I was printing a document when my printer stopped because it ran out of yellow ink. I cancelled the job, replaced the ink. It has been almost two hours and the job is still showing in the queue as "deleting", but has not deleted.
  • 902 Answers
Windows handles the printer spooler issue really bad with this your going to need to reboot the computer but before you do that you need to go to run (under windows xp) type msconfig and go to services and shut off printer spooler under win 7 n vista just type msconfig in the search box and shut if off. then on the reboot turn it back on and reboot again.
Posted on Mar 14, 2011
I cant figure out how to cancel print jobs on my printer. Its a brother MFC 210C MFC-420CN Its been out of ink for awhile and now all of these documents are keep printing because we put ink in. I cant get...
If you are using xp click on start , then control panel, then printers and fax, double click and a small window will open showing all of your print jobs. Click on the farthest left item (on mine it says printers) then it comes with an option to cancel all print jobs, click that. I hope this helps. If that first item does not show it click on all of the options at the top till you find the one that says cancel all print jobs.
Feb 23, 2013 | Brother MFC 210C All-In-One InkJet Printer
Canon inkjet PIXMA ip3000 wont print and has 5 blinking yellow lights
Canceled the jobs on PC and verify the inks.If you use the refill inks perform the head cleaning in the mantenance mode.
Feb 13, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
Hp Business inkjet 1000 wont stop printing garbage - a bit on lots of paper. It ran out of black ink - now replaced - but now wont stop printing .... Have tried unplugging power and usb. turned...
You need to view the print que and cancel all prints.
Do the following:
1.) Navigate to windows control panel and double click Printers and Faxes.
2.) Now double click on your Hp Business inkjet 1000 Printer it should come up with the que.
3.) Click Printer and then click Cancel all documents. That is the Printer tab on the top left of the box.
That should cancel the documents in the print que and you printer should be able to rest now.
Thanks
Till next time!
damnor01
Apr 13, 2011 | HP Business Inkjet 1000 Printer
My printer wasn"t working when I had tried to
Hi pjmgranny !
Yes , you can cancel the previous printing jobs .
under Win XP :
go to start \ settings \ printers and faxes , select the jobs , clic on documents and cancel .
under Win 7 :
go to start \ devices and printers . Right clic on the printer , select open \ documents in queue \ select documents and cancel
Best regards ,
fanaudi .
Feb 21, 2011 | HP DeskJet D2560 InkJet Printer
Hp printer power light keeps blinking -- wont print any document
Turn both your printer and computer off then after a few minutes turn back on. This should cancel the print job.
May 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
Hp deskjet f4140 not operating
Goto start>Run>type services.msc>try to stop and then start print spooler service
Dec 24, 2008 | HP DESKJET PRINTER, HP OR COMPATIBLE
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
My Printer want stop printing!!!!!!!!!
try to check the queue for pending document and cancel it if you find some. to do it:
control panel > printers & faxes(xp)printers(vista) > double click cx7400 icon - this is where you can check if there are pending docs. to dlete: on the same box click printers and select cancel all documents.
regarding enter valid product, where did you get the error from?
May 05, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Status Monitor informs of Ink levels requiring me to press resume button during and after each print job.
What it means is the tank to collect waste ink (from cleaning etc) is full.
Canon suggest you return ther printer for replacement of the absorbant mat, suggest you scour the web for DIY cures.
Oct 19, 2007 | Canon i9100 InkJet Photo Printer
k24674
jasbo
jasbo
