Question about Kenmore Refrigerators
My kenmore side by side has a problem the freezer part work but the frigerator part doesn't what can I do help
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 14, 2011
Freezeor r works fine but frigerator not working
check that your fan is working inside your freezer also check that u do not have an ice blockage problem if your fan is working and also check your t-stat and heater start with the fan if its not blowing the air into the fridge side then thats your problem you can order a new fan from marcone or allbrandsappliance hope this helps
May 16, 2010 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator is freezing
if you turn up the temp in freezer and down on frig side and frig still freeze's than more than likly you have a bad frigerator thermastate.
Nov 17, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore Top Freezer not getting cold (freezer or refrigerator), fan works. Occasional click down by compressor? Any advice appreciated. Trying to fix cheap as this is an 8 year old 2nd frigerator we keep...
Check your compressor relay- http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Sep 12, 2009 | Frigidaire FRS26R4A Side by Side...
I have an Amana bottom freezer frigerator. The
Possibly a bad relay/overload or shorted run capacitor.If it was built between 2002 and 2005 it may be a bad compressor in which case you would want to check the warranty for possible coverage.
 the relay/overload and run capacitor plug right into the compressor on the left hand side.
 IF it isn't under warranty and the Oem part won't get it going pick up a 3in1 hard start for it they are easy to install and will get it working for you.
Sep 05, 2009 | Amana SXD524VW Side by Side Refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
Water was leaking out of the freezer so I cleaned the ice build up on the freezer and now the frigerator is not cooling. I have a Kenmore side by side
check and make sure the timer is not stuck in defrost mode. if you can turn the timer by hand past the current point it should advance past the defrost cycle and begin cooling. The timer is usally found near the bottom of the refrig located in the front side.
Jul 07, 2009 | Kenmore 72102 / 72104
Water in bottom of frigerator
Hi, The drain is plugged coming from the freezer section. Please get me a model# and I can assist you with this problem. Thanks Vic
Jun 14, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Frigerator is working but, refrigerator is not working at some points
Your freezer coil may be frozen over causing air circulation to stop. Check for frost build-up in freezer compartment. this is an indication of a fault in the defrost system timer or heaters.
May 18, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
My frigerator
This will get warm. If very hot check and clean coils in front, underneath. Also check fan behind rear panel. It should be turning when the unit is running. Also check for door not closing properly.
Nov 12, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
66 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
