I have a Samsung 54 High Definition Television PCL5415R i bought in 2003 that was only used for three years. The picture works perfectly but there is no sound. When headphones are plugged into the back....you can hear. Is there anything I can do?
  • 902 Answers
Unfortunatly not the speakers are more then likely blown but you can try and make sure you didnt actually mute the speakers. under the settings on the tv there should be an option to change the way the speakers act as well. i need more info on how you connect your audio/video to your tv to better help.
Posted on Mar 14, 2011
Convergence crosshait will not line up--samsung PCL5415R --red outline the picture
Replace Both STK ICs big black ICs example STK392-110 also 2 resistors 2.7ohms in same circuit call mats forparts 1-800-628-1118
Dec 14, 2009 | Samsung PCL541R 54" Rear Projection...
BLUE GHOSTS
You will need to get your geometry correction repaired. STK circuit has failed. You should be able to get repaired for under 300.00
If you know how to solder, you may be able to perform yourself.
Craig www.classtorations.com
Apr 10, 2008 | Samsung PCL545R 54" Rear Projection...
Samsung PCL 545R turns itself off ALOT
manual can be found on www.eserviceinfo.com
(you have to download all 3 rar files)
I have a PCL5415R exhibiting a similar problem, have not dug into it yet but my set also has convergence problems. I'm suspecting that I have a transistor going out somewhere as it will often turn off while trying to do the perfect picture function.
Mar 17, 2008 | Samsung PCL545R 54" Rear Projection...
My samsung projection tv #pcl5415r don't want to perform perfect focus adjustments
perfect focus functions are based on service mode setup...or factory settings. if the alignment of these setting are loss then the unit wont perfect focus. does the unit have a complete loss of convergence. a complete loss of convergence indicate possible failure of convergence amps.
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
Red and Green flashes
Possible CRT coolant liquid leak onto circuit board.Check
for moisture evidence....................T.
Nov 03, 2007 | Samsung PCL5415RB 54" Rear Projection...
Changing Screen Size on Samsung HP-R4272
you must not have the correct picture settings in the cable box, as although they are not HD they will still be widescreen, so check both tv and box for picture settings.
Oct 14, 2007 | Samsung HP-R4272 42 in. Plasma HDTV
Hour glass as picture
It is possible that your television needs to be degaussed. Gaussing occurs in televisions that have magnets, (usually speakers) placed to close to the unit. A degaussing coil can be purchased at a good electronic supply store. Simply follow the instructions that come with it. If this does not fix the problem, the television will require repair by a qualified service center.
Jul 25, 2007 | Samsung PCL541R 54" Rear Projection...
Samsung 54" rear projection PCL5415R Won't Turn On
Although I am not incredibly familiar with your model, There is most likely a small board mounted above the others near the crts, there is a small red connector with a blue wire if you unhook it it will remove power from the convergence IC's and if they are shorted it might come up with conv out, will need a new module.
May 04, 2007 | Samsung PCL5415RB 54" Rear Projection...
My picture has a "glow" to it
try to adjust your back lighting settings
Jan 13, 2007 | Samsung PCL5415RB 54" Rear Projection...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
