Question about Sierra Online, Inc. Hoyle Board Games 2003 for Windows
Hoyle Games 2003 Stopped Working Windows is Checking for Solution
  • 7 more comments
  • Gary Campbell Mar 14, 2011
    I have an Acer Laptop with Vista operating system.
    When I get to Machine\Software\SQMClient, SQMClient\Windows\DisabledSessions is not offered.
    What do I do next ?
    I have tried all of the suggestions several times
    without any success. The problem still exists.
    Also, after trying the first suggestions my computer will not go back to HKEY_LOCAL_MACHINE\
    SOFTWARE etc. When I go to start and type in regedit it opens at .gz, .h, .HIC, etc.
    Note: I have a vista operating system.
  • Gary Campbell Mar 15, 2011
    I am using Vista operating system on my laptop. I am responding to you on Windows 7 operating
    system on my desktop computer.
    My problem is with Hoyle Games by Sierra. When I hit play on icon I get back the following message Hoyle Games has Stopped Working. Windows is checking for a solution to the problem
    A problem caused the program to stop working correctly.
    Windows will close the program and notify you if solution is available.
    Note: at the bottom of message in a box CLOSE PROGRAM
    The first solution told me to go to start and type in regedit and go to the following key HKEY_LOCAL_MACHINE\Software\Microsoft\SQMClient\Windows\DisabledSessions
    I could not get past this point
    There was not a right pane to delete subkey: Machine Throttling.
    Note: Now I can't get back to the above point. When I try again to go to start and type
    in regedit and press enter I only get new key #1, PersistantHandler, .H1C, .H1D etc.
    Can you help ?
    Yes, at least 20 different times.
    Yes
    Yes
    Yes
    Yes
    It works on desktop windows 7. It still does not work on laptop Vista version
  • 1,555 Answers
First you need to fix your exe association. Once your registry is opening easilly let me know so that I can provide you with further instructions. Since, the solution is long hence, providing you with a link to solution.
http://filext.com/faq/broken_exe_association.php
Posted on Mar 15, 2011
  • 1 more comment
  • Aruna Singh
    Aruna Singh Mar 15, 2011
    have u tried my suggestion.
  • Aruna Singh
    where are your comments. I can't find them out. You last comment is of 18 hrs back.
  • Aruna Singh
    Where are your comments your last comment is of 22 hrs back I can't see any recent comments from you. Kindly let me know have you tried my solution.
  • 2,632 Answers
Welcome to Fixya. For clarification to fix the issue can you please provide the Operating System that you're using (Windows XP, Vista, or 7)? Is this working on the same machine? What is the error message when you try to run/install the program?
Please provide the following info for us to know what is causing the problem. If ypu have questions please let me know.
Thanks for using Fixya
Posted on Mar 14, 2011
  • 5 more comments
  • Rofel Lantican
    Rofel Lantican Mar 15, 2011
    Have you tried to reinstall the software?
  • Rofel Lantican
    The Vista that you are using is it 64bit? have you tried to use it on windows 7 machine?
  • Rofel Lantican
    Try to install it to your Windows 7 machine and set software in Compatibility Mode? Depending on your version of Windows 7, you may have the ability to run it in Compatibility Mode. Try right-clicking on the Hoyle Board
    games shortcut that is on your Desktop. Then, go to Properties from the pop-up menu. Then, select the Compatibility tab. On that tab, put a check next to "Run the program in compatibility mode for:". Then, select Windows XP SP2. Click on the OK button to save this setting. Finally, try launching the program again.
    Just let me know what happen if this runs on windows 7 it means it is a compatibility issue with the software and Vista
    Thanks
  • Rofel Lantican
    did you try to run it on compatibility mode as indicate on the steps below and see what happens?
  • Rofel Lantican
    So the problem is that the program is not compatible with windows Vista. You can upgrade the laptop to windows 7 or downgrade to xp if you want to use the game. If i answer your questions you can see the 4 thumbs on my 1st answer across my you can rate me so i can help others like you. Thanks
  • Rofel Lantican
    The 4 thumbs is on my first answer across my name. Please rate meif i was able to help you.
  • Rofel Lantican
    Rofel Lantican Mar 20, 2011
    Hi - any update on this? was i able to answer all your concern?
  • 2,574 Answers
What operating system do you have?(Windows XP,Windows Vista,Windows 7)
For windows 7
  1. Click Start.
  2. In the Search Bar, type regedit and press Enter.
  3. Locate the following key: HKEY_LOCAL_MACHINE\SOFTWARE\ Microsoft\ SQMClient\Windows\DisabledSessions
  4. In the right pane delete this subkey: MachineThrottling
  5. Turn your computer off and back on for the change to take effect.
  • Reparatii PC - Service IT
    1.Run Hoyle Games 2003 in Compatibility mode.
    Right click Hoyle Casino 2003 icon -->select properties-->Next go to Compatibility Tab and check the box "Run this program in compatibility mode"
    2.Run Hoyle Games 2003 in Administrator Mode.
    right click Hoyle Casino 2003 icon-->select Run As Administrator.-->click Yes.
    3.Uninstall/Reinstall Hoyle Games -->
    Click on the Start
    button to open your Start Menu;
    When the Start Menu opens click on the Control
    Panel
    menu option.
    When the Control Panel window opens click on the Uninstall
    a program
    option option under the Programs category.
    This option is shown by the arrow in the image below. If you are using
    the Classic View of the Control Panel, then you would double-click on
    the Programs and Features icon instead.
    If you want to
    uninstall the program you should instead click on the Uninstall button.
  • pjmac1022
    pjmac1022 Aug 21, 2012
    Nope didn't work.
Can I download hoyle casino 3D on windows 7?
You can certainly download it. It just means it was designed for Windows 2000. More than likely you will have to run an app like VirtualBox in order to get it to play correctly. Read the article below and decide if it's something you can handle or if it's too much trouble.
Article:
http://www.techradar.com/news/gaming/how-to-make-old-games-work-on-windows-7-969445?artc_pg=2
It basically says to get VirtualBox for old Windows games and DOSBox for old dos games.
VirtualBox link:
https://www.virtualbox.org/
DosBox link:
http://www.dosbox.com/
Jun 16, 2012 | Hoyle 3D Casino
Hoyle card games 2005 just stopped working. It won't open on win 7 64 bit comp. I've reinstalled, tried clean install, nothing
You should download and install a special "Virtual PC" package for Windows 7. It is designed specifically for installing and running software that worked in Windows XP, but does not work in Windows 7.
http://www.microsoft.com/windows/virtual-pc/download.aspx
Mar 07, 2011 | Vivendi Universal Hoyle Card Games 2005...
Need unlock code for hoyle casino
Unlock codes are only aviable with a new copy of hte game. In order to get an unlock code try purchasing a new copy.
Mar 06, 2011 | Sierra Online, Inc. Hoyle Casino Games for...
After installing Hoyle Card Games 2005, introduction runs but game stops and window pops up saying that windows is looking for a solution. Tried unistalling then reinstalling. Same problem.
you should try seeing if your computer reaches all the game requirements i.e: type of video card videoX, then you should compare with what the game requirements are and what your computer has! I think that's the easiest way to find the solution for your problem
Apr 30, 2010 | Got Game Hoyle Card Games for Windows
No curser
play it in windowed mode.
Mar 06, 2010 | Encore Software Hoyle Card Games for...
I have hoyle card games but cannot install on vista 64
Going to need more information. Are you getting an error? Try running the install as an administrator and see if that helps. If your getting an error, please specify WHAT error. Thanks :)
Oct 20, 2009 | Got Game Hoyle Card Games for Windows
Hoyle Card Games
Do nothing, Vista is incompatable with Hoyle 2005 to 2009. Wait tille Windows 7 comes out. A word to the wise.
Apr 05, 2009 | Computers & Internet
I bought a new computer. When I tried to run
To be honest, there are only two options.
1. Go to the sierra online website and see if you can get a 64 bit version of the game
2. Get an entirely new OS of windows (a 32 bit version) and then try installing
Feb 24, 2009 | Sierra Online, Inc. Hoyle Classic Games 2...
Sierra Online, Inc. Hoyle Board Games 2003 for Windows Logo
486 people viewed this question
Top Sierra Online, Inc. Video Game Consoles & Games Experts
James Wishart
Edward Talavera
Edward Talavera
steve morris
steve morris
Are you a Sierra Online, Inc. Video Game Console and Game Expert? Answer questions, earn points and help others
