Question about Frigidaire 30" Self-Cleaning Slide-In Electric Range - Black
Frigidaire Gles389fbb F13 error. After turning off power/and back on minutes later, the error returns. The range and oven works except for the broil function.
BNewberry
  • 93 Answers
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Computer is cooked. Sorry to tell you.
I am a factory servicer for Electrolux / Frigidaire
I replace tons of those clock controls. They shouldn't be $160 though
Any questions about these stoves send me and email.
I will be glad to help you out.
Thanks
Posted on May 23, 2008
SOURCE: frigidaire PLES3890
i wouldnt buy one of these products again never!!!!
Posted on Aug 25, 2008
SOURCE: my kenmore elite electric slide in range displayed error and F13 and the oven won't turn on
i phoned Sears about error code f13 on a gas range, and was told to unplug the range for 30 minutes. i think she meant 30 seconds - to reprogram the microchip. i unplugged it for 15 minutes or so, then reconnected, and it worked.
Posted on May 28, 2009
SOURCE: Receiving Error F13
Turn the breaker to the stove off for one minute, reset time and everything should work just fine. It worked for me.
Ken
Posted on Jun 01, 2009
SOURCE: Frigidaire Gallery Series ES340 ceramic-top range:
The manual is missing a step. After pressing Clean or Quick clean you need to press the ^ button once.
Posted on Sep 05, 2010
What is error code f13?
The F13 fault code on this type of range indicates that the EEPROM (Electrically Erasable Programmable Read-Only Memory) on the control board is bad. This can be caused by a power surge or glitch through the electrical lines. You can try to reset the control board by completely unplugging the range (or shutting off the breaker) for 5 minutes. If the error code returns after plugging the range back in, then the control board for the range will need to be replaced.
Feb 05, 2015 | Thermador C301U Electric Single Oven
Why my oven shows f 13
your eoc is bad, electronic oven control (clock)
Apr 11, 2013 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire es300 gas range kepps flashing f10 and f13.how to resetand get the clock working
Hello Carol Martin - Typically, error codes F10 and F13 could indicate a variety of issues. The range could possibly have a shorted keypad, runaway temperature (higher than normal temperature), faulty EOC (electronic oven control) or, display wire harness missing/not connected. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
Mar 06, 2013 | Frigidaire Gallery GLEFZ384GC Kitchen...
What does F13 Error mean?
Here is what the F-13 error code means and the fix for it.
F13 Internal CPU checksum errors 1. Disconnect power for 1 minute.
2. Reconnect power.
3. If failure remains, replace the touch control module
So it says the main computer control had detected a error in the touchpad control
I hope this helps,
Gene
Aug 01, 2011 | Kitchen Ranges
How to fix the F13 error in this stove
F11, 12 & 13) Disconnect power, wait 30 seconds and reapply
power. If fault returns upon power-up, replace EOC.
Apr 15, 2010 | Frigidaire FEF336BC Electric Kitchen Range
F13 flashes on my Frigidaire electric range
F-13
Control's internal memory may have
become corrupted.
1- Press Cancel key.
2- If fault returns disconnect power, wait 30 seconds and
reapply power.
3- If the problem persists upon power-up replace the display
board.
Sep 25, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Receiving Error F13
Ken
Jan 08, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
No oven no burner
The F13 indicates a problem with the EOC (Electronic Oven Control board). This can be caused by a power surge or glitch through the electrical supply lines. You can try disconnecting electrical power completely from the range by unplugging it. Leave it unplugged for a few minutes. If the fault code returns when you plug the range back in, then the EOC will need to be replaced.
Dec 16, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Model FGFL87DSG error code F13
hi there,
the F13 error is related to the clock. this error can occur when the clock looses communication between the keypad or any of the sensor in the stove, including the heat probe. sometimes resetting the power will fix the problem.
here is what you can do:
disconnect power to the stove completely and flip the corresponding breaker on and off on the breaker box.
wait 30 seconds and than turn everything back on.
if the problem returns after power-up, replace the clock.
let me know if this helps.
Oct 12, 2008 | Frigidaire Kitchen Ranges
My kenmore elite electric slide in range displayed error and F13 and the oven won't turn on
Jul 09, 2008 | Kitchen Ranges
Frigidaire 30" Self-Cleaning Slide-In Electric Range - Black Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
