Question about Yamaha NPV80 Keyboard Digital Piano HOME ESSENTIALS BUNDLE
I just bought a yamaha np039 ynp025 digital keyboard. The sound worked originally on the keyboard, but after using the headphones for a few weeks now,when I pulled them out, there is no sound coming from the speakers! Any suggestions?
  • 3,400 Answers
Clean the head phone jack. When you put in headphones, they mute speakers. If headphone jack is dirty or stuck, speakers remain muted.
Posted on Mar 14, 2011
Yamaha p90 keyboard sounds deteriorating
Does this still happen while using headphones? If so, I would suggest trying a different power adapter. If it's clean through the headphones then you may have a speaker malfunction.
Nov 03, 2016 | Yamaha Music
Why does my yamaha mm8 doesn't have any sound? I try the headphones and there's no sound there either.
Assuming the volume is turned up, you can try initializing the keyboard (page 35 of the manual), but that will erase all stored backup data and reset to initial default settings. You might wantt to call Yamaha directly to discuss their suggestions. Here's their support link-
Digital Pianos Keyboards Guitars Drums Live Sound and Music Production...
Jul 28, 2015 | Yamaha Music
Voxmini 3 got sound with headphones plug in but no sound when unplugged
headphones plug in but no sound when unplugged means your output ic is working ,so check the headphone socket it may have loose solder or your socket itself may be defected. give it a try it always helped me.
Mar 06, 2014 | Yamaha Portable Keyboard
Yamaha CP 300 broken headphone jack
Some keyboards use the amp output sockets for headphone use.
You might need some adapters for your headphones.
If it fell in, you would see an empty hole. This would be unlikely because it is held on by two screws. If all fails, buy an amp with a headphone jack input. Plug the keyboard into the amp and use the amps jack.
Dec 15, 2011 | Yamaha CP300 Stage Digital Piano...
Hi, I am undecided about which digital piano to buy: Yamaha Arius 141 or Roland F110? help appreciated, thanks, karol.
I have two Yamaha's and I will say they are maintainable. Almost ALL the weighted piano key models use a keyboard made by one company as I understand it. I can easily get service manuals for the Yamaha, not quite as easy for the Roland... same goes for repair parts. Your decision... listen to each and decide. Hint: Use a set of headphones to do the compparision rather than internal speakers as the orientation in a music store can drastically change the sound.
May 01, 2011 | Roland F110 Compact Digital Piano 4867
The keyboard is showing sign of power input but the screen is not lighting and produces no sound
1. Try the volume
2. Your adapter may not be the proper voltage/amperage. If the adapter has ratings listed, make sure they match the keyboards ratings.
3. Try it with the headphones. If they work and the speakers don't, you've narrowed down your problem. There may be some damage or wiring problem within where the board meets the speakers, and/or before processing.
4. Try it with batteries. If that works, you need a new adapter.
http://www.ioffer.com/i/adaptor-cord-yamaha-psr-or700-s500-s700-s900-arranger-113553507
Feb 06, 2011 | Yamaha PSR-S500 Digital Keyboard
I have a Yamaha ypp 100 keyboard that was sitting idle for awhile. When I turned it on and started to play there was no sound/an extremely faint sound from the speakers.
Try headphones... possibly the switch contacts on the headphone jack which disconnect the speaker when headpones are plugged in. If you can hear via the headphones, check the switch contacts. Also look for a loose cable.
Contacts can oxidize when idle for a long time.
Jan 17, 2011 | Yamaha Full-Size Keyboard
I get no sound from the key board the display shows the keys being pressed all functions look like they are working but no sound at all
We can only guess what keyboard you might have. Maybe it has built in speakers or requires external speakers.
Usually on the keyboards there is a headphone jack. The jack disconnects output if headphones are in. Some keyboards have mute functions. Some use rotary volume controls, some use sliders... The controls can become damaged causing problems.
We don't have ESP to know what model you have and can give no further help without the model number. Always post as much detail and tests you have run.
Sep 13, 2010 | Yamaha Music
Yamaha NPV80 Keyboard Digital Piano HOME ESSENTIALS BUNDLE Logo
201 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
