Question about Husqvarna Sewing Machines
Why does my ride-on leave an unmown strip in the middle
  • Husqvarna Master
  • 1,133 Answers
Is this a three blade ride-on? If so, I'd say the middle blade is broken, blunt or the spindle to it has failed/seized and its not spinning/cutting.
If it hasn't been serviced in the past 12 months, I'd suggest you take it in for one.
Posted on Mar 14, 2011
Why do my stitches "fall off" the edge of the fabric sometimes? It eeven hapoebs when i serging down the middle of a strip.
Most likely, the looper tensions are off--perhaps too loose. Be sure to ALWAYS RAISE the presser foot when threading the machine and then make an extra little tug on every thread when going through the tension disks.
Here's a document you can download and keep with your machine: https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwi24O6mm6XTAhVp04MKHaOCDs8QFggzMAI&url=https%3A%2F%2Fwww.bernina.com%2Fen-US%2FLocal-Resources%2FUSA%2FQuilting-Sewing-Embroidery%2FTensionHeadaches%2FBERNINA-Serger-StopTensionHeadaches&usg=AFQjCNHVP7gBN-VKOPkid_7jzIl76cZo8g
Solving Serger Dilemmas
Make It Handmade Perfecting Serger Overlocker Tension
Serger Series Part 3 Nailing Tension
Apr 14, 2017 | Sewing Machines
I got a new Brother 1634D Serger and would like to make a quilt on it. How do you get a 1/4 inch seam? please help me
Don't expect a quilt to be as accurate from a serger as from a sewing machine. First, you probably want to focus a strip quilt where rows of strips are stitched together. If you do strips, you won't have to worry so much about maintaining an exact 1/4" seam. You can also vary the widths of strips in order to camouflage any seam variations. Avoid a pattern that requires points being aligned! Any seam width variances will not as obvious as an error (it is intensive getting an accurate 1/4" on a sewing machine--so-o-o-o much more difficult on a serger). There are usually seam width marks on a serger that you can follow as a guide, but straight line serging is very difficult to accomplish. You can always try marking a line on your serger using painter's tape.
FWIW, making a strip quilt on a serger is a fast way of finishing a quilt. I divide my quilt into 3 or 4 sections, like making it in thirds or fourths. That way, when the quilt begins to grow, you are not constantly grappling with flipping or turning the heavy and bulky fabric. Instead, do each section separately, then stitch the sections together to make the whole quilt.
Also, be sure to press all the seams of a strip quilt in the same direction.
Strip Quilt Patterns
4 Free Strip Quilt Patterns That Standout from the Crowd Fons Porter
How To Sew An Easy Strip Quilt
https://www.quiltinaday.com/community/topic.asp?forum=2&topic=5481
Make FAST Serger Strip Quilt with 1 4 square Triangles
Feb 27, 2017 | Brother Sewing Machines
Need instructions for Mccalls pattern 7101 for bows can you help
Try contacting the pattern company. Otherwise, you will most likely need to purchase a duplicate pattern to get the instructions.
It looks like you may fold the fabric (wrong-sides together) on the center line, stitch the raw edges together but leave about a 3-4" gap unstitched (somewhere around the middle), then turn the fabric right side out through the gap, push out the points on the corners, hand-stitch the gap closed, then press.
Apr 24, 2016 | Sewing Machines
Consew 206rb1 stopped sewing
Have you tried a new needle? Needles should be changed out before each project and if a large project, several times during the project.
May 16, 2014 | Sewing Machines
When to cut rose bushes winter or spring
Yeah the freeze a bit but if you cut them low and pile straw on them they ride out the winter ok. I cut mine in the fall and pile leaves on them.
Oct 12, 2012 | Sewing Machines
I have a question on my Kenmore sewing machine style 385.17626 When I start sewing, after a couple of stitches it starts to bunch up and not feed through. It's a tangled mess of thread and fabric. I'm...
Try using a double strip of tissue paper 1 1/2 x5/8 inch placing it about 3/4 inch under edge of fabric and middle of seam allowance. Start stitching on the tissue paper and continue onto the fabric to the end of seam. After that remove the tissue. You can also hold both threads and slightly pull them when you first begin the seam to help them reach the back feed dogs.
Oct 22, 2009 | Sewing Machines
I am sewing on demim. The thread is inches loose on the back side... it is terrible. Not really sewn at all. I have changed the tension on top several ways but it does not seem to make a difference. I...
The manual can be downloaded for free from Singer's web site...
Are you seeing loops of the upper thread on the bottom side? If so, then the bobbin tension is too tight, or the upper tension is too loose. The threaded shaft on the upper tension might have stripped, leaving you with no adjustability.
Sep 16, 2008 | Singer 7462 Mechanical Sewing Machine
Embroidery Hoop
Any authorized Husqvarna Viking dealer will be able to get the hoop for you. Replacing the screw is much more economical and that same dealer will have access to the part number so that they can order it for you. This will take longer but will cost about 1/10 as much.
To find your nearest dealer, or one a little farther away, check the dealer locator at:
http://webservices.us.vsmgroup.com/DealerLocator.aspx?Brand=Viking
Aug 27, 2008 | Husqvarna Viking 1
Bernina aurora 440 qe
these quite possibly be the balancing strips for the inside shaft i dont know how factory puts them on but im sure if you ran your machine at a higher speed it would start shaken if it does this would be your problem the other thing it could be is the sewing machines case strips on machine its self
May 15, 2008 | Bernina Sewing Machines
Sewing Machines Logo
21 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
