Question about Hoover Bissell LiftOff MultiCyclonic Pet Vacuum
Brush stopped working - Hoover Bissell LiftOff MultiCyclonic Pet Vacuum
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 31 Answers
The first thing to check, is to see if your belt has broken or not. This is the usual problem for the brush not turning. If you find that your belt is still intact and not even cracked, then you might have a bigger problem. As long as your motor is running and you can hear it running, I would definitely check the belt out first.
To do this...simply remove the cover on the bottom by removing the screws holding it on. It should slip off easily. This will give you access to the belt. Take your model number to the store and pick up a replacement belt. It's a good idea to keep an extra or two handy for these times. You can also order one from the manufacturer of your machine. Such as: Hoover.com. The cost is about the same. About $5.
Hope this was helpful.
Posted on Mar 14, 2011
Roller brushes won't work
Remember, this brush is belt-driven (not air-driven), so if the brush stops working, then there is probably a problem with the belt. The device is likely set to stop the brush from spinning if the belt tension is not correct. My guess is that the belts have become too loose, or there is a malfunction with the sensory mechanism which detects that.
I will trust that your product does have the in-house warranty.
May 19, 2014 | Shark Navigator Bagless Upright Vacuum
Tip
Cordless Shark Vacuum Brush Bar Stops Working
My cordless Shark Vacuum brush bar would stop working each time after a few minutes of use. I was getting ready to throw the vacuum cleaner away, but decided to pull the bottom cover and check it first. I did the following modification and now it works great!
Just a few notes before attempting this tip: You need to be carefulafter this modification if you see the brush bar stop as this couldmean the bar is really jammed and there is a risk of the brush barmotor burning out. Most of the time disabling any fuse or circuit breaker is a very bad idea and could ruin equipment and even cause a fire. In the case of this tip, only consider the modification if you areready to get rid of the Shark because of the brush bar problem. Another option is to replace the circuit breaker, however consideringthe time and money involved vs. the cost of the vacuum cleaner it mayor may not be worth it to you. I did this modification to my cordlessShark about 4 months ago, and have had no further problems with it. I takes about 15 minutes to do this modification using a screw driver and wire cutters.
1. With the vacuum cleaner off, check the brush bar by manually rotating is with you hand. It should not be jammed or very difficult to turn. If so, remove the brush bar and clean it. Try the vacuum again. If you still have a problem with the brush bar stopping, proceed to next step.
2. Remove bottom cover around brush bar / motor.
3. There are two wires going to the brush bar motor, one wire includes a small circuit breaker.
4. Clip the circuit breaker out of the wire and reconnect the wire straight to the motor.
5. Re-install bottom cover.
on Apr 25, 2010 | Vacuums
Floor level brush stopped rotating after it caught
Look at the bottom and check a thread of carpet isn't wrapped around the brush, if so try pulling it off or carefully cutting it off. You'll probably see a collection of fluff etc above the brush that's stopping it from sucking up, pull this out, or it just may be that cause the brush isn't working its not picking up.
If this helps please rate me
Jun 20, 2010 | Bissell 6594 PowerForce Bagless Upright...
While using the vacuum, the brushes stopped turning.
check the drum. Hair will rap around the axxel and stop the brush from turning. Cut this hair with a razor and place a small drop of oil on the end of the axel.
May 08, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Brushes not spinning....
My status light came on, the vac beeped twice and stopped. I noticed my brushes weren't spinning. I took an eyeglass screwdriver and took off the center screw that holds on the brushes. I cleaned the shaft that the brushes spin on. replaced brushes and it works great! I just did this now and it is still running. my status light problem is fixed my roomba is 4 years old and I am on my 2nd battery. Seems to have fixed the problem. FYI it was wrapped with hair, dirt and it was greasy.
May 29, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
My power brushes on my bissel carpet cleaner stopped working. They do not rotate. This is the 2nd power cleaner I have bought and it has the same problem as the first one. What is the problem with the...
The brushes will only work if the handle is released and the ProHeat vacuum is running . There is a micro switch inside the lower handle that switches on the DC carpet brush motor. The DC power for the motor comes from a Bridge Rectifier on the PC Board. petedcurtis@gmail.com
Apr 18, 2008 | Bissell Vacuums
Beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Jan 12, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Bissell 37602 roller stopped spinning
If the roller brush as stopped spinneng .and the brush motor still works the brush belt as broken,
you must replace the brush belt, t
Sep 05, 2007 | Bissell 37603 Upright Vacuum
Hoover Bissell LiftOff MultiCyclonic Pet Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
