Scvhost.exe driver not redy..please solution - Computers & Internet
  • 368 Answers
Glad to help YOU!
The svchost.exe file is located in the folder C:\Windows\System32.
On STARTUP Svchost.exe checks the services portion of the registry and constructs a list of services that it needs to load. Usually multiple instances of Svchost.exe will be running simultaneously. If the process svchost.exe uses high CPU resources it is mostly due because Windows Operating System is downloading some updates.
WARNING: A 100% CPU usage could lead to the presumption of a hidden malware on your computer!!! Same for the message that you got: "scvhost.exe driver not ready"...
I'd suggest you to do a SPYWARE/MALWARE scan AS SOON AS POSSIBLE and AS DEEP AS POSSIBLE!!!
GOOD LUCK!
Posted on Mar 14, 2011
Svchost exe error
upgrade to a newer OS helps alot
Jul 18, 2014 | Toshiba Satellite Computers & Internet
Undetected scvhost.exe
svchost is part of the os, not the motherboard
Oct 24, 2010 | Computers & Internet
After shutting down svchost.exe appeared.and hang itself.
If its not doing this all the time, and the laptop is just stuck on, press and hold the power button down until the laptop turns off.
If its a reoccurring problem, run a check disk.
if it still does it, disconnect one piece of external hardware one at a time until the scvhost.exe doesn't hang on shutdown, and you have found the culprit.
Jan 21, 2010 | HP 510 Notebook
Scvhosts.exe how do i remove? i installed regcure with no luck
hi
don't remove it manually use the remover click on the removal tab
http://www.symantec.com/security_response/writeup.jsp?docid=2005-041022-0008-99
Oct 09, 2009 | Microsoft Windows XP Home Edition
Windows cannot find scvhost.exe
This is the Internet Virus , to overcome this , you may kindly be taken following steps .
Step 1: Write click on the start button task bar .
Step 2: Select Task manager by left click of you mouse.
Step 3. Under the process option , select line
svchost.exe system Administrator
Step 4. Select End process .
Step 5. Repeat Step 3 & 4 until the end of the bellow message.
svchost.exe System Administrator
Step 6. Close the Windows Task Manager by click X button .
or
Run the Original Quick Heal / AVG antivirus software in your system .
The steps are the solution for your problem.
OK
nilamani
nkjbbsr@yahoo.co.in , nkjbbsr@rediffmail.com
Dec 21, 2007 | Microsoft Windows XP Professional for PC
Windows cannot Find SCVHOST.exe.
Boot from your Windows XP disk and use recovery console, follow the onscreen stuff and put the admin password in that you setup when you installed windows, you should now be at a prompt EXAMPLE: C:\WINDOWS>
At the end of the prompt type: cd F:\I386
F is the letter of the drive where your XP disk is so you will need to change it to your drive letter. The prompt should now be F:\I386>
After the prompt type: Expand svchost.ex_ C:\windows\system32
C is the letter of you HD were windows XP is installed, needs to be changed accordingly. At the prompt type: exit
Your sytem will re-boot and you will now have a copy of svchost.exe in your system32 folder again.
If you have found this solution helpful please rate it as Solved, otherwise please ask again.
Thank you
Nov 01, 2007 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
293 people viewed this question
David Payne
David Payne
