniter. It could also be a thermal limit or thermal fuse but since you say the vent is clear I lean toward the igniter. It is located next to the burner and is a ceramic looking piece. Normally it glow bright red when working. Be careful with a new one they are very fragile. you can goto - http://www.searspartsdirect.com/partsdirect/index.action - to find a parts breakdown and order parts. Good Luck
Posted on Mar 14, 2011
5 Suggested Answers
wheelshot
  • 102 Answers
SOURCE: No heat from dryer
It is most likely the heating element. If you would like to access the element, just take the 3 screws out of the bottom of the kick plate below the door and you will see the element in a canister. There should be a screw on the side of the canister that holds the element in. Remove this screw and pull wires off the element, after you have noted where the wires to the element are properly placed. Then proceed to pull the element straight out of the canister. Inspect the wire coils for breakage, If you find a broken coil wire, replace the element. If you do not find a broken coil wire then proceed to checking the high limit cut off thermals located on the side of the canister for continuity. If you find one of the thermals not to have continuity, replace both thermals. They come in a package together as one kit. Hope this helps. Dave
Posted on Apr 02, 2009
  • 70 Answers
SOURCE: no heat, dryer exhaust vent cleaned, still no heat, gas line is on
I think you have a gas dryer, and a bad ignitor.
Posted on Apr 23, 2009
TheMobilian
  • 8220 Answers
SOURCE: Will not heat up and timer will not advance
if that vent was stopped up then you probably have to replace this fuse:
Posted on Apr 25, 2009
milten1
  • 1304 Answers
SOURCE: New Whirlpool Duet gas dryer (wgd9300vu) won't heat.
if its brand new,
anmd its gas, well then more than likely it was dropped, when it was dropped the graphite ignitor craked or broke due to shock impact,
i delivered units for 5 years and saw this numerous times.
I would tell you to fix it your self, but its brand new, if the company you bought it from has service they should give you a free service call and part
Posted on Oct 21, 2009
Testimonial: "milten 1, you nailed it. The store sent a service tech out today and sure enough, the top of the ignitor was broken off. Thanks!!"
Kenmore 110.64622300 not starting
Unplug dryer and check the vent pipe to outside clear it and make sure vent is clear ro outside atmosphere.
take back off of dryer and check fuse. Fuse is located on blower housing next to control thermostat.
3399849-j2rqmywrjn05nkl43ld3f3b0-5-0.jpg If the fuse IS open (blown) then remove the filter housing and clean it as well. I have a home made video I did about heat problem but on my video I show how to check all that stuff: below that is my blog page smack dab full of all manor of stuff pertaining to your dryer. Please let me know if this heps. -PawPaw Dan Webster https://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101/kenmore-whirlpool-englis-roper-dryer-notes
Jun 23, 2017 | Kenmore Dryers
Whirlpool gas dryer doesn't dry
Make sure vent hose in back of dryer is not blocked or stopped up.
Mar 16, 2014 | Whirlpool WGD94HEXR Duet Steam Dryer gas
My Whirpool Duet Gas Dryer is no longer heating up.
This is probally the coils. They tend to fail as the dryer heats. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the troubleshooting. It's a different model but the testing of the parts will be the same.
Mar 24, 2010 | Whirlpool LGR5636L Gas Dryer
NO HEAT - THE DRYER ROTATES WITH AIR BUT THERE IS NO HEAT. GAS VALVE IS OPEN. BREAKERS ARE OK.
Hello there:
On the back of the dryer near the fan blower housing is a thermal fuse, if this opens up ( no continuity ) the gas burner often quits but the motor will still run. If the thermal fuse is open/bad, always clean, change, adjust the venting system and vent hood first and clean out the dryers air ducts. Sometimes it is a good idea to replace the operating thermostat at the same time.
Thermal fuse parts help link...on blower housing cover, can not be re-set, must be replaced if is open (no continuity between pins).
Jan 09, 2010 | Whirlpool Dryers
Dryer has no heat. Tested some of the fuses and they test good. Is there a way to test the igniter with a multimeter?
have you checked the dryer vent that goes through the outside wall sometimes the outlet gets clogged up with lint and the heat will recirculate instead of venting outside, the recirculation somestimes tell the dryer sensor that the clothes are dry and will stop sending heat to the dryer or very little heat clear the vent and see if that helps also check the pipe at the bottom of the dryer they sometimes clog up as well if no sucess call a gas appliance repair service you do not want to fool aroud with gas appliances re igniters or where burners are concerned
Jan 09, 2010 | Whirlpool LGR5636L Gas Dryer
Whirlpool gas dryer, no heat and no flame
check you thermal fuse with an ohm meter if selected only air and close the door and no air comes from the rear where the vent hooks up clear the vent blower housing then check the thermal fuses on the units exaust assy inside the unit
Aug 19, 2009 | Dryers
Whirlpool gas dryer runs but won't heat
hi stella. yes the problem is with the thermal fuse. when you were cleaning the vent at the left. the thermal fuse is right there, on the air duct, a small piece of plastic with 2 blue wires to it . replace the thermal fuse . thanks the appliance doc
Oct 06, 2008 | Whirlpool LGR7646E Dryer
Inglis gas dryer heat loss
It sounds like you have an intermittent gas valve. The ignitor is calling for heat however the gas valve doesnt want to open.
Make sure you turn off the gas and unplug before replacing.
Check for leaks after you reassemble.
Aug 21, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool dryer not enough heat
There may very well be a clog in the vent line. Check the vent to be sure it is clear. Make sure to check the outside vent cover. Some of these vent have screen/louvers that can get clogged.
Jan 02, 2008 | Whirlpool LER5636P Electric Dryer
Steam comes out of dryer after cycle and door is opened
Probably has a restricted vent. Go outside with dryer running and check air coming out vent. Should be a good blast...not just a breath. Clean out the vent and make sure it's not kinked. If it vinyl or foil vent, replace it! Also make sure lint screen is cleaned everytime.
Nov 16, 2007 | Whirlpool LGR3624JQ Gas Dryer
Dryers Logo
26 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
